In their marketing, AVA writes:
"Q: Isn't this just a classic composite design?
There is a crucial difference between what people typically call composite designs and what we consider to be a nested architecture. In a classic composite design, there is essentially only one feedback loop -- around the entire circuit. Everything else is there just to make things work. So, you might have an opamp input stage that's running open loop driving a power amp stage that's also running open loop, with one big loop around everything and some compensation parts sprinkled throughout to keep things stable.
In a typical nested architecture, there are typically three important loops: one around the input stage, one around the power stage, and one that encapsulates both. In addition, with a nested architecture the power stage typically will have a gain not horrendously different from the overall system gain.
Does this matter? Not especially, at least to a first approximation. In both cases, the effective correction can be about the same; it's just distributed differently. In practice, a nested architecture may make the input stage work less vigorously because a bulk of the power stage's correction has already been performed in the power stage."
Looks like splitting hairs to me. I don't know any engineer that wouldn't call a nested feedback design based on two integrated chips a composite amp. And the advantage they're pointing out reads like totally wong. When the slave runs open loop at audio frequencies, the master has almost nothing to do, its output voltage will move just a few millivolts, compared to a few volts with closed-loop slave.
However, you cannot simply have three paralleled slaves that run open-loop with a single master, you'd need a master for each one of the slaves, and parallel the three composites, with load sharing resistors outside of the corrective feedback, thus higher output impedance. That's likely why they chose the "nested" approach, because it is is simpler to implement, and much easier to get super-low output impedance (and it is technically "good enough" when implemented well).
