solderdude
yes, well actually it is more designed to use flat pads and give them the proper contour around the ears.So it's the following part of the headphone (circled in red) that creates the angling?
So in your experience less angling than other angled headphones like say K702 / HD560s / HE4XX / HD800s? I suppose they all have different angling. I know you review a lot of headphones, do you measure the angle, where would you say this headphone fits in amoungst the angled headphones you've reviewed / owned / seen?yes, well actually it is more designed to use flat pads and give them the proper contour around the ears.
I am not sure if it can take 1W at 1kHZ, but I don't understand your reasoning. The spec is at 1K the headphones collapse in the sub bass region, as stated by Amir, but these "bad distortion Amir has shown" Have zero impact on a 1 kHz spec. Your baseline of 200 mW is for efficients headphones I think? It's the excursion that limits the headphone max SPL capability that's the only number that we should look at, 129 dB at 1K, the fact that you reach that at 1W or at 22V don't get into the equation.I've just checked three different online power calculators and they all give the same result that I included in my last post:
Headphone Power Calculator - Headphone & Earphone Audio & Reviews
How much power do your headphones need? Does your amp have enough power? Find out here with our handy calculator. Learn about voltage, current and power.www.hear.audio
iPhone & Cell Phone Repair Experts in Las Vegas
The #1 Rated Gadget Repair Shop in Southern Nevada serving Las Vegas and Henderson. Offering services on iPhones, iPads, Computers, Laptops, & Electronics. Buy, Sell, Trade.www.digizoid.com
https://www.****************/headphone-power-calculator/
And if I use the dB/mw setting then I get almost the same results with 1000mw input equating to 21.7V and 129dB. So their specs must be wrong surely, how can you put nearly 22V into this headphone and for it not to blow up, and also the 129dB is hugely loud in comparison to the bad distortion Amir has shown at the comparitively miniscule levels above 94dB.........how can this headphone just not blow up, surely their 1000mw maximum input at 1kHz must be incorrect?!
EDIT: most headphones top out at 200mw input power, but they're saying 1000mw for this headphone!?
Beside those three considerations ear distance, angle, elevated treble. Isn't it generally accepted as well than open back design is expected to have better spacial quality?Sennheiser also increased driver ear distance and space around the driver as well as wavefront.
IMO this is at least a big part of the strength of the HD800 spatial qualities.
I have the ATH-A700X which has the highest angle I have seen yet (about 20 degrees) where the HD800 is about 10 degrees.
One would expect the A700X to have better stereo imaging but to me it doesn't.
Also some elevated treble seems to help sometimes.
I agree that some of their "audiophile" series sometimes are tuned far from the generally accepted Harman curve. I would tent to think this is a conscious decision for some markets. But this is a headphone officially targeted at the pro market. It's the open back brother to the M-series. None of these have what I would call wonky response. They are not perfect, but are hugely popular, M-series HP are some of the most sold wired headphones worldwide (BT is on an all other level). They must be doing something right.They do seem to excel at wonky FR- I have quite a range of their 'phones and they are all over the place but with some EQ I do tend to enjoy. Not so much the 2000Z metal cups though- they are just boomy!
The reasoning is that 22V seems like a ridiculous amount to put into a headphone when DACS are outputting 2V at most except for balanced DACS, and high gain on headphone amplifiers might be like around 4 or 5 times amplification so really that's 8-10V coming into the headphone as an upper ceiling for most audiophile gear and that is itself already a boat load (too much) to be putting into almost any headphone - that's a long way off 22V. Also it doesn't sit as a practical notion when this headphone is badly distorting at 104dB already, let alone the supposed 129dB upper limit which would be the result of a 1000mw input. It's just soooo nonsensical on both those reasons that it makes me doubt their specs re the 1000mw input......and even if it is true it's unuseable for the reasons I mentioned.......just nonsensical in total, so that's my point, pretty clear reasoning to me, lol.I am not sure if it can take 1W at 1kHZ, but I don't understand your reasoning. The spec is at 1K the headphones collapse in the sub bass region, as stated by Amir, but these "bad distortion Amir has shown" Have zero impact on a 1 kHz spec. Your baseline of 200 mW is for efficients headphones I think? It's the excursion that limits the headphone max SPL capability that's the only number that we should look at, 129 dB at 1K, the fact that you reach that at 1W or at 22V don't get into the equation.
Yes, plenty of space inside the earcup so your ears don't touch & angling I agree are likely design cues for good soundstage, just I wondered if you knew where the R70x comes in vs some other angled headphones, but I see you've not reviewed the R70x. Judging from the comments of people with having problems fitting their ears in the pads then they're probably not gonna be any better (probably not as good as) than the HE4XX (angled pads) for soundstage if I were to hypothesize a comparison, as there's not a lot of room inside the HE4XX I own, and can normally feel some part of my ear touching lightly somewhere on the edges. HE4XX is ok for soundstage, not the best.....so I'd kinda expect this R70x to be no better. (Just trying to put it into perspective for myself.). Would have to listen to the R70x to know for sure, but that's what I'm expecting.Not only the angle differs but also the driver-ear distance and position as well as driver diameter.
And, most likely, also L-R driver matching in higher frequencies.
I have measured the angles of some drivers and list them in the reviews where I measured it. Not many degrees while with speakers the sound comes from about a 60 degree angle opposite the head and not just a few degrees. Add to that reflections from the room (speakers) and eyes giving the brain info as well.
IMO, to really get good pinna interaction you would have to angle substantially more than the few degrees by most headphones.
OK, but maybe we don't need that 129 dB, my point was just that doubting the validity of the spec because it won't happen in real world is an arbitrary statement. Again, why do you restate it's badly distorting at 104 dB when this specification is made by feeding a 1 kHz tone. I am not saying it SHOULD be measured at 1K, some don't mention that and it maybe could be a reason their number is lower. Do you see this headphone badly distorting at 104 dB SPL at 1 kHz? You are repeating what you said before, but you don't explain the reasoning, you are just repeating the same statement. Again this headphone is inefficient, but not more so that a HD650 or a DT990. So what you are saying that in most amplification gain structures, a 2V at 0 dBFS Dac can't bring this to 129 dB SPL, that is true, but why should we care about that, 129 dBSPL at 1k is unbearable. Yes those need a powerful amp, so do the comparable headphones I have mentioned. All that said is that you can feed it a 1 kHz tone at 22V and it won't break. It does not say nothing about doing so at other frequencies.The reasoning is that 22V seems like a ridiculous amount to put into a headphone when DACS are outputting 2V at most except for balanced DACS, and high gain on headphone amplifiers might be like around 4 or 5 times amplification so really that's 8-10V coming into the headphone as an upper ceiling for most audiophile gear and that is itself already a boat load (too much) to be putting into almost any headphone - that's a long way off 22V. Also it doesn't sit as a practical notion when this headphone is badly distorting at 104dB already, let alone the supposed 129dB upper limit which would be the result of a 1000mw input. It's just soooo nonsensical on both those reasons that it makes me doubt their specs re the 1000mw input......and even if it is true it's unuseable for the reasons I mentioned.......just nonsensical in total, so that's my point, pretty clear reasoning to me, lol.![]()
Oddly enough it does not seem any more difficult to drive than the AKG K7XX. This is on a Topping DX3 Pro+.
w seriesWhat is typical AT? To me they have models all across the board. some quite bassy, and some vey sharp.
Have you done any dissection to Denon/biodynamic drivers variants? I believe some modders said they are very capable drivers but they (the companies) didn't utilize them to the fullest extent.As an example I would take the HD800S and HD820. These two headphones, at least to me, have similar spatial qualities. There is slightly more treble in the HD800S though.
There are no headphones that are difficult to drive. It is just that some headphones require a higher voltage to drive them to louder listening levels.
The R70X is 104dB/V where the 7XX is 102dB/V.
This means the R70X is slightly more sensitive than the 7XX.
The R70X is equally sensitive as the HD650. This means that for a lot of people, listening at sensible levels, the 1V out of a phone is enough.
On top of that the efficiency of the R70X is higher as well as at the same SPL the R70X draws 10x less current. And amps perform better (lower distortion) on higher impedances.
That doesn't change the fact that the AT drivers can handle 1W (and thus even more peak level) and can be connected directly to speaker amp outputs. These drivers, just like the ones from Denon, some studio Sony's and most planars are hard to blow up electrically, certainly while wearing them. You'll destroy your ears before you blow up the driver.
Do you mean Foster's Biodynamic drivers that have been used as OEM by Denon in the past? BTW I am not moderator but I think that these kind of questions if it prolonged to a long discussion usually get's better served by a separate thread, from experience on how they like the review threads to be.Have you done any dissection to Denon/biodynamic drivers variants? I believe some modders said they are very capable drivers but they (the companies) didn't utilize them to the fullest extent.
I've always wondered what are some characteristics about them that the brands don't mention in the user manual. Stuff like actual distortion at FR/SPL are pretty much discovered by experienced members of the community, not by the manufacturers actually revealing them. It's kinda baffling.
I mean not only foster's drivers but the later drivers made by Denon themselves (Dx200 series), along with other biodynamic drivers like from EMU. I thought it's a small question that will get one quick answer so I think it doesn't warrant a thread, but I understand your point.Do you mean Foster's Biodynamic drivers that have been used as OEM by Denon in the past? BTW I am not moderator but I think that these kind of questions if it prolonged to a long discussion usually get's better served by a separate thread, from experience on how they like the review threads to be.
Modders sometimes make the weirdest and, more often than not, unsubstantiated claims about 'improved performance', not only about Foster driver based headphones.I believe some modders said they are very capable drivers but they (the companies) didn't utilize them to the fullest extent.
