Audio Magic Ultimate Premier Beeswax SHD Fuse
That’s extra $ fighting with a large owl poking its ears :)
Sure, but it's worth it to get the very best audio performance.
Animal rights groups can have opinions of me torturing dozens of owls in cages with jazz at the pawnshop :)
Barred owls love being scratched behind the ears. They'll let you pick out the wax then ;)
Every single kind of con man nonsense product on the planet is sold with the same marvelous return policy, for a good reason. It's the con man who has everything to win and nothing to loose. It's the worst possible justification for jumping head first into a scam, but people can't help themselve
I've read all the responses to this thread. I find reading the first line of something and respond with unkind words a normal response to people that think they are better, smarter, ruder, ignorant, and most of all jealous.
Bad manners and calling people name is a lack of education not an abundance of it.
I read a few people comment about "listening to fuses", BUT left out the other 99% of what "I've seen", "heard" and tested. Then have the stones to speak about
CONS.
If I was running a CON (hypothetical) in any way, I think the point is, keep the fuse, keep the money and getting someone to pay for something they didn't receive and being happy about it.
Now that is a real CON.
I see a lot of reasons WHY a fancy fuse would work. Insults in leu of proof of why they don't work is not evidence. As I said in my post "A FUSE IN THE SOUND PATH"
will make a difference in what you hear. I referenced Infinity speakers for the THIRD time. RS2b is ONE of several that did this.
Do you need pics and schematics? LOOK THEM UP!!!
Have any of the folks here had issues with fuses and speakers? If you haven't you haven't owned a LOT of the older speakers that are still used today.
I don't care if new speakers don't have fuses in the path, older ones did, and it has a serious effect on sound quality.
If it is science we are looking to, then let it explain why things work like a MODIFIED thing called a fuse. They have used dampened fuses for a long
time in the industrial world. They were in the automotive competition sound off for 45 years. ACME!!
FANCY FUSES did not come from the audio world they came from the industrial world along with dampened fuse holders and contact enhancers.
Argue with the ENGINEERS that made them not the stereo guy that's too cheap or smart to try one. Do they work on an AC circuit. YES!! They reduce the
recovery time on the initial start up of "TUBE GEAR" for ONE!! The fuse gets HOT it HEAVES, IT MOVES, IT SHAKES. Sometimes the fuse never really
cools down. THAT IS WHAT I WANT!!! A ****** little wire shaking around. What would an engineer think of that? The same thing I do. I don't like it.
BUT an engineer would say it's ok, it's GOOD, it's ready for launch. HELL NO...
I explained that ALL TIER 4 engines for off road, Industrial (stationary) use, use satellite tracking for potential breakdowns on critical jobs. Hospitals
bunkers, pumping stations. THAT STUFF!!!! They use FANCY DAMPENED FUSES for the uninterrupted PS. to the OB2 and cann buss for the other
computers. PAY ATTENTION!!!!!
Honestly, do I need to explain a super heated thin, hair size wire supplying a room heater called a tube amps power. REMOVE IT. Screw the fuse.
Screw the amp, screw anyone that thinks that little F_C*ING wire is not a problem in every single way possible.
They fail, they are there to piss me off. The weakest part of the whole AC circuit and people are arguing about how UN important that fuse is.
My dog and rabbit are scratching their head too. They are giving me the WTF look.
Time to feed the chickens and a new fly in of turkeys. Turkey calls in the morning, wonderfull.
Yes true, true, true! Very true! If you put them in the loudspeaker wires. That is well known. Point is there is no need for a fuse in the sound path with properly designed audio equipment! Fuses are safety devices to prevent fire in case of severe malfunction. Not audio "tuning" devices.
CONS.
One of the biggest benefits of fuses is their capability of preventing fires in electrical equipment that malfunctions due to failure or misuse.
CONS.
Your stupidity is going to kill some one!
Opinions of audio perception are fed through and modified by belief filters. If you think a particular fuse sounds better than another fuse model, then for you it does, even if the voltages presented to the speaker terminals through the two fuses are identical.
Yes. This is one of the major purposes of this site, to highlight how susceptible our hearing is to other influences besides the actual sound waves. I have written before, ASR is concerned with the sound that reaches your ears. What happens between the sound that reaches your ears and your brain is your problem.
I'm not a fuse expert. I did spend around 25 bucks for a fuse once for my phono pre only to find out it had two in it. I went ahead and installed the hifi fuse with the other cheapie no hifi one and immediately blew my high dollar fuse on startup. That's my history. Oh except I've used them in speaker circuits before. The venerable and oft discussed CV D9 speakers with all of their pounding bass had a 2.5 amp slo blow fuse in line with the input. Sounded pretty good with that in there I'll have to say.
One thing I do know for sure is there are multiple groups of extremely gullible folks in this world and audio nuts are right up there with some of the best.
A fool and his money are soon parted?
If I'm lucky it will be just a few people. Again with the names. Are you a F___ing idiot? I'm using this term because it is
obviously a BIRTH DEFECT. Please with all your wisdom. Explain how it will kill someone. IT CAN'T!! The protection for the USER
is not the fuse in the equipment. Anyone that thinks a stick fuse or circuit breaker in any piece of equipment is for human safety
needs to go back to SCHOOL.
The law requires NO such fuse. A fast acting BREAKER is required at the receptacle and then again at the main IF there is water
involved.
So we are clear distilled water is NOT CONDUCTIVE. That is why it is used in dry storage of wet cell batteries.
50 years is not uncommon for soft top batteries.
Reciprocating or electric motors in some cases require a JAM breaker. It's still for the equipment health, someone's
arm stopping the machine was an afterthought when they stuck their arm in the garbage disposal and it had a thermal breaker.
We learn! Well some of us do!!
So who is stupid? The fact that YOU removed the crappy receptacle breakers at YOUR house or you haven't been SAFE enough
to install one to begin with.
Screw the equipment for stereo listening they are toys in a grown up world. They are for FUN. Be SAFE driving your CAR. LOL
You really want to be safe move your cell phone to the other room, quit playing video games and go for a walk with a vest on.
In your case a helmet too.
As for FANCY FUSES. They were never engineered for the stereo world. The stereo world just ran with the BS and found
benefits from doing it. The price tag is for the sucker that falls for "THE FUSE" instead of a piece of solid stock and refuse
to understand the benefit of doing it. 10 fingers and 10 toes, what do you have after 49 years of being a master mechanic?
Smart ass uneducated responses. Don't tell me you read a book, TWICE. or you are studied to be an engineer but wound
up working at probation.
Did it type that?
involved.
Did it type that?
Damn, you need to take your medication.
It is A benefit it is not the soul benefit nor has it been used for that reason in stereo gear. It is to protect the GEAR..
EX: a vacuum cleaner may or may not have a thermal breaker. A sewing machine, a light fixture, a TV, an electric weed eater,
a sex toy? Unless you added the fuse/breaker how is a fuse going to prevent a fire? The light BULB explodes what good is a
fuse. LOL The breaker in the wall or at the receptacle prevents FIRES.
Have you EVER worked on a job site? They have 100ft 120vac extensions
cable everywhere. Stick fuses are for safety? You must be kidding. Only equipment.
Some job sites require inline breakers.
If you're working refineries, drilling platforms or around flammable or combustible materials, sparkless lighting and all that JAZZ
is kind of a must. Can't even run non tubed fuses in a refinery. They are an ignition source when they blow. Stick fuses are safe.
Sure they are. Old Lucus fuses and a VW, what a nightmare.
Isn't there is an important revelation, hidden within the product description?
Beeswax is conductive!
(Presumably, this is due to the nano-treatment... which might also explain why the fuse became directional)
Sorry if this has been discussed already
It hasn't been... for a good reason. It's complete nonsense.
You can't make a p–n junction out of beeswax through "nano-treatment". Please stop trying to find hidden revelations in that buzzword fueled drivel.
At what point have I been calling people names? o_O
Absolutely. If a fuse is placed in a signal path, it will function as a load dependent resistor. Nothing mysterious about that. The fuse doesn't have to be "fancy", just well suited for the specific design. Simple electrical and mechanical parameters. None of that quantum/nano/precious metals gobbledygook.
You can't ignore the fact that people put those "audiophile" fuses in switch-mode power supplies and hear all kinds of heavenly changes to the sound. That's just bonkers, no matter how you look at it.
Goodness me, I haven't lost my beans old boy:)
I was trying to make a joke - albeit, not a very successful one I admit!
Regards
