Even better.
It’s just as open or closed as it ever was.I detect that some think this issue still somehow ‘open’.
But it isn’t.
1] There cannot be any performance difference (between dacs under test) that caused Josh to ‘perform so well’ during his testing…his metrics show a very definitive result, but the box he used masked any possible performance differences in the dacs by FIFTY DECIBELS(!!).
Probably the relays. But we don’t have any evidence of that yet, other than conflicting testimony. Could be phase. Could be fabrication. Could it be filters? Seems incredibly unlikely, especially with the HF rolloff and presumably some if not most of those DACs used used the same filters on the DAC chip.2] So then, what other thing was the ‘tell’. Relays are obvious. But more importantly, it was not the DAC performance. That case is closed
No it doesn't. This has already been explained.I repeat.. why listen to clicks when you have the source LED telling u whether A or B is active. It's there in the Pic.
Sure, but that's an individual determination. Josh has written countless articles and to my knowledge there's no prior indication that he operates in bad faith.The lame public internet rule that everybody's opinion and word counts the same. It does not. Complete nonsense, sorry.
Because the LED doesn't tell you what X is.I repeat.. why listen to clicks when you have the source LED telling u whether A or B is active. It's there in the Pic.
Again - it is not about good or bad faith. It is about amateurish approach, questionable test method and no valid data.Josh has written countless articles and to my knowledge there's no prior indication that he operates in bad fait
It totally does if you cable things up yourself... Because the LED doesn't tell you what X is.
How do you know that.
We never got a thorough description... how do we really know he didn't cable up things himself and knew exactly which DAC was connected to which port? This device was to obscure that, right? Clearly it doesn't and provides both audible and visual cues.
All displays and settings are turned off in either the quick test or formal ABX test modes.
Does it really make a difference if a LED is obvious or not, or a click is different or not, concerning a DUT (here: an ABX-Comporator), that is distorting within audible range?It totally does if you cable things up yourself.
Whether or not the LEDs were covered up no one really knows.
So regardless of who cabled up what, the LEDs obviously do not tell you what device is active in ABX
Explain the picture of the device with two big LEDs identifying the source.
I'd rather trust my own two eyes than your third party observations, sorry.
Obviously, they are not off in training mode because you need to know what you listen to in that caseAll displays and settings are turned off in either the quick test or formal ABX test modes.
I am not saying that's the reason, but there seem to be too many things making this a totally useless appliance for the purpose of a real blind test.Does it really make a difference if a LED is obvious or not, or a click is different or not, concerning a DUT (here: an ABX-Comporator), that is distorting within audible range?
His "Best Version Of" articles are gems.His articles are worthless
Are you under the impression that when you select 'X' on the remote, the comparator lights up whether 'X' corresponds to 'A' or 'B'? If that were the case, that would be a truly useless device. However, there is no reason to suppose that to be the case.It totally does if you cable things up yourself.
If you assume Josh cheated, the comparator doesn't matter, the LEDs don't matter, nothing does. He could have simply made up the results in that case. So this whole disussion about LEDs can only be about the question if they are on or off in test mode. And they are off.I guess you were there live, ensuring the testing protocol was executed according to your assumptions.
