I've really appreciated the many insights you've brought to this discussion, along with your own designs and tests that you've shared - thank you!
With that said, come on man - there's no need to trash everyone's time and effort (including your own) as worthless and a waste. It's been highly informative for many of us, and if you already knew all of this or already had your own take on it that you were satisfied with, that doesn't mean it hasn't been valuable for others. Your high level of expertise is evident - you don't need to try to demonstrate it by dismissing all the technical info as redundant because it was already "immediately visible" to you from the the datasheets of the components. Lighten up - discussing this stuff can be fun even when it's also being kind of aggravating.
As for my own view of this whole... episode, I'm in academia and there's a joke in our sector that "academic arguments are so pitched because the stakes are so small."
I don't say that to diminish the importance of the issues being discussed here, but I do think it can be helpful to drain the blood out of things a little bit. We all know what's really going on here: the subjectivists are trying to dunk on ASR because we allegedly "can't take it" and "turn into religious fanatics ourselves" when a "scientific" result disproves what they mistakenly believe are our unshakeable convictions.
Why take the bait? There's no need to worry about lost credibility for science or about the ignorant, self-satisfied things that some folks at another forum might be saying. Josh clearly aced the test. The most likely explanation is clearly something to do with the comparator box (and/or the comparator box as it differentially interacted with each DAC).
And even if the DACs did produce tiny differences that could not be accounted for by the box - which is unlikely but possible and there's nothing wrong with directly admitting that possibility however unlikely - Josh's own summary of the differences makes it obvious that they are not nearly of sufficient scope and magnitude to guide a purchase decision of one over the other, or - and this is the key part - to explain the alleged differences some folks say they hear in sighted, uncontrolled listening comparisons when they swap a new DAC into their existing system.
To me, Josh's results are akin to taste-testing two different brands of mayonnaise made from the same recipe: if you are able to reliably distinguish one from the other but you have to really concentrate, rub your tongue around your mouth, and focus on fine sensory details of the faint aftertaste a spoonful of each one leaves in your mouth, then either there was some kind of external cue that you're not aware of, or the mayos do in fact have some slight difference between them - but either way they're going to taste identical as soon as you put them into a sandwich surrounded by bread, meat, lettuce, and tomato.
