Hi,
I'm in the process of modifying my audio & video setup.
I want to use my LG C1 TV as a monitor only. It would be hung on the wall, with no visible cables (all cables would go in the wall, and I want to keep them as few as possible).
All audio would be played by my NAD C3050.
The NAD and the TV are both e-ARC compatible, so I'd like to take advantage of that.
I have the following video sources:
- LG C1 TV
- TV Box
- Panasonic Blueray
- Sony Playstation
I need to have only 1 HDMI cable to go to the TV. So I guess I need some kind of active HDMI switch device, that can handle the various sources, and send the signal via just 1 cable to the TV.
It also needs to handle the e-ARC system, and the connection towards the NAD.
I am on the right track when I consider a device such as the Feintech AX340? And if I purchased it, I guess I'd connect the NAD to the "Soundbar e-ARC" HDMI plug.
I am right, or I am missing something?
I guess I could also imagine using the Toslink out connexion from the TV to go to the NAD for audio, but have no idea if that would be a better option than the e-ARC HDMI option.
Many thanks in advance!
- LG C1 TV
- TV Box
- Panasonic Blueray
- Sony Playstation
