Erogen
- Joined
- Feb 9, 2026
- Messages
- 243
- Likes
- 56
Why offline, why million-tap
Every DAC upsamples. It has to — reconstructing an analog waveform from 44,100 samples per second requires an interpolation filter. But a DAC chip does it in real time with a filter of a few hundred to a few thousand taps. AuraEngine removes the real-time constraint entirely: it renders the track offline through FIR filters of 1 to 30 million taps, designed in 128-bit arithmetic, applied in end-to-end 64-bit float. The DAC then receives a 352.8/384/705.6/768 kHz waveform that is already reconstructed — its own filter has almost nothing left to doAuraEngine — The Signal Path
How AuraEngine renders 44.1 kHz audio at up to 768 kHz: every DSP stage, its parameters, and why it exists.
toxadev.github.io
Does anyone have any experience?
