- Joined
- Jul 21, 2018
- Messages
- 259
- Likes
- 554
Can you help me with suggestions for a great AV stand which satisfies (most of) the criterions a) to g) below?
I am looking for a gorgeous and wide AV stand. It will contain a huge TV on top and my components in a shelf.
It should be:
a) In white finish (preferably high-gloss white). But a part of the stand may be in another colour (for instance its top plate or the feet).
b) At least 180cm wide (prefereably from 180cm to 300cm).
c) At least 45cm deep (preferably from 45cm to 55cm, but a little big deeper than 55 cm is also OK).
d) Approximately 1 meter or more should be "open" (in the same shelf) to contain hi-fi my components.
e) The height from bottom to top for the shelf with components does not need to be large, since my highest component is 24cm.
f) Look gorgeous. A modern style is preferred.
g) Can be a little expensive, but not very expensive (it should preferably not cost more than USD 4000).
It should be:
