Audio Magic Ultimate Premier Beeswax SHD Fuse
That’s why it was added because they work ,what you don’t understand you ignore .if you have not tried them then you speak out of ignorance. Try them ,they have a trial period Nothing to loose and Everything
To gain !!
There is nothing to try. I don't need to stand in the middle of the road to know that I will be severely injured or even killed by the oncoming traffic. Similarly for something that should exclusively be used for protection of electronic devices ONLY and usually in the primary circuit of something that drives a peak rectification circuit that has absolutely no bearing on sound quality there is no need to try it either. The effect you think you are hearing is nothing more than a placebo effect and this can readily be backed up by some decent measurements or proper blind testing. All you are doing is just helping to buy Ted Denney's next Ferrari. Wake up to yourself :(
Most people have no idea how little time the AC fuse conducts current in a power supply.
Worse still the current drawn by the mains is anything but sinusoidal and is horribly distorted and certainly unaffected by changing fuses !! What problem are they trying to solve ? If it was power factor correction yes they may have a claim for noise reduction but have a snowflakes chance in hell of achieving that with a fuse change ! Still they should feel good about helping Ted Denny buy his next Ferrari. :D LOL
:facepalm:
JSmith
It's just a HRC fuse with a fancy label on it. Why are people so gullible ? :D LOL
The fuse that beats all other fuses ;)
Frequently asked questions.​
Q: Are fuses directional?
A: Yes, fuses are directional. Electricity should flow from the left to the right when you view the fuse. If you do not know the direction of flow you should listen to the fuse inserted in both directions. One direction will sound more detailed. This is the correct way.
Q: Do fuses have a burn in period?
A: Yes, most products have a settling in period. The first 200-300 hours of use are the most crucial.
Q: Where should I use my Master fuse(s)?
A: To get the most out of our Master Fuses, we suggest starting with one or two fuses in most systems, and possibly more for highly resolving systems. There is no "wrong" component to start with; however, we typically recommend starting "upstream," at the beginning of your signal source (Music Streamer, CD Player, Turntable, Reel to Reel, etc.). From there, we suggest moving on to your digital-to-analog converter or phonostage (if you use one), followed by your preamplifier and then your power amplifier. If you have multiple sources, upgrading the fuse in your preamplifier first can improve the performance of all of your sources."
I REALLY don't understand why you're surprised with stuff like this.
I mean,come on:
(I choose a mild one,there are others 5-10 times it's price)
I mean,come on:
What happens when the $600 fuse blows because of a 5 cent rectifier diode that shorts out ?? Do you get another fuse under warranty if you return the blown one ?? :D LOL
I mean,come on:
The difference is, no one believes that cigar cutter makes your cigar smoke better etc. It's simply jewelry.
I have the bad luck to have a cigar-aficionado friend (I like them too but sensibly).
You wouldn't want to know the debates about the interaction of different metals with the cigar's moisture :facepalm:.
Isn't there is an important revelation, hidden within the product description?
Beeswax is conductive!
(Presumably, this is due to the nano-treatment... which might also explain why the fuse became directional)
Oh dear God - is there no activity that the woo doesn't infect?
Nanoo treatment? Alien tech, I guess?
I think I have to to make earwax fuses . Very exclusive.
I will grow the earwax while listening to select audiophile chestnuts of your choosing like jazz at the pawnshop.
If you want fuses for mono blocks I will make sure there is a right and left fuse with wax from the right and left ear respectively .
;):facepalm:
;):facepalm:
Since owls have better hearing than humans, I suggest owl earwax.
