Thanks. I stand corrected on Amir having a Klippel.
Looking at his review:
"The CSS Criton 1TD-X design has benefited from some good design choices such as a woofer with impressive power delivery with good on-axis and predicted-in-room frequency response. There are minor imperfections here and there but at higher level, it achieves very good fidelity. Subjective experience with a bit of filtering was very good. As a kit, it will give you the satisfaction of building something you can take pride in."
Ok, outside of the EQ he points out a weakness in the CSS which is the cabinet resonance.
Looking at the Fidelia, there is more bracing. In fact its the back of the speaker which has an issue where he cut out space for the back panel. This is the area that got tore out.
So its a bit of a trade off. Had he used HDF or MDF for the cabinet, that wouldn't happen. It doesn't impact the sound, but its an aesthetic issue.
The nice thing about the kits is that you can modify them if you know what you're doing. CSS sells the kit w/o a flat pack so that you can design your own box as long as you don't change the size and shape of the baffle.
Again, I'm not knocking the Fidelia, just comparing it to another kit.
Honestly if you're in the EU, the Fidelia is a better option simply because of the cost of shipping.
W.R.T the data...
While I respect both Erin and Amir... its not the same if Erin reviewed the Fidelia, and Amir the CSS or vice versa. Two different people, two different reviews. There's an objective and subjective part.
Its when you have the same person reviewing both speakers... also if you have a gaggle of reviewers w a consensus of opinions.
The reason I wanted to compare the two is that there are design choices that have been made and this leads to different outcomes and issues.
