tuga
Not sure what’s so appalling about it. The most recent one in the list is Mac OS X Leopard (ancient), but it seems up there with the best.
Or Ghost Spectre?
Ever heard of noise-floor modulation (by signal)?Hm, -160dB, truly appalling. How do they even measure that?
Do you have any experience with "Audiophile Linux?I think using a 'player' on a general purpose PC/Mac is quite different from building a single purpose 'player' on a minimal OS. There's a lot more support for doing the later with Linux than Windows.
Installing Roon Server on my five year old Lenovo was plug and play, no candles, no headstands. Audirvana as I recall was also straight forward. RME drivers occasionally get an update (none these days essential but that's hardly difficult.But doesn't the data need protocol-converting before it's transmitted (streamed?) on to the DAC?
Anyway for the trasmission to be 'bit-perfect' the music playing software (renderer?) needs to be set so that there's no tampering with the signal and to ensure that the operating system doesn't interfere with the data stream.
With iTunes you need to disable Crossfade, Sound Enhancer and Sound Check and it's so dumb that it requires that you set the correct output sample rate and bit depth in the Audio MIDI Setup control panel, otherwise iTunes will use MacOS' appalling CoreAudio SRC. Also read about hog mode.
So not really plug-and-play.
I don't use WinOS but I have the impression that it's even worse, that you need to install dedicated drivers, light a candle and stand on your head...
Yes they do. My point was that Windows is no hindrance.You missed my point.
Roon Server is not your free run-of-the-mill Windows Media Player, it is extremely likely that it'll optimise (take control) the output. Same with Audirvana.
It is if you use Windows Media Player or another basic player. The post I was replying was defending that any player can do 'bit-perfect' but that is notYes they do. My point was that Windows is no hindrance.
No comment.Ofcourse this is a very subjective opinion .
So no evidence in measurements.
Protocol is how you transport data. Data is the same irrespective of the protocol used to transmit it.But doesn't the data need protocol-converting before it's transmitted (streamed?) on to the DAC?
Who cares about the UI? I love it's super clean UI and would never change it! Foobar2000 works flawlessly and has options even expensive software doesn't have. I've tried Plex, JRiver, Musicbee, Minim and others. None of them could convince me like foobar2000 does. Some of them don't even follow common standards, like JRiver, which has it's own proprietary Replay gain implementation. Bah! Foobar2000 does 99% right and it's free.If Roon was free the others would be obscure niche applications. In my opinion the only reason not to use Roon is cost, and I just quit paying yearly and bought a lifetime license. I deleted Foobar after a out an hour. Too much work to get the UI nit to look like a freshman software project.
Why on earth would you use anything else that EBU R128 (which is open standard) this day's? And as such implemented with no change in JRiver (-23 LUFS) and available as plugin or integrated in many others.Who cares about the UI? I love it's super clean UI and would never change it! Foobar2000 works flawlessly and has options even expensive software doesn't have. I've tried Plex, JRiver, Musicbee, Minim and others. None of them could convince me like foobar2000 does. Some of them don't even follow common standards, like JRiver, which has it's own proprietary Replay gain implementation. Bah! Foobar2000 does 99% right and it's free.
Isn't UI the reason for Roon's popularity (also Audirvana, JRiver, etc.)? I'd say many people do.Who cares about the UI?
It probably is. But not for me. And it seems for others not either. Foobar2000 is quite popular inspite of it's simple UI. And there's a reason why that is. It simply does right what it does. Like when I tried JRiver and found out about the BS it does concerning ReplayGain.... Uninstalled it right away. Who wants to put up with crap like that?Isn't UI the reason for Roon's popularity (also Audirvana, JRiver, etc.)? I'd say many people do.
I don't use Roon, but I need a complex, well-designed UI for browsing; that's why I use a laptop instead of a smartphone or tablet.It probably is. But not for me. And it seems for others not either. Foobar2000 is quite popular inspite of it's simple UI. And there's a reason why that is. It simply does right what it does. Like when I tried JRiver and found out about the BS it does concerning ReplayGain.... Uninstalled it right away. Who wants to put up with crap like that?
