ToxaDev
- Joined
- Apr 10, 2026
- Messages
- 29
- Likes
- 35
@Erogen That "Himalaya" is a DC offset, not infrasound. Audacity doesn't remove the mean before the FFT, so an offset leaks into the first bins through the Blackman-Harris window. The dip at 10 Hz is the window's first null: 4 bins × 2.7 Hz = 10.8 Hz. Easy check: set the size to 65536 and the hump and the dip move four times closer to 0 Hz. On Audacity's scale, −40 dB in the first bin is an offset of about −43 dBFS, roughly 0.7 % of full scale.What about the low-frequency range? With CDs, you very often see "Himalayas" below 20 Hz. I know it’s inaudible. My speakers don't need it. Couldn't AE filter that out?
The converter already takes that out: the first thing it does is subtract each channel's mean. Nothing else below 20 Hz is touched, there's no high-pass in the chain. On a disc I have here (Mal Bicho) the rip and the converted file agree within 0.13 dB from 2.7 to 100 Hz, picture attached.
(Tip: on a 352.8 kHz file, size 16384 starts the plot at 21.5 Hz. Use 131072.)
A subsonic filter I'd leave to the playback chain. Where to cut and how steep depends on the speaker, and there it protects them from every source, not just from my files.
