About the CSV, I completely see your point now, when dealing with huge log files, a structured CSV is lightyears ahead of CTRL+F.
I'm working on implementing it.
Regarding your understanding of the process: You nailed it perfectly.
Case 1: It's straightforward. All 3 segments return 100% CDDA, so the file is instantly marked as OK.
Case 2: The auCDtect engine gets a mixed/uncertain result, so my program automatically triggers the secondary spectrogram analysis. It scans those 5 specific timestamps (slot@...) to measure the actual frequency cutoff, helping you determine if it's a true lossless file or a lossy upscale.
Why is it slower than auCDtectTaskManager? You actually answered your own question at the end! auCDtectTaskManager simply calls the engine and generates the visual spectrogram images.My program, however, doesn't just look at the auCDtect score; when a file is "Suspect", it performs a deep mathematical analysis on the audio data at those 5 points to extract the exact cutoff frequency, RMS, and peak ratios. This secondary DSP (Digital Signal Processing) pass is what takes the extra time, but it provides a much more accurate automated verdict without forcing you to visually inspect every single graph.
