Indica
- Joined
- Mar 8, 2020
- Messages
- 10
- Likes
- 2
Hello everyone!
I've been doing so much research over the last few days. I've come across a setup I really enjoy, then I do a bit more research, read a few posts on here, Reddit, HiFiGuides and find something else that I think is it. So thus all my posts, across the forums
My needs and budget are listed below:
I do have a slight grasp on different setups I think would work well for my needs.
Amps, DACs, pre-amps
The first thing I need help with is WPC, speakers that whole shebang.
For the Paradigm's specs, I read:
I assume that means, at max, I should only be pushing 50WPC to these? I enjoy the pretty loud music, so I'll be pushing these on the harder side.
Top of my ranks currently:
Both of these options seem to be the way I'm more than likely going. But that also depends if I'm understanding the WPC, Speaker section correctly.
Middle of my ranks currently, mostly due to cost, and trying to figure out if it's worth it:
**According to a Reddit user I could damage my setup with a stack like this:
But, I'm open to any suggestions that y'all have for me. But from what I've read, seems The Paradigms will be perfect for my needs, All the amps, have their pros, and cons, and costs. While I can spend up to $550. I wouldn't mind keeping it cheaper, for future upgrades like a nice pair of headphones.
T.I.A y'all.
- Budget:$~550USD
- Location | Retailer: USA/Prefer Amazon, but money talks, so where ever it's cheaper
- Inputs: Optical for TV, USB for PC, Phono for Turntable,(Willing to settle for RCA phono stage if needed) Bluetooth would be a plus. But not required.
- SoundStage: Home Office setting, 60% in an office chair, 40% sitting behind office chair on a recliner for media and PS4
- Uses: Music, TV/Movies, gaming
- Music taste: General range of things. Black Sabbath, to pink Floyd, to Tyler, The Creator, to Mild Orange(Indie rock). I love my Sabbath hard and loud, and my Floyd, medium but deep.
- Possible Future upgrades: Headphones, and a sub as I enjoy my bass.
- Speakers: Currently my main pick is Paradigm Monitor SE Atom($238) 2nd choice ELAC debuts 2.0 B6.2.
SUITABLE AMPLIFIER POWER RANGE 15 - 100 watts
MAXIMUM INPUT POWER 50 watts
- SMSL AD18
Pros: All in one, built-in sub out, has all the inputs I need.
Cons: Seems the Topping mx3 is a cleaner sound. requires additional hardware to use with my TT
Questions: It's rated for 80WPC@4ohms, would that translate to 40WPC@8ohms?
- Topping MX3
Pros: I've fallen in love with the display/design if I'm being completely honest. Cleaner sound according to Z reviews.
Cons: Weakest WPC in the group, requires additional hardware to use with my TT. Doesn't cut off low freq when a sub is introduced
- Topping DX3/Toping PA3
Pros: Higher quality DAC, higher WPC, Cool looking,
Cons: Sub output will be tricky*, Possibly damage to my setup**. 2x the cost of either solution above.
- Denon PMA-600NE
Pros: Checks every box on my needs. Phono inputs for TT, High WPC, sub-out, Dual Speaker out.
Cons: Headphone amp isn't the best, Cost, especially if I were to need to invest in a headphone amp down the road.
I'd slap a pair of RCA splitters (1 male to 2 female) splitters on the DX3 Pro's outputs. One L+R pair goes to the PA3, one pair to the subwoofer. Get the relative volumes of the PA3 and subwoofer dialed in and then leave them there; then use the DX3 Pro as the volume control. (You could also vary the PA3 volume to act as a bit of a tone control. Turn the PA3 down a bit and turn the DX3 Pro up for a bassier sound. Do the opposite for less of a bass tilt)
Alternately you could use the sub's high-level inputs.
It can easily, and mistakenly, be engaged to run as a DAC instead of DAC/Pre causing a sudden full 2v output to go to your amp. If it happens to be turned up high, you could damage your speakers or amplifier. I’ve also read reports of the DX3 Pro damaging headphones due to a lack of a protection circuit IIRC. These may not be issues depending on how you intend to use this setup.
T.I.A y'all.
