Thank you for the insights on the Nuprime products quality and on designing product around the ES9039Q2M. I wasn’t aware of all the multi room benefits you pointed out.
I started looking at AioP because I’m a big fan of the work Mitch Barnett does designing convolution filters with Audiolense. For two channel I’ve been using his filters for several years and they sound amazing running on Roon and playing through Berkeley, Meitner and RME DACs. With AioP and Dolby decoding I could send the decoded multichannel PCM to a Mac running Mitch’s filters and then from the Mac to a pro DAC like the Merging Hapi.
But these are many boxes and it relies on one person, Mitch, to stay up to date if you change anything. Also Mitch charges 1500 for a multichannel convolution filter. Given the time and talent involved, that’s very fair, but it’s not cheap.
I need something everyone in my house can use, and the MIMO technology Dirac uses for bass management is truly amazing. The Merging DAC doesn’t have any easy wireless way to control the volume. Audiolense can generate filters with 60,000 taps that have resolution down to a hz or two even for 192khz music, and it can blend in a time aligned way multiple subs, but there is no absorption taking place, as there is with Dirac and Trinnov. So a single box with HDMI CEC and with a proper implementation of Dirac and great DACs is very appealing.
I need 10 channels (TAD R1s front main running full range to 20hz, KEF Reference 2C center, KEF Meta R3 surround, KEF Meta R8 height, 2 Perlisten R210 front subs, one Rythmic F12SE rear sub, all with Benchmark amps, in mono for front). Even with the Denon 4800h it sounds pretty good. But for stereo the RME DAC with the Audiolense convolution on Roon on the TADs by themselves sounds better.
