- Joined
- May 31, 2020
- Messages
- 1,082
- Likes
- 1,996
Point is that a neutral speaker is always best. Do you want a speaker that only sounds good with certain records? With coloration of the sound that certainly is not anywhere close to “true to source”?
If you want a pair of similar speakers like those audionote, old Kef are indeed sounding similar, but better. And they are all over the place and relative cheap. I got a pair of Kef Chorales here now to restore that were free given. I need to restore the crossover (will cost me about 25€ to do both new) and some minor cosmetic fixes. I'm sure i can bring them back for about 50€ and they can be sold/bought for 3-400€ in good shape.
Or get the original Snell or Dynaco A25 speakers, they are also easy to find and much cheaper and better sounding (but similar sound signature). A lot of brands are just going back to those old designs and repackage it for a ridiculous ammount of money, while the originals are better and still there, and very often there are diy clones/variations of it that are way better than those overpriced snake oil speakers. Devore is an other company that does that, in a similar way as Audio Note and with similar inspirations (Dynaco A25 and A35) that they repackage in a fancy overpriced way.
Then i prefer something like Harbeth. They also lean on the (BBC) past, but at least their speakers are well build and do what the company says they do. And they don't support snake oil amps or cables or so, they recommend a very mainstream (relative cheap) integrated amps for theirs. It's not ASR standard fit, but it's not snake oil neighter and their spreakers work like intended with their "signature sound".
Speaking of the t27 tweeter. My friend, who usually organizes a vintage DIY hifi fair, has over the years collected a hell of a lot of old KEF drivers. It was kind of his thing to build KEF clones, even LS3/5A copies. And why not, a hobby as good as any.If I'm not mistaken, in the period that Kef had the Chorales, they bought this very expensive computer, which they first used to design the 104, the first 'Reference' and the Correli, the (or a) successor of the Chorale, was (much) better. @DSJR mentioned something like this, I think in this thread, months ago, maybe he could clarify it. I wouldn't be surprised if you could make the chorale better by redesigning the crossover so that it's more like that of the corelli, Calinda or the 104(aB), though those have different woofers. Better, but less Audio note-like I guess. My experience with the chorale was that it had some excess mids and worse (upper) treble than the 104aB which I've had too and the diy cs1 (which I still have) while using the same tweeters, the t27, which are now replicated, to re-sell the bbc ls3-5a concept, while nowaday tweeters (etc) are so much better...
audiosciencereview.com
I agree with you that SB26ADC is: On it's own or in a waveguide this is a gem.I prefer the H087 tweeter above the T27 anyway, if you talk about 70's Seas tweeters, it's a much better one in my personal opinion. But many seems to like that old T27 and pay sometimes crazy prices for it. I'm just restoring that old Kef Chorale, i won't use it, it will go again after restauration. Plan B (if their was a bigger problem than the crossover) was to recup the still working drivers for selling them, as they go for silly prices (even the B200 woofer).
And i agree that modern tweeters are often much better, my favorite dome tweeter is a 50€ modern alu tweeter, the SB26ADC, that is a lot better than both the T27 and the H087 or all vintage tweeters i know. It's cheaper, easier to find and a lot more controlled untill about 1200Hz (measured by several people) than those old ones. On it's own or in a waveguide this is a gem.
Partly sighted bias maybe? Such subtle looking small membranes.. But if you 'know' a speaker longer, it also works partly the other way round. In the case of one of the better designs with the t27, that can sound very well, their looks can get a certain 'degree of magic'. But if you then hear good modern speakers, the highs are more refined, not like 'tearing paper' anymore.But many seems to like that old T27 and pay sometimes crazy prices for it
What is so nice about good, neutral speakers, is that you can forget about them. Just listen to music. Most recordings, broadcasts will sound just fine. Especially when you care about the sound, it's such a good thing if you can 'forget your gear' ass well (again). Instead of endless tweaking and doubting or even buy snake oil.Point is that a neutral speaker is always best. Do you want a speaker that only sounds good with certain records? With coloration of the sound that certainly is not anywhere close to “true to source”?
for a lot of people good coloured speakers do the same. But those are mostly not audiophile speakers advertised by snake oil mags. They are very often classic vintage speakers like the Kef Chorale or the Dynaco A25, that were for their time the best arround. The trick is to find the models that are not overhyped and so sold for inflated prices. But the top of those are almost all overhyped and so way to expensive like many of the classics of Altec, JBL and Tannoy. But outside those brands, there are tons of others that are very easy to listen to, but don't fit the ASR standards at all. Many speakers of Philips, Kef, Dynaco, Goodman and Warfdale were like that (and there is more).What is so nice about good, neutral speakers, is that you can forget about them. Just listen to music. Most recordings, broadcasts will sound just fine. Especially when you care about the sound, it's such a good thing if you can 'forget your gear' ass well (again). Instead of endless tweaking and doubting or even buy snake oil.
No not the negative feedback is bad trope againany amp can produce odd harmonics SS or tube ,thing is that the levels can be inaudible low the THD spectra can look anyway it wants it' still inaudible , apart from AN's terrible electronics with very high amounts of possibly clearly audible distortion and noise . On to the ignore list you go ? Why are you on this forum go post astrology on an astronomy fora ?
Inherent to SET tube designs is to have dominant even harmonics, inherent to SS designs is to have dominant odd harmonics.
It just looks logical to me, but indeed, there is no proof. Probably there are things that play a role that are not investigated yet, like 'differences in individual psychoacoustics'. But with ones hearing, one hears reality too..
www.audiosciencereview.com
That's allright for them of course, but couldn't it be that there are more people that listen to a great variety of music, radio programms, etc. and that the average sound of all that would be about neutral on about neutral speakers? And when producers and engineers try to make a good production, don't they on average aim at neutral sound on neutral speakers? So then neutrality would mean biggest chance on right tonality, not extremely strict, but still..As I pointed out before, that is the case, whether you choose neutral speakers or coloured speakers.
If you choose neutral speakers, they are going to vividly show you the differences in recording quality, and the variation and recording quality means that “ certain records sound good and others do not.”
So it’s not really a problem you get around choosing neutral gear.
That also describes the experience of people with more coloured gear as well. in fact, some people find that certain coloured gear makes more of the recordings they like sound listenable and pleasant.
I haven't met thousands of people who use "colored" gear, but I've seen a good few. Some kept their "colored" gear a shorter period of time, and some kept it a longer period of time. In the end, most played the change-up game, buying what they thought was fabulous, and then tiring of it some time later.
Do you know which people were the exceptions? It was people who were alive and using tube gear in the '50s, '60s and '70s. In those years, both low-level and high-level circuits were designed and implemented with neutrality as the goal.
Nowadays, precious little tube gear is designed and implemented with neutrality as the goal ... if any.
Jim
So, I'll ask again since you are just repeating the same inaccurate claims.
Do you have any kind of technical background that you are speaking from, or are you just regurgitating the propaganda you've picked up along the way?
Not much techincal knowledge is needed...
Now, bench testing the amp is done with a sine wave,
And, btw, it's well established fact, done by science known by "listening", that amps with very low distortion and hyper detailed often sound lifeless and boring. And there's an actual scientific explanation for that.
... it cannot even tell if something sucks, even less if something sounds great.
I find the topic of this thread very suitable to go off topic.I promise no more OT from me in this thread. In and of itself, I like threads that spread in all sorts of directions, but maybe it's not everyone's cup of tea?.![]()
My class-D amp sounds lifeless and boring indeed, when it amplifies lifeless and boring music, but when that occasionaly happens, I just change the station. And what's so nice, every watt it consumes more than about 18 w, is converted in music, voices.boring
