Are you sure about that? The APR-16 has seven HDMI inputs, which suggests that it has different digital hardware.The DPR-16 is the same digital hardware as the APR-16 has inside. 4 x HDMI input, 1 x HDMI eARC, + coaxial, optical & Dante inputs.
Yes. It has the same digital processing capabilities inside it.Are you sure about that? The APR-16 has seven HDMI inputs, which suggests that it has different digital hardware.
Is that what someone from AVPro told you?The i/o boards are all AVPro designed in house and will be using the same architecture and chips etc with the quantities of the driver chips being dictated by the i/o on each model in the range. There're no 3rd party HDMI boards as used elsewhere.
Yes, maybe, but that might be throwing away one of the great advantages of a digital processor - the ability to use good off-board D to A conversion.So for the pure digital processor...would something like https://www.bhphotovideo.com/c/product/1738071-REG/sonifex_avn_ao16_16_output_dante_interface.html work for converting the Dante to analog?
Yes, the stated specs on the Sonifex are quite a bit worse than that list. But PoE is a big plus from a simplicity standpoint!Yes, maybe, but that might be throwing away one of the great advantages of a digital processor - the ability to use good off-board D to A conversion.
The Sonifex might be great, but we don't know.
Better to use one of these, which do have good sonic provenance:
Yes, but then I couldn't decouple my computer equipment from my AV equipment. With Dante I could put the processor anywhere in the house (likely my networking/computer rack), and only have the (1 mu!) DAC in my AV rack.I've nothing against Sonifex, I think they're a great company (I have an AVN AES IO 8R) but I don't think DA conversion is their core competency.
Don't forget the Sonifex is worse than the APR-16 according to the specs, and that would be a convenient solution instead.
I doubt that POE will be any great advantage when you will need power for a power amp or active speaker anyway.
I'm assuming you've got a full set of existing power amps already hence the conversion required.Yes, the stated specs on the Sonifex are quite a bit worse than that list. But PoE is a big plus from a simplicity standpoint!
That is very true. I'm expecting to see most of the DPR-16 being installed in larger multiroom install racks away from the actual rooms they're processing for and the associated amps/active speakers.Yes, but then I couldn't decouple my computer equipment from my AV equipment. With Dante I could put the processor anywhere in the house (likely my networking/computer rack), and only have the (1 mu!) DAC in my AV rack.
I am guessing the AES3 outputs will be the closest to source, more than the analog. They didn't talk much about those in the video.There are lots of different AOIP schemes, and all have their foibles.
I think Dante is closest to being plug and play, but it's still nothing like AES3 for example. There's still work for the integrator to do.
For those that want to know about Dante, this video by hollywoodzuhause about the Trinnov Altitude CI is worth watching.
The Trinnov rep insists that analogue outputs are still the best, and Dante is there for convenience rather than quality. Go to 02:30.
A Dante network operates at the audio sample rate set by the Dante controller, so if the source runs at a different rate, it will have to be sample rate converted.
That much I already knew, but what's added here is that Dante ALWAYS performs SRC, suggesting that Dante is at the top of the audio clock hierarchy.
In conventional digital audio replay systems, the source is top of the hierarchy, and everything else follows that.
Not so with Dante it seems - the source has one clock, and Dante has another clock, and they're not synchronised.
The two digital domains have to be connected with an SRC, and some of them are good and some of them are bad.
Dante is digital, but to the best of my knowledge, it's definitely not bit-perfect to the source, and the conversion can cause degradation.
