Audiophonics HPA-S400ET Class D Purifi amp
Fledermaus
France
May I add : if loud enough, bypass is also the way to go theoritically considering SNR, provided source output hot enough and no impedance mismatch, since DAC output noise will be less amplified with less amp gain.
Pritaudio
Other threads have stated that the audio phonics build quality is not that good compared to others. Is this due to the input board, wiring, placement or case choice.
Pritaudio
There are two models with a price difference on audiophonics. The only difference I can see is the case and obviously placement too. Maybe request some emi stickers if parts are placed close to each other.
tmtomh
I have not seen that here - unless you are referring to the cable-routing issue that results in low-level hum in one channel when there is nothing connected to the input. But that’s not a build quality issue. RE the two similar units, the price difference is the casing (including different location of power switch). That’s it.
Pritaudio
Unrelated but, there is no standby function or choice of trigger.
what is power usage when idle?
Oklei
Build quality is top. Idle power usage is 17W.
Pritaudio
Build quality is top. Idle power usage is 18W.
Is it advisable to leave it on for 24/7, or say 10-12 waking hours everyday.
apart from shortening the lifespan, what is the difference in watts from 18w if there was a standby mode. The electricity cost will add up.
Oklei
I use an ethernet power strip to turn it on/off with my remote via the raspi. So I never leave it on for 24/7. But it runs rather cool therefore I don't think lifespan would suffer too much. I have it 3 months now so time will tell about reliability.
Harmonie
France
I prefer Mono(amps that you can place just behind speakers with very short speaker cable.
So the Mono audiophonics could be the next amps on my future list.
Don't ask me why or what's the difference between 2 foot vs 10 foot cable.
It's my habit and happy so.
Morla
Europe/Germany
No question :cool: it's a lot easier to lay interconnect cables, no?
My canare 4s11 are vergy rigid.
Harmonie
France
Yep,
I do it old school too,
longer interconnects, short speaker cables. I can't help it, I was "educated that" way.
JaapDeventer
I'm in doubt between ordering an Audiophonics purifi amp or building one. Might even buy LPA-S400ET and move the parts to a Slimline 2U 280mm case. One question I have is on Audiophonics using their own bufferboard. Purifi uses feedback from the speaker terminals. You can see them using three wires between speaker terminals and the Eval1 board. How is this solved on the Audiophonics bufferboard. I see only two wires between speaker terminals and the board.
Harmonie
France
+1
But then, as long as my mono's are doing OK (and I have 2 pairs of those), I feel still fine.
But if,
Yes, I would probably go for their DIY kit.
TabCam
Do not know for sure but I posted pictures earlier in the thread. I know that I have bigger hum problem when converting unbalanced to balanced with the HPA-S400 then my Anthem I225 which had no humming problem. I also know I should not convert ;), it just showcases grounding problems.
