Polite answer, I do agreeI am not saying that's the reason, but there seem to be too many things making this a totally useless appliance for the purpose of a real blind test.
I am not assuming anything. I KNOW it is utter bullcrap to have someone tell competent DACs apart 98% of the time. We have found out it was a useless test. Deal with it.If you assume Josh cheated, the comparator doesn't matter, the LEDs don't matter, nothing does. He could have simply made up the results in that case. So this whole disussion about LEDs can only be about the question if they are on or off in test mode. And they are off.
That's still a possibility. It is not like this is like foobar where you get a printed output. Josh said he got this and that result and to this date, we have accepted that at face value. But a true verification was not done in the form of say, recording a video of him taking the test and achieving said results.If you assume Josh cheated, the comparator doesn't matter, the LEDs don't matter, nothing does. He could have simply made up the results in that case.
Wait.. with LED off the noise floor of the DUT is supposed to be .....If you assume Josh cheated, the comparator doesn't matter, the LEDs don't matter, nothing does. He could have simply made up the results in that case. So this whole disussion about LEDs can only be about the question if they are on or off in test mode. And they are off.
If he is using for speaker comparison, then it is fine. Using it for much else is problematic.And I suppose Erin should stop using his ABX moving forward.
The ABX comparator manual says:
So regardless of who cabled up what, the LEDs obviously do not tell you what device is active in ABX testing mode (because they are off). I'm pretty sure this has also already been discussed in the initial thread and it would also make the device immediately and obviously useless to anyone.
The user then defines the two level-matched systems to be compared and enters Formal Blind Test Mode. Another command — ON-OFF, then 1 — starts the test. The LEDs go dark, and the VFD shows a “1” to mark the first of eight rounds. A random number generator assigns the “X” system each round. Using the remote, the listener can switch between the “A” system, the “B” system, and the “X” system. A small, uniform click sounds with every button press, concealing whether an actual switch has occurred. The UP and DOWN buttons move through the rounds. Afterward, MUTE button relights the LEDs, and stepping back through the rounds reveals the identity of “X” in each round.
You and "others" know as much about the real test environment as I do. You're just assuming. Go buy the device and show us...
As others have said, the notion that the LEDs are a tell is a complete red herring, especially when the fidelity is relatively poor.
Moving the goalposts. I was answering your question:I guess you were there live, ensuring the testing protocol was executed according to your assumptions.
At any rate, that question has been thoroughly and repeatedly answered.I repeat.. why listen to clicks when you have the source LED telling u whether A or B is active. It's there in the Pic.
This is why I said in my video on blind testing and you really should use such tools for yourself. For publishing, the level of rigor goes way up. Here is the video queued up to the right moment:This whole adventure goes to show how difficult it is to generate truly blind studies.
Unfortunately, Erin has used it for amplifier comparison, and on multiple occasions.If he is using for speaker comparison, then it is fine. Using it for much else is problematic.
You couldn't answer the question if you weren't there live, sorry.Moving the goalposts. I was answering your question:
Totally agree. If you are going to sell a product under your brand, you should test it to protect your brand.That is true although I wonder if they were going to sell it under their name, why they did not perform some measurements, and looked for any issues it might have (e.g. relay sound). After all, I am sure they kept some of the profits.
That's exactly what you just did:I am not. claiming it was the LEDs... but then why do they exist, hello?
Explain the picture of the device with two big LEDs identifying the source.
That was established in post #1 of this very thread. Why the need to keep ranting about it? The question has been answered.I am not saying that's the reason, but there seem to be too many things making this a totally useless appliance for the purpose of a real blind test.
Thank you for your polite reply.Wake up, they already are:
Reference ABX hardware design and implementation
Update 2026-09-11: boards ordered! https://www.audiosciencereview.com/forum/index.php?threads/reference-abx-hardware-design-and-implementation.72589/post-2679015 Edit 2026-07-31, see progress update at...www.audiosciencereview.com
Not so great here imho.But as the great philosopher Yogi Berra said, "In theory there is no difference between theory and practice. In practice there is."
