AudioQuest JitterBug FMJ — Forensic Teardown, Shielding Analysis, and VBUS Scope Traces
Hertz1
Introduction
Following questions regarding the internal layout and efficacy of USB conditioning dongles, I performed a destructive teardown of the AudioQuest JitterBug FMJ, coupled with oscilloscope probing of the VBUS rail. The goal was to examine the physical construction, component identification, and actual noise attenuation performance under test.
Key Physical Findings:
  • Component Anonymity / Masking: The internal passive components lack any top-side laser markings, ink stamps, or standard manufacturer identification, preventing verification of part numbers or precise electrical specs.
  • Thermal Signatures: Internal metal shield cans exhibit distinct chromatic heat-tempered coloring (blues and purples), indicating exposure to localized thermal stress during manufacturing or welding.
  • Shielding Architecture: The internal assembly resides within a non-grounded, floating shell configuration, raising questions regarding Faraday cage efficacy against high-frequency external EMI/RFI.
Oscilloscope & VBUS Findings:
  • Ripple Transfer: Comparative probing of the raw input VBUS against the output rail downstream of the JitterBug FMJ shows.
Raw VBUS
  • Transient Behavior: Under dynamic load steps, the trace indicates that the device functions primarily as a pass-through rather than an active decoupling or filtering stage.
Visual Documentation & Traces
Jitterbug FMJ
Discussion Points:
Given the lack of component documentation, floating shield design, and scope measurements showing minimal impact on VBUS switching noise, how do these implementation choices align with performance claims? Curious to hear thoughts from other members who have probed similar devices.
I don't have a whole lot to contribute here, but I'll say two things:
1) Thanks for doing this. Always glad to see content like this.
2) There's really just not a whole lot going on in there, seems to me.
Thanks for the feedback. To give some context, I actually benchmarked a handful of these USB conditioning and filtering devices on the bench—including the iFi iSilencer+, the Labahua filter, and an ADuM galvanic isolator module.
Out of the entire batch, the JitterBug FMJ turned out to be the worst-performing of the lot, doing very little to suppress the VBUS switching noise while carrying that sparse component layout inside a floating shell.
What can I say my AI assistant has very dry humour
I'll be tactful and say the target audience for this wouldn't know a proton from an electron. AudioQuest is happy to take their money, though.
Did you know you can take the virtually ineffective circuit and plug more into redundant ports to further the impact... Some how... With no apparent in line interactions.
We call it snake oil around here. But mention it in other forums and your posts get deleted. Go fig.
You go around highlighting an ineffective solution to ineffective power implementation then the men in black will visit.
Yup. We're just a bunch of tin-eared engineers here, that can't tell the sound of one power cord from another.
Ah well I'd recommend headphones or speakers personally. They're surprisingly sophisticated over a run of copper for auditory delights.
I did as well except that it was our dog that did it for me:
He is available for hire although he is not as motivated as when he was young and teething! :D
You may have found a valid use for AudioQuest stuff: dog toy!
Clearly, the sky is the limit!
We are lucky to have companies, that take care of our well-being.
You just need a huge budget to stack that 5% improvement... And a twenty port hub.
Maybe he likes snake oil. We may have a new review contributor! Watch out panthers. ;)
Bummer about the OP's new user name. The first one gave me an adolescent chuckle.
