Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Welcome to ASR. There are many reviews of audio hardware and expert members to help answer your questions.
Click here to have your audio equipment measured for free!
This sounds really good to me. I'm cutting my fronts (Revel M126BE) at 100. Anything obvious that I should still be addressing? I'm EQ-ing to 2000 to address a dip at 1.8. I should mention that I have two 1000w Rythmik subs bringing the low-end flat to under 20.
I have to say the latest 1.5 update has blown my mind! It is another world better with the 9db EQ limit now removed for the bass.
This latest update is what audessey should have always been!
It is more fiddly to get right vs DIRAC, but given dynamic EQ, it's now better than DIRAC for me.
How does it work for >9 dB boost for the other channels? I’d love to replace the Bose 901 equalizer with something like Audyssey. Dirac does a decent job, but misses out the very last bit of boost. The delta between 1 kHz and 10 kHz is 22 dB!
Are the filters in MEQ additive? If I added a bass shelf, then added a tilt filter, would the tilt filter then lift the existing bass shelf on an axis?
Thank you. Does the order of the filters matter? I am using a -0.2 tilt and +3db shelf at 101 and crossing my subs at 100 and it sounds really good. Sounds like more bass than expected but still controlled. I did decide to use Auto for the subs at 20 and it sounds tighter. I tried importing the Harman Curve but didn't like the way it sounded nearly as much.
Thank you. Does the order of the filters matter? I am using a -2 tilt and +3db shelf at 101 and crossing my subs at 100 and it sounds really good. Sounds like more bass than expected but still controlled. I did decide to use Auto for the subs at 20 and it sounds tighter. I tried importing the Harman Curve but didn't like the way it sounded nearly as much.
I go full range. My tilt generally tracks what my speakers are trending toward in my room on the high end, so I don't bother with a curtain.
The multiple shelves that I run are basically to account for where I want bass for music (the 100Hz shelf) and then a bit more low end for movies (the 50Hz shelf). I found that it gives me a nice balance that works great for both.
