Audio interface for home theater room measurements and calibration with M23R mic
deep bass
Hello everyone.
I have an Earthworks M23R microphone.
Iam planning to buy audio interface for one microphone only
it requires Phantom 48V ( It supplies 10mA of power to the mic)
the main purpose its for use it for my home theater room measurements and calibration
I will use REW
- Room EQ Wizard Room Acoustics Software
Note that I have subwoofers that drop to very low frequencies, around 6Hz. so I need the audio interface can accurately capture frequencies below 10Hz without rolling off in that region
I want it to support high dynamic range.
My budget is a maximum of $1,500.
I found these devices.
1\
2\
3\
I don't know if it is suitable for my usage or not
Is there something better than these that suits my usage?
What are your suggestions?
Thank you
Of the interfaces on your list I would choose the RME, because the company behind it is reputable and stands by their product. Also there are dozens of RME users on ASR, and we rarely have problems.
A cheaper alternative is the Motu M4. I believe it goes down to 1Hz or even DC, but Amir's testing did not go that low.
