Buy some old Snells.
El84 or 34 tube amp, passive pre and the high impedance 1970s speaker of your choice. If you want to get really close, get some old Snells.How exactly and what would that entail?
First, to reiterate, I find audio notes speakers get ridiculously expensive for “ what they are” in my own price performance criteria. But I did seriously audition a pair that I would have bought had I liked them enough (AN-E model if I remember correctly).
I personally I am super picky about which loudspeakers compel me want to sit and listen for long periods of time. It’s actually pretty rare for me. So when I find a speaker that lights my fire, if it’s within my budget, I don’t care too much that some other audiophiles will say “ this can be done cheaper, it’s overpriced.” I’m happy to let the speaker designers spend lots of time designing a loudspeaker that turns out to be exactly what I want. The materials may not be super expensive, but they spent a long time dialling the sound in and hit on exactly what I’m looking for, so I’m willing to pay for that.
I’ve often seen people say “ this speaker isn’t worth it” often sighting material costs or whatever. I’ve seen it even said about speaker brands I own, Joseph audio, or about other brands that I really enjoyed, for instance Devore O/96 speakers “ it’s just a 10 inch woofer and a tweeter in a wide box!”
Fine, but they are normally isn’t replicas of the very same speakers out there for sale at half the price or whatever. That seems to just leave it to “ somebody could build something like this much cheaper .”
But I have no interest whatsoever putting time into learning speaking design and making my own speakers. So the advantage of DIYing some cheaper version hold no appeal to me. I’d rather buy a finished product that exactly suits my needs.
And those saying “ anyone can put together the speakers you are talking about” I would say “ fine go ahead, if you can build an exact replica of this loudspeaker, that sounds precisely the same, with just as high-quality fit and finish, and sell it to me for half the price, go for it. And I also hope that if you set up a company to do this, it will remain viable and not close after a year, leaving me out to lunch if I need a part or service.”
You can buy some smart furniture with the ( enter absurdly high figure) you save,
PQ just copied the designs, as Mart says probably made them worse as he copied the Kondo stuff, it’s just a hugely expensive vintage sound, the only good thing is the veneer.“ why not get something that doesn’t sound the same or look the same, and spend money elsewhere?”
That’s a “ solution “ for someone with different priorities.
This is what I was getting at.
I no doubt overpaid, by some peoples estimates here, for some of my loudspeakers.
But since they are precisely the combo of aesthetics, level of craftsmanship/fit and finish combined with the exact sound I love, I am more satisfied with them than if I’d cheaped out.
If it makes you happy then what the hell, just get on with listening to the tunes and enjoy.But since they are precisely the combo of aesthetics, level of craftsmanship/fit and finish combined with the exact sound I love, I am more satisfied with them than if I’d cheaped out
1) You have admitted many times to liking a "sound" that is, by your account, not accurate. What do you (personally) have against accurate (or neutral) sound?
2) Many members here have similar likes as yours, but they don't mention their likes and dislikes to nearly the extent that you do.
To many members here, your aggressive public advocacy amounts to proselytism. Why are you so aggressive in your public advocacy?
You don't have to keep justifying it mate
folks on here will always disagree with your choices
I don't think you've ever tried to argue that these are neutral or SOTA by any modern measurements. You've just said they make you happy and that you enjoy them...
But that's the opposite of what an Audio note lover wantsIncredibly good sound for the small amount of money.![]()
Just more examples of Matt's apologetic attitude toward the snake-oil marketers of over priced, poor performing products.I can see why you might have that impression. But in fact what I’ve actually said many times is that I like the fact that loud speakers sound different, and so I like a variety of presentations. That includes neutral. I’ve worked with neutral equipment, and I have owned neutral equipment, including loudspeakers and enjoyed them.
Nope, justifying the worthiness of gear based on personal criteria is exactly what this forum does not do (I think). It justifies worthiness based on objective measurements.I think it’s worth pointing out that “ justifying” the worthiness or not of gear, usually by appeal to personal criteria, is what people do here, as in any forum.
So you like them, you advocate for them, just not enough to part with your own cash?Just to be clear: I don’t own audionote speakers.
So you like them,
One way of looking at it.But that's the opposite of what an Audio note lover wants![]()
And how about the Mofi source point 8 (inch)? As far as I know a well measuring, highly regarded speaker. Two way coaxial with rather large midwoofer=tweeter waveguide so that a smaller amplitude is needed for a given output. Rather expensive, too, for normal people.One way of looking at it.
In any case, if you google: Studio monitors with 8 inch bass, a lot of suggestions appear, so the two-way combination with 8 bass drivers seems to have its demand in that market. The diameter of the bass driver is the same, but they differ a lot from the old "classic" passive two-way speakers discussed in this thread. It in that these modern active studio monitor/speakers often have WG tweeters and probably FR fixed via DSP.
Just to name a few active ones that came up when I googled:
JBL 308P MKII,RCF Ayra Pro8, ADAM Audio T8V, Kali Audio LP-8 2nd Wave, Mackie MR824, KRK Rokit RP8 G5, Yamaha HS 8. Incidentally, those mentioned are within more or less the same price range. It seems like a tough competition.
Another option in that line is the HSU Research CCB-8.And how about the Mofi source point 8 (inch)? As far as I know a well measuring, highly regarded speaker. Two way coaxial with rather large midwoofer=tweeter waveguide so that a smaller amplitude is needed for a given output. Rather expensive, too, for normal people.
It's night here, I'm going offline.
Peace
www.audiosciencereview.com
I thought he bought the old Peter Snell designs, which he liked, when Peter died and Kevin Voeks took over as the designer and started making a different style of speaker altogether.PQ just copied the designs, as Mart says probably made them worse as he copied the Kondo stuff, it’s just a hugely expensive vintage sound, the only good thing is the veneer.
Which is kind of apt.
Another example, like Ascend acoustics, of a very nice American brand that doesn't export, at least to Europe.Another option in that line is the HSU Research CCB-8.
Another 8" coax like the Mofi but at a much lower price $389 each.
As is typical of Dr Hsu, he leads the pack in offering very high value products.
The speaker was measured and reviewed by James Larson at Audioholics with much the same
results that Amir found from the HB-1 MK2 here, a recommended product.
I kept a 5.2 system based on the HB-1 here for a number of years before finding something I wanted to spend
considerably more money on, they are very hard to beat.
Hsu Research CCB-8 Bookshelf Speaker Review
The CCB-8 is an audacious new speaker featuring an 8" woofer utilized as a waveguide for a center-mounted tweeter. Read our review of the Hsu Research CCB-8 bookshelf speakers for our impressions.www.audioholics.com
HSU HB-1 MK2 Review (Horn Speaker)
This is a review and detailed measurements of the HSU HB-1 MK 2 bookshelf speaker. It is on kind loan from a member and costs US $169 each as of this writing (normal price $199). I can't say I am a fan of the industrial looking horn but otherwise, the HB-1 looks fine: As you see, it uses a...www.audiosciencereview.com
