Audio by Van Alstine ABX Comparator Review
I understand what you're saying here but I would disagree when evaluating the entire effect the test and subsequent discussion has had. If absolutely nothing else we have @mcdn engineering a proper ABX box. And not just sitting on a forum pissing and moaning. That's a win. :)
We have some members here who are doing their own circuit designs, making prototypes, testing them and even selling a small lot production. That means, being involved in the whole process. There are not many, but they do exist.
I have demonstrated from time to time how the far-right side of measurements and data feels like and how unpleasant it can be to same same objective "camp" which otherwise defends it.
But that what hobbies feels like, the new-find-light fundamentalists are far more interest in rants than actual hobby-fun. That's the world of forums, and after so many years most know how to navigate through.
This thread is both a goldmine and a trash-can, one chooses what to pick.
Amir and the rest gave the data, interpretation and usage is probably personal, but it's a great school!
I only know of Matt designing a full-fledged ABX box. I'm definitely curious about the others you're referring to.
I was speaking about audio circuit design, not specifically about only ABX box design. Even in case of the ABX box design, let’s wait for the finished prototype and its parameters.
By the way, no one seems to mention the implications and side effects if some of the issues of this box prove to be the cause without a doubt.
The new market of high-output DACs, low input impedance gear for home use (one of the tricks for low noise) has created a new side market to it: low/no gain amps and -surprise - surprise- all sort of passive attenuators and similar for existing medium gain amps so people can maintain some safety at first, specially when using digital VC upstream and decent SNR, etc.
So, is it fair to assume that this setup will be replicated lots of times out there, with users not knowing the effects?
It is true that the concept of "passive" volume control is attractive to audiophiles without realizing the problems with it. Indeed, Josh himself repeatedly bragged about the AVA trim controls being passive implying that they must be pure or something. Expecting audiophiles to know that varying impedance and lack of buffering are bad things, is hard. I do test for them in my reviews of such passive devices though.
Exactly. Active buffers are no no for audiophiles. Look, I have been in contact with that sort of people for quite long time, like 15 years. I dare to say I know their reasoning, objections and tricks. I had to swallow something from them, because during certain period they were my customers (power amplifiers). Not easy, really :). And my experience is that it is almost impossible to convince them on objective parameters importance.
The funny thing about is that some of them had different views for about the same working principle.
Take the Magnepan community for example, a gazillion of them have been actively driven their speakers with stuff like Marchand, etc refusing (and rightly so) to use pasiive stuff like the Harrison ones and so, acknowledging the importance.
And the same ones can be found using a passive attenuator upstream of the el. active x-over! (Phil probably gave the option for 100kOhm input impedance for their shake)
(by the way, the same community made minidsp happy at the early days)
Reactions: pma
I appreciate that the steps would be larger as N increases but still it seems more than that. Here is what I get when I do the divider, including the 3K resistor (hope I did not make an error) However, the box has 100 positions and the IC has 256 positions, so maybe some of this has to do with the assignment of the box volume number to wiper position in a judicious way to give what is described in the manual?
Sorry -- I made a spreadsheet error. @KSTR is right, the step increases quite a lot more as N approaches 256. So what is in the manual seems a natural result of the circuit. Still, the AVA code must be doing some careful assignment to wiper position with the 99 to 10 compared to 09 to 00 volume, right? Now it seems unimportant; I was wondering if additional circuitry was being switched in but now I get that they would not do that.
I'll try to explain.
There are 3 different types of 'steps' in this box.
There is the displayed step (0-99) which would correspond with a 0.1dB attenuation level-step per 'displayed step' from a certain displayed step upwards.
And there are 'tap-steps' (78 ohm resistor steps in the ladder) in the AD5262.
Then there is the actual 'level step' (supposed to be 0.1dB)
They are NOT the same 'steps'.
Near the maximum setting each first tap-steps is close to 0.03dB so display step 99 to 98 on the display requires the AD5262 to make 3 'tap-steps' to create the 0.1dB 'level-step' (with a small error that is setting dependent).
The AD5262 'potmeter' is linear and has 256 resistors of 78ohm each) creating the total of 20k.
dB values are logarithmic so the closer you get to the 'bottom' of the 'potmeter' the less 'steps' are needed to create a 0.1dB level-step.
For this reason a volume control is always (semi) log type and you can't use linear for that (which the AD5262 is).
At some point you can't even make 0.1dB level-steps anymore as each 78 ohm tap (step) becomes equal and subsequently even bigger than a 0.1dB 'level step'.
For this reason the 0.1 steps can only be created up to a point (and often won't even be 0.1dB but a bit bigger or smaller) and the 'steps' have to become bigger than 0.1dB and steps larger than 3dB are created with the lowest steps.
The 'tap steps' at the far bottom of the adjustment range are 5.5dB and the second last step is 4.34dB
So there is a 'map' in the processor that tells the AD5262 how many 'tap-steps the chip has to make in order to create the 0.1dB level-step.
This way one can make a linear pot act closer to a logarithmic (dB) pot.
Unfortunately the designer did not buffer the AD5262 (which he should have) and has consequences which are shown in the table below.
When the AD5262 is loaded with a certain resistor value the 'displayed steps' do not correspond with the (desired/designed when not loaded) 0.1dB steps.
When the box is loaded with 100k and you need -1dB trim you need to go from 99 to 90
When the box is loaded with 50k and you need -1dB trim you need to go from 99 to 91 (so the steps are not 0.1dB any more)
When the box is loaded with 10k and you need -1dB trim you need to go from 99 to 93 and not the expected 90
When the box is loaded with 2k and you need -1dB trim you need to go from 99 to 96 and not the expected 90
One might think each step is 0.1dB (as per the manual) but it isn't.
The actual dB steps depend on the load resistance and how many 'tap steps' are required to make an (unloaded) 0.1dB step.
Fortunately one can operate the 'displayed steps' and have to measure the actual output voltage AFTER the amp that loads the AVA box.
The snag is that when the load impedance gets lower the 'displayed steps' are getting bigger than 0.1dB and one may not be able to get a matching within 0.1dB.
All fine when one compares DACs that are just 1 or 2dB off in output level but becomes an issue when comparing a DAC with 3V out and 1V out and loading the box with an amplifier that has an input resistance below say ... 20k or so.
One would have to digitally attenuate the 3V DAC output voltage to close to 1V (-10dB)
Note that Josh reported trim levels never exceeded 9 steps and has a 42k load to it so matching within 0.1dB was totally possible but depends on the resolution of the used measuring method (0's behind the decimal).
This means the DAC output voltages of the used DACs
Thanks for this great reply.
Of course. But that doesn't exonerate us from doing our best to not fall into the same trap.
That said, sometimes I get petty in responses to my videos. But they have it coming. I swear. :D
Thanks for your response, and I should have been clearer - yes, I agree with your "doesn't exonerate" us point. 100%. It's just a fun hobby so no big deal at the end of the day, but I have to admit it drives me a little crazy when folk descend into ad hominem or accusations of malign motives when there's much stronger, more evidenced-based support for their position available to them - which evidence is the main reason I value measurements in the first place!
No one likes it when they are not believed/questioned/attacked.
It also matters how the questioning happens (and where) when one is publicly questioned and if and how reactions are given.
Such usually ends in shit shows and unwillingness to cooperate. Sadly...
What if everyone could restrain themselves a bit better in life ?
That would/could be the constructive thing to do.
Sometimes, some people might have just have 'had enough' ... sadly.
Coming soon... I don't have high hopes for the THD over all gain ranges for the first prototype as I didn't model the Coff variation of the muxes, only the Ron variation. Still should be better than 80dB at worst, reaching 120dB in some gain settings, but not the >120dB at all gains that is the goal.
Precision should still be 0.01dB (4096 steps over 20dB range). The THD fix is simple and there's lots of other functionality to test so the prototype is still very valuable, but it will need a new spin of the analog board to meet the transparency goal.
Reactions: pma
Tiny addendum: With 0.1 dB steps, your matching can always be within 0.05 dB. The worst case match will always be half the step size if done right.
If you're off by 0.06 dB you can attenuate one channel by another 0.1 dB and arrive at a 0.04 dB difference.
Yes, but only for the range between 70 and 99. The steps can be bigger than 0.1dB and thus also between A and B.
Below that range the differences can exceed 0.05dB depending on the load.
There is no such problem between 90 and 99 where it was used.
How far one is off thus depends on the load resistance, range and how accurate one measures AFTER the used amplifier.
We have concrete data to back scenarios that could invalidate the test. Which one is really at play, or whether Josh's test is valid, is impossible because of lack of cooperation from Josh himself. We know many ways his tests could be invalid:
I'm talking about 'the culprit' in your test, your experience, listening to white noise after using the AVA box to match levels and hearing an obvious difference, as reported by you.
That's far more interesting to me at this point than Josh's saga. His saga has data holes in it that we will never fill, meaning we won't ever know 'for sure' what glitch produced his (surely faulty) results.
That's not true of your report.
I didn't see a reason to keep testing.
Gordon Bennett! Quelle surprise!! I wasn't keen on the community project, why another box? I have now changed my mind, go for it guys, can't do worse... do note this is really hard to do well - but we know that.
I hope you will be luckier than was I, this is something I got with silicon switches:
Green trace is the generator signal.
