AuraEngine Converter
Maybe I missed it in the above but what is the typical size expansion for a FLAC or WAV file? 20x...30x?
Need to cost this out for my 5000 ripped CD's in terms of new PC, with mega memory, mega GPU and mega storage... then more mega storage for the off site backup :)
I would probably be dead before they are all converted
Peter
This is needed for 90% or more of the CDs that were released since the beginning of the 21st century (and earlier)
Maybe I am lucky but 95% of my ripped CD collection (Blues and Jazz) was recorded in stereo between 1957 and 1975... so all well recorded on an analog only production chain (end to end) thus I don't suffer the issues with current music production standards.
Peter
Maybe I am lucky but 95% of my collection (Blues and Jazz) was recorded in stereo between 1957 and 1975... so all well recorded on an analog production chain (end to end) thus I don't suffer the issues with current music production standards.
Peter
Just because music was recorded in the 1950s-1970s doesn't mean that its contemporary CD releases are good. :)
Jazz and blues, classical music, are usually released well, though not always.
The situation is worse with rock and other genres; remasters are usually poor.
Metallica Death Magnetic 2008 (Japan SHM-CD)
30M Taps, All:On
Intel Ultra 7 GPU:OFF
Album Duration: 74m:46s
Encoding Time: 28m:22s (0,38)
Apparently the Japanese editions are better. That's not true. ;)
A good program for testing the speed of your computer system in various mathematical operations with sound. ;)
a bit hyperbolic statement i think :) some ISO now and then will pass unnoticed by a listener and can also be fixed by simply lower the digital volume by -3dB in whatever you use for playback .
This will not fix all mastering problems . The clipped samples may be interpolated to look nicer , but it's still shoddy mastering ? the DR number is not the whole story ?
That 90% of pop music have "hot" masters does not lead to that 90% off all music must be processed by this software ?
Ill whip out my infected mushrooms CD to give it a try if i find the time :)
Aren't the graphs in #19 more or less identical with the "after" being simply being dilated by a factor of about 0.8 of the "before", they both have the appearance of a trimmed hedge, in the "after" one there a very few peaks rising above the sheared line but that is not the appearance of a file with good good dynamic range. Numerically the dynamic range has increased due the mean values being lowered with respect to the peaks. The tracks would not sound different apart from volume.
30M Taps, All:On
Who would have thought!? I love that album, never listen to it as it was released. Sometimes listen to the Guitar Hero version.
The program will not change the final mastering.
The program will correct errors related to over-sampling and other related errors in the final mastering.
Those responsible for the final mastering should be classified as pests. :)
Perhaps the estimate that 90% of 21st-century CDs have poor final mastering is an exaggeration, but 89% is quite realistic. ;)
Ace of Base - Flowers (1998)
"03 - Cruel Summer"
If the software is correctly designed it should not actually do anything if the song is without any errors , you get a slight level change as the filters must have some headroom (afaik) and a straight upsampling nothing audible if you level match again when listening .
Is this representative off your collection ? maybe the 90% estimate is true for your CD collection ;) :D Ace Of base ! I consider "the sign" one of the worst tunes ever recorded
The Rolling Stones Foreign Tongues (2026)
That's how it's done today, on the CD release.
The program remastered all the samples that were causing clipping.
This improved the dynamic range a little, just slightly.
Unfortunately, it's still poor, because that's how it was mastered. Loud, with poor dynamic range.
That's how it's done these days.
A professional mastering specialist once told me that he masters the artist's preferences.
In the case of the Rolling Stones, it can be assumed that the members of that band, due to their age and years of working in very loud environments, have very poor hearing. Maybe that's why the mastering is so poor. ;)
Conversion speed 30M Tabs All Options: ON
Intel Ultra 7 = 1x
Intel Ultra 7 + GeForce RTX 5060Ti (8GB) GPU = approximately 3.2x - 3.4x
Conversion time approximately 0.10-0.11 times the duration of the music.
With this class of GPU, this already works acceptably.
Version 1.25 released.
Hello
I think you should read and understand:
Done.
The millions of taps are not needed for what is basically a level adjusting / expanding algorithm. All that carbon being burned for nothing.
Easily done with almost no delay without without needing to oversample into radar-frequencies. Take a look at Amplify or Normalize in Audacity. You can also use expanders to increase dynamic range.
When you have finished normalizing, expanding etc. you no longer have the original music. I'm sure it does sound different, possibly subjectively better. It's no longer the music that was released.
The thing is - unless you had access to the mixing panel or DAW during tracking and recording, you can't actually control how the music is limited or balanced as is it is captured. Unless you can lay your hands on the multitrack or stems, you can't rebalance the music. Unless you are holding the final master, you can't adjust how a final release is set to peak near 0dBFS.
You can EQ to suit your tastes. You can Normalize and perhaps guess what the peaks should have looked like. You can use an expander to make the DR number bigger, but thanks to the circle of confusion, the odds are that you did it wrong compared to how it sounded in the studio. The outcome is just "what you like". Fine for you, but not relevant for anyone else.
Last Test
Aura Engine 1.25
CD duration: 3178s
Encoding time: 316s
Encoding speed: 0.099x (10x)
The positive aspect of older stereo recordings is they don't start with say 32 or more tracks so being less complex means there is less to go wrong in any remastering.
Now Blues from the period can be a crap shoot, not in relation to remasters, but that Blues artists of the era recorded with labels with less funding/equipment/less skills than the big Jazz labels of the era so the original sound quality can be spotty.
Obviously I can't comment on how well a CD remaster is (compared to the studio master) but I can say that the 1000's of Jazz CD's I ripped all sound great as does releases from Blues focused labels such as Vanguard, Delmark etc. Chess recordings seem to have a "glaze" over them but obviously you can't ignore Chess given the artists they recorded.
Also Blue Note Jazz releases can be spotty. I have albums by say Jackie McLean from what would be well into the stereo era and it is really hard to tell if they are mono or stereo (very narrow stereo at best) and yet another Blue Note record from another artist in the same studio in the same year is clearly stereo.
Rudy was great but seemed a bit inconsistent from release to release. For example, Art Blakey's cymbals seem to be very "splashy" where others arent...maybe Art had naturally splashy cymbals that he liked or his attack caused this or Rudy recorded them this way?
Peter
