johnevansdesign
- Joined
- Aug 29, 2025
- Messages
- 10
- Likes
- 1
I need help choosing audio interface hardware. Please pardon this repeated discussion request, but there are so many alternatives. I have researched for some time and have learned a lot, but with all the options and no place to go to see devices and discuss with knowledgeable people, I am here.
Julian Krause said it is important to know what you want to use it for FIRST!
I will be primarily using it as a convenience with my Axe FX processor and guitar, initially routing and adjustment convenience, and later some simple recording and perhaps the wife using the Mic for her needs.
I need to connect:
Axe FX out (XLR, TRS, or SPDIF) Stereo
Looper out Stereo
DAW I/O (meaning PC or iPad playing backing tracks, and future SIMULTANEOUS recording)
FRFR amplified Cabinet Stereo (800 amp)
Headphones, 250 ohm
Keyboard out (future whim)
Connection needs:
I have no idea what my future behavior or desires will be, so I want flexibility (this is all a new build), so ALL advice is welcomed.
1) No computer required to run configuration; I know I will need computer to at a minimum setup some backend routing, but after that, unless I'm recording, I'd like to not have one connected; Just turn on and play my guitar!
2) Power brick required - need my USB port dedicated for PC comms, on or not.
3) I want to have some hardware convenience to adjust BASIC input levels and things I don't yet understand completely, without needing a computer.
4) Selectable profiles and routing: I wanted to possibly be able to run complete bus into headphones (seems easy), but ONLY run Axe FX output to the FRFR amp in one profile, and then complete bus to FRFR in another profile.
5) recallable profiles on hardware
6) rotary encoders for level knobs, so that the computer software and/or hardware knobs are synced and can adjust alternatively.
7) SPDIF would be nice in coax (Axe Fx is coax). SPDIF is not a deal breaker, but maybe good option for this layout. Thoughts?
8) Combo jacks, send/return, separate input sections for bypassing preamps
9) the luxury of adding wife's keyboard in future.
You all may see some bad judgement in my ideas, and I welcome suggestions and alternatives, this part including recording is all new to me.
The main goal is to just sit and play with some looper action or backing tracks, without a lot of monkey farting with a mouse and keyboard while I'm playing, and record in the future. I understand that I'll have the computer for backing tracks, yes, but I'd like to be able to just adjust a knob for something simple; when using the looper, I don't want to plug a computer in at all.
My research has brought me to
MOTU - Ultralite Mk5 and 624. The M6 can't route and save profiles, UGGH. I was told the mk5 was my best choice, but the mk5 can't save profile info to unit, so PC had to be used in conjunction for any routing.
Audient id24 - USB power only, so I'd have to swap the cable on and off computer - UGGH.
SSL 12 - No SPDIF, and stupid USB power only. UGGH.
You all see? I keep hitting "oh this is great, but there's one problem". I could really use some experienced advice.
The Axe FX can do all this routing, but i wanted some convenience without all the AXE FX routing.
Thank you all.
John Evans
I need to connect:
Looper out Stereo
Headphones, 250 ohm
Connection needs:
Thank you all.
John Evans
