Audio Fake Detector PRO
Issues on GitHub are solved and closed
@Alessandro Comito Using Audio Fake Detector PRO v8.4a I am getting the following error. It happened 2 times a shown below when scanning 2 albums.
[12:05:13] [10/28] D:\Music\Lossless\Bareilles, Sara\(2013) The Blessed Unrest [2013, US, CD, 88883722902]\10 -
Eden.flac
[12:05:13] Full analysis (>= 170 kbps) │ Engine: auCDtect (lossless, staggered pipeline)
[12:05:13] No encoder tag │ flac │ 44.1 kHz │ 2ch │ 16 bit │ 1012 kbps │ 00:04:05
[12:05:13] slot1 @61s -> CDDA 100%
[12:05:13] slot2 @123s -> CDDA 100%
[12:05:14] [LOG ERROR] Exception calling "AppendAllText" with "3" argument(s): "The process cannot access the file 'D:\Music\Lossless\Bareilles, Sara\~Report\AudioFakeDetector_20260809_120501.log' because it is being used by another process."
[12:05:14] slot3 @184s -> CDDA 100%
[12:05:14] [CLEAN] auCDtect: CDDA 100%
[12:05:14]
[12:05:24] [20/28] D:\Music\Lossless\Bareilles, Sara\(2010) Kaleidoscope Heart (Target) [2010, US, CD, 88697 77035
2]\08 - Basket Case.flac
[12:05:24] Full analysis (>= 170 kbps) │ Engine: auCDtect (lossless, staggered pipeline)
[12:05:24] No encoder tag │ flac │ 44.1 kHz │ 2ch │ 16 bit │ 931 kbps │ 00:04:12
[12:05:24] slot1 @63s -> CDDA 99%
[12:05:25] slot2 @126s -> CDDA 100%
[12:05:25] [LOG ERROR] Exception calling "AppendAllText" with "3" argument(s): "The process cannot access the file 'D:\Music\Lossless\Bareilles, Sara\~Report\AudioFakeDetector_20260809_120501.log' because it is being used by another process."
[12:05:25] slot3 @189s -> CDDA 100%
[12:05:25] [CLEAN] auCDtect: CDDA 100%
[12:05:25]
Eden.flac
[12:05:14]
[12:05:25]
Your antivirus probably intervened in some way at 12:05:25 that I can't explain, but the scan continued normally after that.
It's not a bug in the script.
Odd, I never saw that, even on the scan that went for several days. I am only using the standard Windows Defender.
Am I losing result data or is it written when the file is available? I suppose I will have to test.
Audio Fake Detector PRO v8.5 released
Thanks for the update. I saw the engine choice right away and had to dig into the readme.md to see the details. Might be nice to at least have the bold lines on that engine selection screen, just a thought. Maybe a note about extended processing time with one.
For those wondering, the details are:
### ️ Dual-Engine Precision
The combination of LAC + FLAD provides complementary validation for lossless PCM audio by addressing each tool's native blind spots:
LAC accurately detects sample-rate upscaling (e.g., 44.1 → 48 kHz).
FLAD helps identify lossy-to-lossless transcodes (e.g., MP3/AAC → WAV/FLAC).
Neither LAC nor FLAD is responsible for native DSD analysis; DSD processing is handled independently by Audio Fake Detector PRO since version 8.4.
This complementary approach is particularly useful because the two analyzers can expose different types of suspicious lossless material that may be missed by the other analyzer alone.
Also, what is the Full FLAC/WAV (v) toggle on the main window?
Full FLAC/WAV ( ) → per-slot analysis
FLAC/WAV (v) → full track analysis
Updated 2026-09-17
Replaced ForceRedirect.exe
mp4 192kbps zansei.flac - a FLAC created from an AAC 192 kbps source.
️ mp4 192kbps zansei.flac Google Drive Google Drive (101 MB)
Updated 2026-09-18
