- Thread Starter
- #501
Cool, I hope that’s true, as I would then definitely have some interest!I believe they mentioned in their video last year that Auro was in the works
Would also be great if they made it Roon Ready like other Audio Control products. Even better if they can add Tidal, Quboz …. One can only hope.Cool, I hope that’s true, as I would then definitely have some interest!
Isn’t APR-16 slated to be substantially more expensive than DPR? Given that it really should be DPR with AES/EBU replaced by analog out.The APR-16 is limited to stereo in and out on Dante. As will the RCV-11.
The DPR-16 will have stereo in and 16 channel output.
What does the Storm do that the HTP1 cannot? They seem roughly equal to me, and I would even put the HTP1 above the Storm at least as far as the analog preamp section (which is just as good as any “audiophile” megabuck preamp, what’s audible anyway)Isn’t APR-16 slated to be substantially more expensive than DPR? Given that it really should be DPR with AES/EBU replaced by analog out.
I also watched the training video. Honestly the more I learn about these, the less interesting they seem.
Today among boxes using Dirac (I.e. excluding Trinnov and Lyngdorf) considering only audio functionality and audibly material audio performance factors, Storm is the clear gold standard and HTP-1 is a not-too-far-behind silver (clear gold for value, but silver excluding price).
As for the newer stuff right now on paper Tide-16 slots in at a fairly distant bronze, and this one is behind that, maybe tied and maybe ahead of Samsung A (Denon/Marantz) depending on the interplay between Dirac and PEQ. Samsung B (JBL Synthesis/Arcam) is TBD. Not sure why none of them can be bothered to beat or even meet the current category leaders with their brand new stuff.
More channels, active crossovers. Maybe the HDMI shit I couldn’t personally care less about too, but that’s not an audio feature or performance issue so out of the scope of this ranking.What does the Storm do that the HTP1 cannot? They seem roughly equal to me, and I would even put the HTP1 above the Storm at least as far as the analog preamp section (which is just as good as any “audiophile” megabuck preamp, what’s audible anyway)
Ah, indeed, I hadn’t thought about those additional benefits for more complicated systems, makes sense. But for us mere mortal “audiophiles” that happen to also do multichannel, I don’t think it gets better, especially given the value proposition vs the big guns.More channels, active crossovers.
But I take your point. For the overarching majority of users (your humble narrator included), since the introduction of Dirac ART, there really isn’t any gap between the two. But for the most complicated or largest systems, one has to recognize that StormAudio is still the leader.
For me AirPlay 2 and auto-off after no play for a while would make HTP-1 even betterAh, indeed, I hadn’t thought about those additional benefits for more complicated systems, makes sense. But for us mere mortal “audiophiles” that happen to also do multichannel, I don’t think it gets better, especially given the value proposition vs the big guns.
I also use Wiim Pro with optical into HTP1, control via Qobuz direct from my phone or tablet, works flawlessly. But agree those features would be nice on the HTP1. Maybe somedayFor me AirPlay 2 and auto-off after no play for a while would make HTP-1 even bettereven on the main system would be nice to be able to play music just by pressing AirPlay on a phone.
I solved those issues for the one in my office (running the desktop nearfield system) with a WiiM Pro — which obviously provides AirPlay 2 but also has auto off and a trigger out that works with HTP-1’s trigger in to provide auto-standby.
Struggling to understand your point. If (big if) the Tide16 and APR-16 perform to spec, they may be the best measuring AVPs out there. They have the most elegant design except perhaps the latest Trinnov which we haven’t seen. Most recent processors, etc.Isn’t APR-16 slated to be substantially more expensive than DPR? Given that it really should be DPR with AES/EBU replaced by analog out.
Agreed.Struggling to understand your point. If (big if) the Tide16 and APR-16 perform to spec, they may be the best measuring AVPs out there.
So effing what?Struggling to understand your point. If (big if) the Tide16 and APR-16 perform to spec, they may be the best measuring AVPs out there.
If you think they look nice, that’s fair.They have the most elegant design except perhaps the latest Trinnov which we haven’t seen. Most recent processors, etc.
So - Amir measured 103 / 104dB SINAD from the best AVPs, and are probably not audibly transparent, while the Tide16 and APR-16 are about 10dB better, and probably are.So effing what?
Note that I wrote “audibly material audio performance factors” above.
Since Amir measures just 2 channels in pure DAC mode, nobody knows how good or bad AVP's really are decoding multichannel with room correction enabled.So - Amir measured 103 / 104dB SINAD from the best AVPs, and are probably not audibly transparent, while the Tide16 and APR-16 are about 10dB better, and probably are.
I don't have any links, but I recall a few instances where he did measure the effect of engaging DSP, and sometimes that increased the noise floor slightly.Since Amir measures just 2 channels in pure DAC mode, nobody knows how good or bad AVP's really are decoding multichannel with room correction enabled.
Come to think of it, DRC normally needs 10dB headroom to apply boost at room mode cancellation frequencies.While it's probably fair to say that you don't need to go over 120dB SINAD in order to achieve transparency, you probably do need more than 105dB.
The testing was accurately level-matched, performed double-blind, and reported in recording magazine Sound on Sound.
Amir did some EQ measurements with the Topping D50 iii and got mixed results:Since Amir measures just 2 channels in pure DAC mode, nobody knows how good or bad AVP's really are decoding multichannel with room correction enabled.
www.audiosciencereview.com
So what then makes the Storm the gold medal winner, HTP-1 Silver, Marantz Bronze and Tide16/APR16 distant bronze? Is this about features, channels, value (performance/price) .., “On paper” I would rank them very differently. Trying to understand your logicI’ll take your word for it. Couldn’t care less. Bottom line is that none of the boxes under discussion have broken conversion stages so it really doesn’t matter.
BS — unless you can back that up with an actual controlled same/different listening test. Which you can’t, because your speculation has about as much merit as that someone who hears the difference between one “interconnect” and another. Really, SINAD cultists are in the same evolutionary pool as the wire mongers. And I also think it’s funny/sad when people obsess about the solved-by-the-1980s problem of digital audio conversion, but don’t even bother with the basic foundational stuff such as using the same three speakers in the same orientation at the same height for left center and right.
Again, I’m reminded of a discussion I had with an actual expert on digital audio, Dr. David A. Rich. He was disappointed that an expensive processor with superior features used very cheap DAC chips that was several steps lower than the best performance available at the time it was designed. (The company did spend money on top-tier analog audio parts.) But when I pressed him on it, he conceded that it wasn’t an audible difference. His point, which I think is fair, it was really that expensive audio equipment shouldn’t cheap out by using lower grade audio parts. None of the boxes I mentioned in my post above do that (today).
That’s not a useful test and doesn’t really tell us anything. Read how it was conducted rather than just marveling at the results that happily confirm your biases.
There was a presumption of difference rather than an effort to answer the threshold question of whether a difference exists or not. One should should read a little bit more critically and with understanding of the actual issues at play.
Please don't be rude, I know that's beneath you.BS — unless you can back that up with an actual controlled same/different listening test. .......
And I also think it’s funny/sad when people obsess about the solved-by-the-1980s problem of digital audio conversion, ........
Again, I’m reminded of a discussion I had with an actual expert on digital audio, Dr. David A. Rich. He was disappointed that an expensive processor with superior features used very cheap DAC chips......
That’s not a useful test and doesn’t really tell us anything. Read how it was conducted rather than just marvelling at the results that happily confirm your biases.
There was a presumption of difference rather than an effort to answer the threshold question of whether a difference exists or not........
Funny, that.Would Like To See
- Higher-spec DAC
