StillMotion
- Joined
- Jan 20, 2026
- Messages
- 2
- Likes
- 0
Current Build:
9800 X3D
64 gigs 6000 MHz Ram EXPO
4070 TI
AsRock b850 steel legend wifi
Meshify C
I’m getting audio popping on sudden sounds (sometimes) or when sounds suddenly stop (pausing a video, muting, jump cuts, audio censoring for curse words, etc.).
I’m on Windows 11. I’ve tried different Realtek drivers (default Windows, Realtek website, motherboard forum versions, and OEM versions). This happened on a previous build too, but it was completely eliminated by using a USB DAC dongle.
On this new build, I’ve basically rebuilt the computer completely with new parts — the only thing that’s the same is the case. I also tried running just the motherboard/CPU/cooler outside the case with a fresh Windows install and it still happened.
Its happened for a while before, then stopped for quite some time (about 2 years), and recently came back on the same drivers. I’ve disabled auto driver updates via gpedit.
It happens with different headsets and on different ports.
Would investing in a proper DAC using S/PDIF as the connect bypass this? I don't know if the USB DAC not working means nothing else will either.
Build history:
9700k + Z390 Gaming X Rev 1 -> problem solved with Apple USB DAC dongle.
12700k + ASUS TUF/Prime A (tried like 5 different brand new ones, Prime and another series) -> problem persisted no matter what I did. Went mostly away on its own after a long time.
9800X3D + ASRock B50 Steel Legend Wifi -> didn’t show up until now.
Troubleshooting steps:
Tried Different outlets and power networks
Disabled fast boot
Disabled hibernation
Turned on and off XMP/EXPO
Disabled all power management options in BIOS (ASM, PCI-E Link Power Management)
Disabled HD audio in bios
Changed PCI-E slot speeds to gen 5 and 4 for GPU and SSD, respectively.
Completely reinstalled everything audio related, after completely cleaning driver store
Tried Audio Drivers from ASUS ROG Forum
Updated PD Firmware to version 007
Updated Intel Serial IO Driver and all applicable from support website, even used Armory Crate for updating everything
Disabled all sound processing from DTS and Realtek in Device manager
Disabled Wifi/Bluetooth
Messed with sound bits and sample rate/format
Tried USB Dac
Tried Generic Drivers
Reinstalled fresh to windows 11 from 10 (where the issue started)
Return motherboard for another of the same model and changed models (Previous motherboards were Z690 TUF Gaming D4 Wifi)
Updated Bios to latest
Tested in Safe Mode
Tried All Ports (USB and 3.5mm)
Installed Linux on USB and booted from that
9800 X3D
4070 TI
Meshify C
Build history:
Disabled fast boot
Tried USB Dac
Tested in Safe Mode
