Audio Smile LBM Monitor Review
Rate this powered monitor:
    Votes: 1 0.5%
    Votes: 14 6.5%
    Votes: 98 45.6%
    Votes: 102 47.4%
This is a review, listening tests, EQ and detailed measurements of the Audio Smile Little British Monitor (LBM) Active Speaker (Monitor). It was sent to me by the company and costs £529.00 (VAT Excluded). Kit version is available for £349.00.
As a woodworker, I appreciate how the baltic birch plywood edges are used as a design element around the edges. I am not sure if it comes across but this is a tiny speaker! Low frequency is handled by a 3 inch driver. Dual class AB amplifiers are used for each channel:
Little British Monitor (LBM) Speaker Desktop power supply back panel Review.jpg
Dual analog inputs are provided together with bluetooth. A subwoofer output is provided as well (which I did not measure).
As you see power is external through a switching adapter.
Dual controls are provided for gain and "boundary." I found that it is best to set the gain to max as otherwise input can overload. Boundary at 12:00 o'clock gives you flat bass. Turn it one way or the other and you adjust the bass through a shelving filter.
The design is DSP optimized which we don't usually see in such low cost/small speaker (together with bi-amping).
Unusually, the port is on top!
Clever idea as then you don't have to worry about putting it flush to the wall.
Audio Smile Little British Monitor (LBM) Measurements
As usual, we start with our family of anechoic frequency response measurements:
Little British Monitor (LBM) Speaker Desktop Anechoic frequency response measurement.png
I was stunned at how flat the on axis response is! This is better than vast majority of speakers I test regardless of cost. There is just a tiny dip around 1.07 kHz. Directivity is smooth but it takes a step function around the same frequency. This impacts early window response together with predicted in-room:
Little British Monitor (LBM) Speaker Desktop early window Anechoic frequency response measurem...png
Little British Monitor (LBM) Speaker Desktop predicted in-room frequency response measurement.png
Sadly I forgot to measure the port response but here are the other two drivers:
Little British Monitor (LBM) Speaker Desktop early window driver frequency response measurement.png
We see that the break up in the woofer is nicely attenuated. Company has a nice sound sample comparison showing clean output of the port:
This is a small speaker so of course, can't get too loud but I was still impressed that it got up to 91 dBSPL:
Little British Monitor (LBM) Speaker Desktop THD distortion percentage ratio response measurem...png
Little British Monitor (LBM) Speaker Desktop THD distortion response measurement.png
There are internal limiters to keep the drivers from being damaged which may be responsible for much worse response at 96 dBSPL (not shown).
Horizontal directivity narrows with frequency:
Little British Monitor (LBM) Speaker Desktop horizontal beamwidth response measurement.png
Little British Monitor (LBM) Speaker Desktop horizontal directivity response measurement.png
Vertical response shows that you better listen at tweeter axis:
Little British Monitor (LBM) Speaker Desktop vertical directivity response measurement.png
Finally, here is the CSD (forgot to capture Step Response):
Little British Monitor (LBM) Speaker Desktop CSD waterfall response measurement.png
Audio Smile LBM Listening Tests and Equalization:
I should start by saying that my reference tracks are designed for larger speaker and in some cases, full range ones. So it is a bit unfair to throw them at the LBM. I did anyway as I don't want to lower my standard here and set wrong expectations.
Going into the listening tests, I expected superb fidelity but I got the opposite at first. The sound was dull and quite localized to the speaker. Then I realized that the LBM is fair bit shorter than the typical speaker in my near-field setup so I raised it to near ear height. Difference was dramatic with far better overall response and more spacious sound. Going through my track list, I would say about half sound excellent but the other did not. At first, I filled the on-axis dip. That was a toss up as far as improvement.
As it sometimes happens, I resorted to equalization using the predicted in-room response. There, we have flat bass and what we should have is one sloping down. At first, I corrected the response below 1 kHz but there still was not enough bass to satisfy me. Using a trick I have used before, I dialed in a bass boost to simulate a small subwoofer. This made a huge difference:
I couldn't believe that the LBM was able to handle that bass boost which was just a guess on my part. The sound now had warmth down to low frequencies. Combined with startling treble detail at times, made for a mostly excellent experience. There were of course tracks that could still use a much larger speaker but the promise was delivered.
EDIT: company is changing DSP filters to fill the on-axis response and give it a slight bass boost. See: https://www.audiosciencereview.com/...o-smile-lbm-monitor-review.66859/post-2431414
The LBM shows what happens when you put your mind towards highly optimizing a speaker design despite severe size and cost limitations. Audio Smile objectively gets there as far a frequency response, delivering some of the best I have ever measured. Off-axis is good but there is a step in there and flat response otherwise. A couple of filters fixed that although a subwoofer may be a more ideal setup.
Despite the speaker being built in UK, the cost is kept extremely low. Availability as a full kit at even lower price is nothing short of amazing.
I am going to recommend the Audio Smile Little British Monitor (LBM) for its excellent design and great value.
Not bad at all for a tiny speaker ! Nice class AB amp inside.
From inside :
LBM constrained layer damped (CLD) port cross-section view, consisting of two stiff outer skins containing an inner visoelastic film.
This technique is used by another brand whose name I don't remember, but it seems to be very effective against standing waves!
What is a Viscoelastic material?
Some other measurements :
Here is my take on the EQ.
Please report your findings, positive or negative!
For the score rational your journey starts here
Explanation for the sub score
The following EQs are “anechoic” EQs to get the speaker right before room integration.
If you able to implement these EQs you must add EQ at LF for room integration, that is usually not optional… see hints there.
The raw data with corrected ER and PIR:
Score no EQ: 5.5
With Sub: 8.3
Spinorama with no EQ:
  • Pretty good!
  • Slight dip in the 1 region
  • Good directivity
  • Good engineering
Directivity:
Better stay at tweeter height but as sensitive as other designs.
Horizontally, better toe-in the speakers by 10/15deg and have the axis crossing in front of the listening location, might help dosing the upper range. explanation here
EQ design:
I have generated two EQs. The APO config files are attached.
  • The first one, labelled, LW is targeted at making the LW flat
  • The second, labelled Score, starts with the first one and adds the score as an optimization variable.
  • The EQs are designed in the context of regular stereo use i.e. domestic environment, no warranty is provided for a near field use in a studio environment although the LW might be better suited for this purpose.
Score EQ LW: 6.1
with sub: 8.7
Score EQ Score: 6.3
with sub: 8.9
Code:
Little British Monitor LBM APO LW EQ 96000Hz
October242025-170345
Preamp: -3.00 dB
Filter 1: ON HPQ Fc 48.6 Hz Gain 0.00 dB Q 1.29
Filter 2: ON PK Fc 319.1 Hz Gain 1.32 dB Q 1.00
Filter 3: ON PK Fc 406.5 Hz Gain -1.10 dB Q 1.07
Filter 4: ON PK Fc 1010.2 Hz Gain 2.62 dB Q 2.91
Filter 5: ON PK Fc 2231.1 Hz Gain 0.59 dB Q 0.75
Filter 6: ON PK Fc 5378.4 Hz Gain -0.85 dB Q 5.99
Filter 7: ON PK Fc 10597.1 Hz Gain 1.73 dB Q 1.63
Little British Monitor LBM APO Score EQ 96000Hz
Preamp: -3.00 dB
Filter 1: ON HPQ Fc 47.6 Hz Gain 0.00 dB Q 1.29
Filter 2: ON PK Fc 266.6 Hz Gain 1.51 dB Q 1.02
Filter 3: ON PK Fc 392.2 Hz Gain -0.82 dB Q 0.72
Filter 4: ON PK Fc 1042.8 Hz Gain 1.98 dB Q 2.59
Filter 5: ON PK Fc 1533.1 Hz Gain 0.98 dB Q 0.57
Filter 6: ON PK Fc 5125.2 Hz Gain -0.81 dB Q 5.10
Filter 7: ON PK Fc 10561.1 Hz Gain 1.73 dB Q 2.50
Spinorama EQ LW
Spinorama EQ Score
Zoom PIR-LW-ON
Regression - Tonal
Radar no EQ vs EQ score
some improvements?
Bonus:
@amirm EQ Spinorama
Score no EQ: 5.5
With Sub: 8.3
Score EQ LW: 6.1
with sub: 8.7
Score EQ Score: 6.3
with sub: 8.9
Score EQ Amirm: 5.6
With Sub: 8.1
The rest of the plots is attached.
  • Little British Monitor LBM APO Score EQ 96000Hz.txt
  • Little British Monitor LBM APO LW EQ 96000Hz.txt
Impressive speaker indeed! I think it falls in the same category as the Adam D3V as it's similar in performance, size and price.
This is one of the nicest surprises I've had in an audio review for a very long time. I can't believe that it's so flat down to ~90 Hz and can still take boost below that. Just think what they could do with something a bit larger...
Thanks for the test Amir. It's fun when you test speaker gems like these. :D
They should definitely be an option for Brits because they are being built in UK. Support domestically made that is. Of course, a good option for non-British people too.
It will be a smile:
for them.:)
Edit:
More people giving them thumbs up:
AudioSmile put a tremendous amount of design work into perfecting the small desktop loudspeaker form factor, and I think it paid off. In my opinion, which makes the LBMs a bargain. Were I shopping in this segment, they would be my first choice, even if cost were no object.
There are also measurements that Audioholics did on the LBMs reported in the article them if you want to compare with Amirs:
Fits very well for my needs.
Thanks a lot for this appreciated review, @amirm !
What a gorgeous little speaker stand! Scroll down at <https://www.audiosmile.com/lbm>.
From inside :
Good points. Add:
To the vendor @AudioSmile_UK
In the insulation guide:
There may be inexpensive opportunities for improvement of resonance.
Above the crossover point, it appears the tweeter is enclosed, as it should be. Maybe that enclosure is not rigid enough or have damping lining. Below the crossover frequency, the pictured egg crate foam, if that is what they supply, may not be the proper material. Those metal square tubes supporting the LF driver should be checked for resonances.
Maybe there is a MBF?
Always nice to see Speaker reviews (DACs are getting boring), and especially from new companies.
Looks like a cracking little speaker, really very nice. I'm not sure if I would have been able to figure out the EQ required to get the best out of it - so your review is massively helpful - so marked it down slightly for that.
Good reminder of the importance of height in speaker positioning too.
Nice to see an optional, very good looking desktop stand is available. Called "Little feet"".
Very interesting product. I was thinking of buying it a couple of years ago and the forgot. Two things
1) am I being dumb but I cant see why it doesn't have a conventional digital input as well as bluetooth, given that it obviously has a dac. Surely some people would want to connect to a streamer or something (a desktop pc ?) without bluetooth;
2) I can't see why @amirm needed to produce the bass boost in dsp to get a downward sloping response- isn't that what the boundary control is for (as per first post)- does it not work?
Just a quick note; the quoted price of £529 in the review doesn’t include VAT. For British consumers, that brings the actual cost of a pair to £634.80 including VAT, which is roughly US $846 at current exchange rates. Worth keeping in mind when comparing prices.
