Problem
Aura Engine 1.6.1
This window is the engine's log: it shows what each conversion
is doing, step by step. Keep it open — closing it closes Aura
Engine. Minimise it if it is in the way.
Filters 30M taps — 5 output rates — linear + minimum
Session log C:\Users\winyl\AppData\Local\AuraEngine\logs\session-2026-10-18_10-25-10.log
Drop audio files on the window to start.
[10:25:10.644] [PACK] instruments off; pack 2 not installed
[10:25:10.645] [INPUT] listening for players on the link
[10:25:10.866] [UI] volume: 0 dB
[10:25:10.883] [UI] add: 1 of 1 file(s) readable
[10:25:10.883] [UI] settings: PlayerSettings { mode: Direct, fs_multiplier: 4, taps: 30000000, phase: Tfs, apodizing: 0, adaptive_apodizer: true, headroom_db: -0.5, iir_dc_blocking: false, subsonic_hz: 0, declip: true, isp: true, adaptive_headroom: true, xtc: false, xtc_geometry: Geometry { speaker_span_mm: 0.0, left_distance_mm: 0.0, right_distance_mm: 0.0, head_width_mm: 180.0 }, use_gpu: true }
[10:25:10.884] [UI] device: {0.0.0.00000000}.{809755be-efc8-4ed2-a8ac-fa644d8ca8b1}
[10:25:10.888] [UI] settings: PlayerSettings { mode: Direct, fs_multiplier: 4, taps: 30000000, phase: Tfs, apodizing: 0, adaptive_apodizer: true, headroom_db: -0.5, iir_dc_blocking: false, subsonic_hz: 0, declip: true, isp: true, adaptive_headroom: true, xtc: false, xtc_geometry: Geometry { speaker_span_mm: 0.0, left_distance_mm: 0.0, right_distance_mm: 0.0, head_width_mm: 180.0 }, use_gpu: true }
[10:25:24.743] [UI] settings: PlayerSettings { mode: Aura, fs_multiplier: 4, taps: 30000000, phase: Tfs, apodizing: 0, adaptive_apodizer: true, headroom_db: -0.5, iir_dc_blocking: false, subsonic_hz: 0, declip: true, isp: true, adaptive_headroom: true, xtc: false, xtc_geometry: Geometry { speaker_span_mm: 0.0, left_distance_mm: 0.0, right_distance_mm: 0.0, head_width_mm: 180.0 }, use_gpu: true }
[10:25:32.128] [UI] device: system default
[10:25:36.703] [UI] play Some(1)
[10:25:36.704] [CONV] Decoding: 02. Amsterdam.flac
[10:25:36.954] [CONV] Decoded: 44100Hz 2ch 8922240 samples, artist='Agnieszka', title='Amsterdam'
[10:25:36.955] [CONV] Lab: analyzing source...
[10:25:37.012] [CONV] Static DC offset removed: L=-6.174575e-5, R=-8.280029e-5
[10:25:37.019] [CONV] Lab: declipping source...
[10:25:37.050] [DECLIP] longest run on the rail is 3 samples (gate 17) — a limiter ceiling, not clipping; standing down
[10:25:37.050] [CONV] Headroom: output ceiling -0.5 dBTP (shipped -0.5)
[10:25:37.331] [player/gpu] context ready on 'NVIDIA GeForce RTX 5060 Ti' (DiscreteGpu, vendor=0x10de device=0x2d04)
[10:25:37.333] [POWER] {"cpuWidth":20,"renderPool":20,"powerPool":20,"mask":"0xfffff","machine":"Intel(R) Core(TM) Ultra 7 265@20","rayonGlobal":20,"ev":"pool","tMs":0.0,"unixMs":1792311937332}
[10:25:37.333] [POWER] {"key":"30M:176400","reason":"fresh","hpDeferred":false,"ev":"pretrial.skip","tMs":0.1,"unixMs":1792311937333}
[10:25:37.333] [TFS] Found cached TFS filter: C:\Users\winyl\Desktop\AuraEngine\aura-engine-v1.6.0-bundle-30M-windows-x64\aura-engine-v1.6.0-bundle-30M-windows-x64\fir-optimizer\output\fir_30M_176400_tfs_phase_v4.npy
[10:25:37.367] [PLAYER] 02. Amsterdam.flac: the source stages streamed the whole track in 0.32 s, 369 intersample overs corrected of 373
[10:25:37.367] [ISP] max=+1.07dBTP clusters=373 fixed=369 unfixed=4 residual=+0.00dBTP
[10:25:37.367] [CONV] Headroom: output ceiling -0.5 dBTP (shipped -0.5)
[10:25:37.368] [CONV] Adaptive Apodizer: source analysis...
[10:25:37.491] [CONV] Source analysis v3: cliff=18149 Hz (−45 dB), effective Nyquist=22050 Hz, 48 attacks judged, 75% ringing (sev 14.3 dB), ring freq=17757 Hz (32 bursts validated, 4 rejected as broadband/junk), aliasing=none
[10:25:37.495] [CONV] Adaptive Apodizer v3: pre-ring on 75% of 48 attacks (14.3 dB), ring at 17757 Hz is below the plausible ADC band (≥18963 Hz) — lossy pre-echo or spectral tilt suspected, using preset bucket → fc = 17993 Hz, 2048 taps, β = 24
[10:25:37.541] [CONV] Adaptive apodizing: 2048 taps, β=24, fc_norm=0.8160, cutoff=17993Hz
[10:25:37.544] [CONV] Adaptive Apodizer: applying...
[10:25:37.645] [PLAYER] bank fir_30M_176400_tfs_phase_v4.npy ×4 — 458 MB of spectra
[10:25:37.747] [PLAYER] Analog (1+2) (2 — RME ADI-2/4 PRO SE) would not open at 176400 Hz: another program holds it (an ASIO host), or the rate or the clock is locked in its driver's settings. Free it and press Play. [AUDCLNT_E_ENDPOINT_CREATE_FAILED at 176400 Hz]
[10:25:37.913] [CONV] Apodizing applied: 2048 taps on 8922240 samples (CPU FFT OLA + Rayon)
[10:25:57.527] [UI] device: {0.0.0.00000000}.{809755be-efc8-4ed2-a8ac-fa644d8ca8b1}
[10:26:01.678] [UI] play Some(1)
[10:26:01.702] [POWER] {"key":"30M:176400","reason":"fresh","hpDeferred":false,"ev":"pretrial.skip","tMs":24369.868,"unixMs":1792311961702}
[10:26:01.703] [TFS] Found cached TFS filter: C:\Users\winyl\Desktop\AuraEngine\aura-engine-v1.6.0-bundle-30M-windows-x64\aura-engine-v1.6.0-bundle-30M-windows-x64\fir-optimizer\output\fir_30M_176400_tfs_phase_v4.npy
[10:26:01.785] [PLAYER] Analog (1+2) (2 — RME ADI-2/4 PRO SE) would not open at 176400 Hz: another program holds it (an ASIO host), or the rate or the clock is locked in its driver's settings. Free it and press Play. [AUDCLNT_E_ENDPOINT_CREATE_FAILED at 176400 Hz]
[10:26:05.078] [UI] settings: PlayerSettings { mode: Direct, fs_multiplier: 4, taps: 30000000, phase: Tfs, apodizing: 0, adaptive_apodizer: true, headroom_db: -0.5, iir_dc_blocking: false, subsonic_hz: 0, declip: true, isp: true, adaptive_headroom: true, xtc: false, xtc_geometry: Geometry { speaker_span_mm: 0.0, left_distance_mm: 0.0, right_distance_mm: 0.0, head_width_mm: 180.0 }, use_gpu: true }
[10:26:06.199] [UI] play None
[10:26:06.450] [CONV] Decoded: 44100Hz 2ch 8922240 samples, artist='Agnieszka', title='Amsterdam'
[10:26:06.472] [POWER] {"key":"30M:44100","reason":"direct","hpDeferred":false,"ev":"pretrial.skip","tMs":29139.357,"unixMs":1792311966472}
[10:26:06.478] [PLAYER] Analog (1+2) (2 — RME ADI-2/4 PRO SE) would not open at 44100 Hz: another program holds it (an ASIO host), or the rate or the clock is locked in its driver's settings. Free it and press Play. [AUDCLNT_E_ENDPOINT_CREATE_FAILED at 44100 Hz]
