AudioGrade: A macOS toolkit for examining recordings, from stereo to multichannel and ADM
gpiano
Hello ASR!
Comparing different releases of an album often means looking beyond sample rate and bit depth. With AudioGrade, we wanted to bring useful measurements and visual inspection into one macOS application. I lead the team that developed it.
You can examine loudness, True Peak, DR14-style dynamic range, LRA, and stereo phase relationships alongside spectrograms and waveforms. A source detector also looks for indications of previous lossy encoding, with findings presented as evidence rather than certainty.
The Pro edition includes comparisons between masters and analysis of multichannel recordings and ADM BWF/BW64 files. Its spatial view lets you inspect channel activity and follow audio object movement.
Processing takes place on your Mac, and the original audio remains untouched. The app is available with a free tier and a single-purchase Pro option.
I’m particularly interested in how it fits into your existing analysis workflows and any discrepancies you find when checking results against other tools. Specific examples and technical criticism would help us improve it.
Explore AudioGrade
For a Mac! How nice! I don't need that kind of workflow but applause nevertheless. Ah...could I use it to compare the spectrum of different pieces of music? Like to see how much power peak and RMS in each 1/3 octave band or something?
Thanks for the kind words! AudioGrade Pro lets you compare the spectra and spectrograms of two different audio files side by side, so you can explore differences in their frequency content.
For the specific measurements you describe, though, the current version doesn’t provide separate peak and RMS readings for each 1/3-octave band. That would be a useful addition for this kind of comparison. Thanks for suggesting it!
I didn’t understand from the website if this only works with local files or also with Apple Music streams from the Music app.
It isn’t limited to local files. Pro includes Live Audio, which lets you view a running app’s audio output in real time.
To try it with Apple Music, open Visualizer -> Live Audio and select the Music app. This shows a live spectrogram of the playback output. The full file analysis and reports require local files.
Thanks for pointing that out. The website could explain the difference more clearly.
@Head_Unit, a sneak peek at the next update...
A new update is out! The main addition is Band spectrum and comparison, available in Pro.
You can now:
  • Analyze one file or compare two using octave, 1/3-, 1/6-, or 1/12-octave bands.
  • Compare RMS and peak levels across entire tracks or selected time ranges, with overlaid curves or a difference view.
  • Listen to individual frequency bands, with optional LUFS loudness matching when comparing playback.
  • Sort measurements to find the largest differences and export charts as PNG or data as CSV.
This makes it easier to compare different masters or releases and hear where they differ.
