I've seen that but I have been assured otherwise. We will find out soon.
In order for the CI to have both the Digigram Dante PCI-E card, and also have a hardware based Ravenna card the unit would need to be redesigned from the ground up before the official launch. Because the piece of hardware they have now called the Altitude CI doesn’t have the space for it.I've seen that but I have been assured otherwise. We will find out soon.
I thought we'd established that there's always an ASRC in front of a Dante output because the source clock and Dante clock aren't synchronised.At this point I’m thinking the winning setup will be the Trinnov CI over Dante with Dante network set at 24/96. This way only 44.1 and 48 will be up-sampled. And SoX based 64 bit floating point DSP SRC that Trinnov uses is very transparent upsampling to 24/96. And native 24/96 content will be sent bit-perfect through the whole chain to DAC.
That's interesting. With or without ASRC?I also have a Appsys Flexisys AES with Dante daughter card.
Ya but there’s no need to alter the audio in the ASRC if the incoming and outgoing sample rates are the same. All it does is aligns the clocks for timing. If outputting a different sample rate then there’s a possibly for artifacts in the algorithm to degrade the sound quality. However this is minimized a lot when using 64 bit floating point DSP.I thought we'd established that there's always an ASRC in front of a Dante output because the source clock and Dante clock aren't synchronised.
Trinnov said so here. Therefore a Dante output can't be bit perfect even when the audio format is the same.
Quite right. Though you might have missed one - DACs themselves often have ASRC these days.I suppose when we focus on ASRC breaking the system from bitperfectness, we are forgetting about all the other sections of an AVP that also does.
Having been a hair-shirt audiophile, I now find myself pondering using both Audiolense/HLC, PLUS an upsampling tool like HQP or PGGB, to get the digital filtering right.So generally, all cases of HDMI -> Dante/AES67 will be going through some form of ASRC.
audiophilestyle.com
Have you seen the HX? It’s almost 4x the price of the H.Not even close. That Nuprime box is a joke.
Hyperion are still claiming 130dB DNR and 120dB THDN. It's not entirely clear whether they're quoting DAC chip specs, or actual measurements for a real, live, complete, production standard, piece of equipment. They're state-of-the-art results for a minimalist stereo DAC at any price, and quite without precedent for a jack-of-all-trades AVP. The absolute best Anthem, Marantz and McIntosh AVPs don't quite reach 110dB THDN yet. I'll have to remain cautiously sceptical for now, but if Hyperion can be shown to be honest, the functionality and performance of the APR takes away much the need for digital audio outputs. Those numbers are comparable with Merging and Okto.The APR-16 seems very carefully laid out. Wonder how quiet the DAC and analogue outs are. Alternatively, how reliable a DPR-16 with outboard DACs could be. And whether it’s best to use AoiP or AES/EBU. Would these outputs have a well implemented volume control.
PGAMiami was talking about the HX16, which won't have the same limitations as the H16. To your credit, you pointed out that the H16-AIP uses SRCs that cause audible degradation (hence your use of the Appsys). However they're used on the AOIP board to enable it to synchronise with Dante, and are not needed or used on the H16-AES. That has it's own limitations, such as a number of outstanding bugs. Without exception, all AVPs have bugs. To their credit, Nuprime have issued two firmware updates, they have publicly stated what the outstanding bugs are, how they're prioritised, and are engaged with the user community. The H16 also has only 12 output channels, not 16, and it performs DSP at 48kHz (like Storm). Maybe all that wouldn't be acceptable if it cost $10,000. Sure, the Trinnov ALCI will be better. But the H16 costs less than a 2 channel upgrade for the Trinnov.Not even close. That Nuprime box is a joke.
Dirac will work up to 192kHz on a PC with suitable SW.From what Kal has said a few times, Dirac will also work at 96kHz on a suitable PC.
They made it clear that they didn’t even know how many channels their processor could process until it was actually in the hands of customers! They bought some cheap third party Chinese board and popped it in a box and pumped it up before they even knew its capabilities and limitations. When the same company who has proven they have no idea what they’re doing make some pie in the sky promises about some vaporware box that is only a conception in their minds, my expectations are low.PGAMiami was talking about the HX16, which won't have the same limitations as the H16. To your credit, you pointed out that the H16-AIP uses SRCs that cause audible degradation (hence your use of the Appsys). However they're used on the AOIP board to enable it to synchronise with Dante, and are not needed or used on the H16-AES. That has it's own limitations, such as a number of outstanding bugs. Without exception, all AVPs have bugs. To their credit, Nuprime have issued two firmware updates, they have publicly stated what the outstanding bugs are, how they're prioritised, and are engaged with the user community. The H16 also has only 12 output channels, not 16, and it performs DSP at 48kHz (like Storm). Maybe all that wouldn't be acceptable if it cost $10,000. Sure, the Trinnov ALCI will be better. But the H16 costs less than a 2 channel upgrade for the Trinnov.
Yes, we all know by now you don't like the Nuprime. So don't buy it. Please change the record.
