johny_2000
ATH-ADX3000
These featherlight (257 g) audiophile headphones are hand-assembled at our facility in Machida, Tokyo, from components built in-house, and are rigorously tested before leaving the factory. They ar ...
ATH-ADX3000
Modelled after our flagship ATH-ADX5000 open-back headphones, the ATH-ADX3000 is designed to bring the natural Open-Air sound to a wider audience. These headphones feature 58 mm integrated driver units, which position the diaphragm, voice coil, baffle and magnet in a single unit, resulting in improved airflow and full-range audio reproduction. This creates an optimum structure, reducing unnecessary sound distortion. The result is full-range audio with natural bass, pure mid and high frequencies, and a precise, realistic soundstage.These featherlight (257 g) audiophile headphones are hand-assembled at our facility in Machida, Tokyo, from components built in-house, and are rigorously tested before leaving the factory. They are outfitted with replaceable velour earpads to ensure lasting comfort and come with a detachable 3.0 m (9.8') cable with A2DC (Audio Designed Detachable Coaxial) connectors at the headphones and a 6.3 mm (1/4") gold-plated stereo plug for connecting to devices.
As a leading innovator in transducer technology for over 60 years, Audio-Technica places special emphasis on driver design to achieve the optimal sound from each pair of headphones. The ATH-ADX3000’s integrated driver units are handmade in our Machida, Tokyo, facility to ensure the highest quality.
The ATH-ADX3000 open-back design allows unrestricted airflow that prevents any distortion or artificial enhancement to the sound. This results in a purity of sound with truly authentic sound staging and imaging
Specifications
Headphones | |
Type | Open air dynamic |
Driver Diameter | 58 mm |
Frequency Response | 5 to 45,000 Hz |
Maximum Input Power | 700 mW |
Sensitivity | 98 dB/mW |
Impedance | 50 ohms |
Weight | Approx. 257 g (9.1 oz), without cable |
Connector | A2DC connector jack |
Accessories Included | Detachable cable (3.0 m (9.8’) / 6.3 mm (1/4”) gold-plated stereo plug), Hard shell carry case |
Replacements/separately sold items | Replacement earpads, AT-B1XA/3.0 balanced cable |
