Audyssey A1 Evo to USB Interface with CamillaDSP
yelloguy
I would never have undertaken a project like this but for the AI chatbots. I have been happily using A1 Evo optimized Audyssey calibration for listening to 2 channel music using a Topping E50 DAC going into a Denon 3600 AVR. Speakers are B&W 683 and two SVS PB 1000 Pros left and right. A1 Evo gave me a great sound stage and very precise instrument placement and the Topping E50 brought its own enhanced clarity (I think) compared to the built-in DAC on the Denon. I use Apple Music playing on a Macbook Pro for feeding the E50.
Recently I started playing with adding a bit of EQ using CamillaDSP. I used ChatGPT (Thinking model) for setting this up. The non-thinking model had a ton of problems and gave me some wild goose chases. Google AI Studio struggled as well.
From there I jumped on this Behringer UMC404HD USB Interface just to see what was possible. The idea was given to me by OCA himself. On seeing a picture of my setup and my preference for 2 channel music he told me to get an interface and cook the crossover manually for better results. I didn't have the time back then but decided to try it now.
ChatGPT Thinking gave me the steps to set this up. But it struggled a bit with REW measurements and getting timing reference, etc. With some estimated timings I was able to get this working over the weekend but didn't like the sound much. I felt that A1 Evo was a much more cohesive sound. I did some limited comparison (re-connecting the cords does not lend itself to proper A/B comparisons) so this was a very sketchy test.
Enter Grok yesterday. It really took over where ChatGPT left off. I was able to get it to give me good instructions on getting an acoustic timing reference for sub measurements, look at my graphs and come up with the right sub delays. It took 3 iterations but the sound now is much better than my previous A1 setup, and it can get better with a little more effort. After enjoying the new sound for a couple of hours I went back to the old sound because I thought it was pretty good. 2 songs later I nope'd out to the interface again... And loudness is not it. I was listening at about 78dB avg SPL using a phone app in both setups.
I (mostly) like the sound that my speakers produce in Pure Direct mode. The lowest 40Hz bass notes are kinda sad but everything else is superb. (Well, I do like a high shelf at 2.4k for -2dB but that is for another post). So the plan was to let the speakers do what B&W intended for them to do but cut them off at 60Hz and let subs do the bottom end. I have 3 little filters to reduce peaks in my bass for now, but other than that it is all just speakers doing what they want. The bass is tighter than my previous setup (which was done with a 6dB excess bass room curve) and most of all, the mains are shining. Highly recommended!
I love this, I've been using Claude Code to analyse OCA's file format and A1 Evo Express (fyi I didn't edit the code, just analysed it).
A1 Evo Express calculated the distance of my Front Right upfiring Atmos speakers as 4m compared to 2.5m of the left. I exported the frequency response from REW and asked Claude Code to do research using Perplexity and analyse measurements and it concluded there was a reflection skewing the distance calculation. I haven't verified what it did yet and I still think it's impressive.
Ya it is a hit or miss. It is like having any old tech support try and help you - sometimes they give you the right ideas, sometimes they end up wasting your time.
You would have better results with measurements and showing graphs to the AI. Some like jpg exports in a certain smoothing and zoom level, others work with text export from REW measurements. But the problem also is that A1 Evo kind of limits your options for what you can do. I haven't touched the Express version but played with all the versions up to Express. For multi-channel, Audyssey and A1 is the best way to go.
Overall it is pretty impressive what you can accomplish with AI. But it is not for the technologically challenged.
Reading the review for my USB interface here on asr (actually the 204) , I have now learned that it sends only 1v signal on the RCA output. Which explains my need to turn up the volume so much. Now I am thinking of returning it and buying another interface. Probably a Motu or a Focusrite.
