Is there still a member on here that is connected to Audiophonics?
I'm late.I'm talking about the cable,shielding it all the way means that the XRL's shell should act like a Faraday cage too,protecting the bare soldered conductors.
Extreme maybe but that's the principle.
Frequency response of large cardioid diy speakers + subwoofer at the listening position at a distance of 3m from the speakers. Smsl mda1 raw dac + Emotiva PT-100 preamplifier + Audiophonics MPA-S250NC power amplifier. Played calibrated 24bit 96kHz pure pink noise from youtube and measured with phone microphone using Spectroid application.
It's really great that apps like this are available for free. The phone's microphone may not be very accurate, but I adjusted the low pass crossover and volume of my subwoofer based on these measurements. There were many pink noise videos on Youtube, several of which were clearly not very accurate. I've also tried the EQ adjustments of the Wavelet application when playing from the phone through the speakers, and I think these Spectroid measurements are very indicative from the ear. I also measured a couple of other amplifiers and they gave slightly worse results for some reason.Whether it's accurate or not, I don't care. Isn't it amazing that we have these kind of measurement tools and software we can run on a handheld device basically for free in 2024?
It seems like a very unlikely mistake, check your source, and...erm... check your hands.So I just got this and to make left and right separation I actually have to put the left hand speakers into the right hand output of the amp. I am guessing this is not normal behavior and that my amp must be faulty right?
Already done that and yes, facing the speaker the right channel speaker tests comes from the left side. Ive tried to connect it to another preamp and it was the same. Created a new thread for this.It seems like a very unlikely mistake, check your source, and...erm... check your hands.
Hi, I'm not sure I understand your question so apologies if I've got this wrong.I own this Amplifier in the XLR edition.
I was wondering where i can find out what the Polarity of the Trigger Socket should be as i would attach a wallmart supply as a trigger.
In case the information is in this thread i missed it.
Makes good sense - I hope I didn't come across as patronising. Can't help with your actual question I'm afraid. Audiophonics have been quite good at responding to direct questions when I've asked them before.Hello there. I am aware what it’s for.
In My setup there is no device with a trigger output. So I have to build one. So I wanted to find out where + and where - is on a typical trigger. As in “Center Positive”. Hope that makes more sense ?
Patronising? No not at all!Makes good sense - I hope I didn't come across as patronising. Can't help with your actual question I'm afraid. Audiophonics have been quite good at responding to direct questions when I've asked them before.
Also another scenario, what will happen if i leave the Amp swith permanently On and use a remote controlled Socket in order to switch off the power before it reaches the amp?
Will it damage the Soft Start switch in the long run?
If I'm not mistaken, audiophonics is selling a 12V trigger you could use on gear which have none.Hi, I need some information: I would like to connect this amplifier directly to an Eversolo DMP A6 DAC streamer, which does not have a trigger. Should I leave the amp on 24/7 if I always want it ready to use or is there a way to put it on standby or something? Thank you
