I think you are asking "If I can buy a Rotel A14 for the same price as an Audiophonics DAW-S250NC, what distinguishes them?"
My take on the Audiophonics is that if it completely covers your use case, it's a good value. I have only one music source and I never switch it. I just wanted a modern class D amp with a volume knob, display, and remote, and that's what I got. If your needs are different, be sure you'll be getting everything you need out of the Audiophonics.
- The usable wattage on the Audiophonics is going to be higher, 150W @ 8Ω on the Audiophonics vs. 80W @ 8Ω on the Rotel. Amir says "So you better have a beefy amplifier to drive [Elac DBR-62]", but I expect 80W is enough. Others should chime in if I'm wrong about this, or anything else.
- The Rotel has a lot more inputs. If you need a phono input, for example, the Rotel is your only option.
- The network music player on the Audiophonics is Wifi only. The Rotel offers Cat5 wired networked connections as well, it looks like.
- The software driving the network player on the Audiophonics is an older Linkplay module. I don't know what's in the Rotel, but it appears to be Roon ready, which the Audiophonics is not and may never be. You should look carefully at your use case and figure out which one works best. If you don't need a built-in network player, the Audiophonics DA-S250NC is cheaper.
- Form factor and UI are similar but details matter. Is there a feature you need that one doesn't do, or one does better?
