Run ART on a PC (as a VST plug-in) and you can do that just as easily.Storm's implementation, at least IMO, is better not for for number of filters but for ability to put PEQ before ART and ability to appply tone controls after ART.
Last I had HTPC was in the elder ages. Actually remember it quite vividly as it broke some speed records while on the balcony of my NY flat back in 2001. Was -25C so it was a really good run.Run ART on a PC (as a VST plug-in) and you can do that just as easily.
Can you do that with 16 channels?Run ART on a PC (as a VST plug-in) and you can do that just as easily.
yes.Can you do that with 16 channels?
How do you know if the Storm processor will process at sample rates above 48kHz? According to my information, "Post-Processed Outputs: Up to 32 channels, 48kHz." When I queried them about this, their response was "Our chips are capable of 96kHz processing, so a bypass is possible and likely in the future."Anyone know whether the APR 16 will internally resample everything to 48khz, as an AVR like a Denon 4800h would, or process sources at their native sample rate, like a Storm processor?
Well, that’s what happens when one relies on ChatGPT. Yesterday its gave me a very detailed comparison of Storm vs. what it called less sophisticated consumer AVRs and confidently said the Storm was native rate. Today it’s apologizing for its error. Great catch Kal.How do you know if the Storm processor will process at sample rates above 48kHz? According to my information, "Post-Processed Outputs: Up to 32 channels, 48kHz." When I queried them about this, their response was "Our chips are capable of 96kHz processing, so a bypass is possible and likely in the future."
Do you have any news on when ART for PC will be released?Run ART on a PC (as a VST plug-in) and you can do that just as easily.
I learned from experience in sending the ISO-EVO hi-rez sources and got only 24/48 at the output.Well, that’s what happens when one relies on ChatGPT. Yesterday its gave me a very detailed comparison of Storm vs. what it called less sophisticated consumer AVRs and confidently said the Storm was native rate. Today it’s apologizing for its error. Great catch Kal.
That may depend on how you are implementing it. I am a Mac newbie, so I cannot comment.What about on a Mac mini? AI told me it also did SRC on Dirac.
Dunno. Like you, I can only ask but, although they have had Beta versions on the website for a long time, the current ones are not so describedDo you have any news on when ART for PC will be released?
That, of course, is not an entirely clear conclusion. Dirac, itself, can run up to 24/192 as I use it every day. The issue is, as it was with Audyssey, with the hardware and whether the hardware manufacturer will provide sufficient DSP power for higher sampling rates. What is clear is that Storm chooses not to do so (yet).Of course their chips are able to process 96KHz. This answer however is basically a non answer since it does not indicate if Storm actually does it.
Once you activate Dirac everything is resampled to 48KHz anyway.
Perhaps. Their justification might be that all the widely available immersive content (which is what their products are bought for) is limited to 24/48, anyway.I don't have any evidence, but I'm pretty sure that Storm could process Atmos + Dirac at 96kHz if they chose to.
It's just that they can use more effective filters if they process at 48kHz, and the benefits of doing that outweighs the disadvantages.
That's a reasonable rationale for moderately priced gear, which the Storm is not.Perhaps. Their justification might be that all the widely available immersive content (which is what their products are bought for) is limited to 24/48, anyway.
I am in complete agreement with you.If there's 96 and 192kHz material out there, and there's lots of it, in stereo and multi-channel formats, then I think an audio replay system should process it as such.
I'd like to hear the same from the other players in this market.(sampling rate is "up to 192kHz") This is often misunderstood. We don't do a great job explaining it. What we are referring to here is something that I believe is unique in the home theater sector: we adjust our digital signal processing to match the incoming data rate up to 192k, preserving the bandwidth that you may have paid good money for at HD Tracks or similar sites. By contrast, every other surround processor I know of resamples everything to 48 kHz, regardless of the incoming rate, since that is the only rate at which their DSP chips operate.
What Storm means by that is with their new update it’s possible to upsample the post DSP 48kHz audio up to 96kHz so the Ravenna network could be set to native 96kHz. This way they can boast 96kHz output capabilities. However it won’t improve sound quality. And more likely degrade it due to an additional SRC stage.How do you know if the Storm processor will process at sample rates above 48kHz? According to my information, "Post-Processed Outputs: Up to 32 channels, 48kHz." When I queried them about this, their response was "Our chips are capable of 96kHz processing, so a bypass is possible and likely in the future."
If so, that's disappointing.What Storm means by that is with their new update it’s possible to upsample the post DSP 48kHz audio up to 96kHz so the Ravenna network could be set to native 96kHz. This way they can boast 96kHz output capabilities. However it won’t improve sound quality. And more likely degrade it due to an additional SRC stage.
Then the Trinnov CI is for you. Also much cheaper if you don’t need all the channels.If so, that's disappointing.
I don't think that's what they mean at all. It would be pointless.What Storm means by that is with their new update it’s possible to upsample the post DSP 48kHz audio up to 96kHz so the Ravenna network could be set to native 96kHz.
I have a suspicion that Kal can figure that out for himself.Then the Trinnov CI is for you.
It’s what Storm says they did anyways. It’s not pointless, it’s so idiots can brag that their processor can output 96kHz. And it stops people on forums who don’t actually understand what they did from crying about 48kHz limitation.I don't think that's what they mean at all. It would be pointless.
For everyone's benefit, that's what Storm wrote in their blog here: The Journey To Full Digitalization. The context here is an AVP with digital audio output.It’s what Storm says they did anyways. It’s not pointless, it’s so idiots can brag that their processor can output 96kHz.
Both of those statements are explicitly clear that Storm use an output ASRC, post processing. That's regardless of whether it's an analogue or digital output.Both at input and output, our processors operate asynchronously, meaning they are not forced to follow the clock of the connected source or device. Instead, we reclock the signal internally with ultra-stable timing references. This means whether you play music at 44.1 kHz, a Blu-ray at 48 kHz, or high-resolution content at 192 kHz, StormAudio ensures perfect playback timing across all inputs and outputs. On Output, before signals are sent to DACs, amplifiers, or AoIP endpoints, they are re-clocked again.
However, Kal's reported statement above does not explicitly state that Storm achieve 96kHz output from up-conversion. That's only an interpretation of that statement. My interpretation is that can perform DSP at 96kHz. If that's true, I'm sure that Storm will continue to use both input and output ARSC, regardless. I could be wrong, but I don't think so. Time will tell.How do you know if the Storm processor will process at sample rates above 48kHz? According to my information, "Post-Processed Outputs: Up to 32 channels, 48kHz." When I queried them about this, their response was "Our chips are capable of 96kHz processing, so a bypass is possible and likely in the future."
This is a thread about the AudioControl processor, and I think this is the key question now. And it might not be answered for some time.Anyone know whether the APR 16 will internally resample everything to 48khz, as an AVR like a Denon 4800h would, or process sources at their native sample rate, like a Storm processor? With ARM DSP and x86 like processing power, it certainly should be able to.
