You could also just create your own MRC with the 20$ app after disabling the default one, can't you?
Hi Peng.In my opinion, the Denon/Audyssey video is way better if the goal is to understand how the software works. The Joe N one seems biased to me and has a lot of his personal understanding/interpretation of how MultEQ X works. He seems like a better presenter and they could be one reason why his video may be the more popular one.
The D+M/Audyssey one is naturally biased too but at least you will get the correct (should be...) interpretation/explanation of the the features and how they work, right from the manufacturers.
What import option would you like to have?
Hi Peng.
You inspired me some 4 to 6 months ago to try Ratbuddyssey to see how much some finetuning of the automated XT32 results could further improve the room response. (You nicely demonstrated this with your REW postings).
Now we know, what a tedious process that is to use REW and Ratbuddyssey and iteratively feedback the results via the IOS App into the AVR.
The interview with the Denon developer and JoeNTell at least suggested that there might be an easier way in the future as opposed to the above mentioned process (via Ratbuudyssey) to get the REW corrections into the „Housecurve“ adjustments. (And yes of course these interviews are biased and contain marketing, but most here are mature enough to take it with a grain of salt and take out the useful info to make an informed decision whether to buy the MSApp or not).
This is what I am hoping for, just to clarify.
Absolutely also my experience. After putting in a lot of work with Ratbuddyssey the results were, let’s say a bit less than overwhelming. Recently we redid the living room and I didn’t want to go through it again. But it was fun initially and it proved the concept and taught me sth. After all it’s a hobby… right.Thank you for the clarification. I would just want to emphasize that the way I did it with Ratbuddyssey and the App is indeed very tedious, but it was only because I had too much time to try and get a near flat line. If I were to accept +/- 2 to 3 dB in the 20 to 200 Hz range, with no smoothing (okay may have leave 1 or 2 narrow dips alone) it would take me less than two hours to achieve, including the time to run REW a few times. Again, what I did was necessary and in my opinion/experience had no audible benefits, it could have made the other seats, or impulse response worse, though fortunately that wasn't the case, upon checking with REW. Still, that's just my opinion based on my own experience.
JoeNTell would be right for sure, if he said there might be an easier way in the future. There is always a better way.
I really wish it wasn't licensed the way that it is. Of all the ways Audyssey could have licensed it, they went with the most restrictive and profitable model, and it feels like a money grab. That said, MultEQ-X is not made by and sold by Denon and Marantz like the mobile app is. This is made by Audyssey, so it's essentially a cross-sell. Either way, I feel that after you've bought the software once, a reduced fee of maybe $50 or something per additional AVR would be far more reasonable for owners of multiple units.Should be tied to the product serial number and transferable. Count me out.
It's as if this product is not from Denon/Marantz but instead from a 3rd party
Audyssey does not actually use PEQs. As mentioned by others, and it was explained in that video Audyssey/Denon video (From around the 50 minute mark). ...... When you use the "PEQ" using MultEQ X, that PEQ data entry format, that is the frequency, gain and Q values, Audyssey would use the entered values to figure out the FIR filters accordingly.
thanks, so can you confirm that with mult-eq x there is no longer the problem of raising the trim level by the same amount as the boost applied? if so, do you think it would be enough to simply create this curve or, combined with it, raise the trim levels anyway?
This is by design - the digital headroom is managed such that we keep the level the same - this also avoids a large on/off level difference.
Currently, to compensate for the level, you should apply the same target curve to subwoofer and satellite speakers - then you can choose a frequency - when the curve is the same for sats and sub, any frequency will do, but if you look at, say, 250Hz, then you will usually find the target curve is down several dB there for the subwoofer. If you use that offset and add it to the trims it will get you what you're looking for. For example, say it's -4.5dB on the sub, while the satellite is at 0dB, then you dial in +4.5dB to your subwoofer trims.
This is expected behavior, and we anticipate that a future version of MultEQ-X will do this for you automatically.
This is correct and laid out very well. I learned this from a post @Jon AA made on either AVS or Audioholics (can’t recall). He showed the same thing. I know when the app came out there were a lot of complaints about lack of bass when using a sub curve. Post measurements show if you boost the sub trims the same amount as your target curve it will match the mains curve as long as you use the same curve. I always assumed it was a flaw in Audyssey but it sounds like it is just working as it was originally designed which was ruler flat bass.According to the avsforum thread on MultEQ-X, yes there is still the problem of raising the trim level (of the subwoofer channel). This post quotes a response from Audyssey support, which I take to be the definitive answer.
Audyssey tech suppport comment, as quoted on avsforum:
To further illustrate the issue, here are MultEQ-X graphs for the Surround and Subwoofer 1 channels using a "target curve" that I created, in demo mode. Reference is set to my "target curve", and Flat is unchanged (flat). (I captured this image with the Print Screen button, followed by paste to a graphics app, crop, and vertical stretch x2). Comparing the graphs, the target curve level is 0 dB at 1 kHz for the Surround and -5 dB at 1 kHz for Subwoofer 1. That means a subwoofer trim of +5 dB must be dialed in manually to achieve a smooth blend between the subwoofer and satellite (front, center, surround) responses.
Are these real and detailed responses, like REW? Or those fake-looking "targets" like Audyssey/ARC?Measurement with detailed frequency responses for individual channels
I’ve seen a few people saying this puts audessey on the same playing field as Dirac… not really, Dirac uses FIR for timing as well as freq response, this just uses FIR for freq response… Dirac corrects and adjusts the impulse response to effectively focus all freqs timing at the listening position and correct for drivers and how they effect the impulse and also the room to a lesser degree
Dirac delays any early arriving frequencys to make the phase flatSo far I've yet to see someone with measurements showing this clear advantage. Although I'm still curious as I did see some comparisons with differences in phase, it just wasn't clear if/how what Dirac did was any better.
So he’s disputing what Dirac does and how it works… I’m not in a position to provide that as I don’t own a Dirac processor… but it’s well publicised what it does and how it does itYes but he’s asking you (or someone) to show him the above measurement that shows the flat phase response after Dirac.
