audio_tony
This is a relatively old DAC which I think was initially produced around 2013 - so this must be 11 years old now.
It's based around the ESS9016 DAC chip.
My test setup: Asus Xonar STX sound card with a self built buffer / gain box in front of that. Host PC is an Intel i7 running Windows 10 with 32G RAM and SSD - no mechanical disks or CDROM drive present.
I also use an Altor Audio Olivine-2 ADC, however the Asus Xonar was used these measurements.
Sound card input was set to 24bit/96kHz, DAC was set to 24/192kHz
Even though this has a USB input, I used an S.M.S.L. PO100AK as a USB to coax bridge, as the USB input on the Audiolab appears to have some issues.
I used Arta for the measurements.
Spec:
THD 0dB
THD -3dB
THD -6dB
THD -30dB
THD -60dB
THD -90dB
Frequency response using Arta's sweep.
Frequency response (smoothed white noise):
Jitter:
Multitone (I just can't seem to get this right...)
Digital silence:
Spec:
| Resolution | 32bit |
| Maximum Sampling Frequency | 84.672MHz |
| Digital Inputs | 1 x 24-bit/192kHz Coaxial 1 x 24-bit/96kHz Toslink Optical 1 x 24-bit/96kHz USB |
| Frequency Response | 20Hz-20kHz (+/-0.2dB) |
| Total Harmonic Distortion (THD) | 0.002% |
| Dynamic Range | >110dB |
| Crosstalk | 112dB |
| Analogue Output Connections | 1 pair RCA Phono |
| Digital Output Connections | 1 x RCA Phono and 1 x Optical TOSlink |
THD 0dB
THD -3dB
THD -6dB
THD -30dB
THD -60dB
THD -90dB
Jitter:
Digital silence:
