Audio by Van Alstine ABX Comparator Review
Exactly. Still some, even technically knowledgeable members here try to find excuses for the test and believe in a good will of the tester.
I don't know that any are finding excuses for the test versus simply comparing what Josh says he did and did not do to hypotheses about what Josh did or did not do, that are repeatedly raised by Amir's findings.
'Some' technically knowledgable members are doing this by continually, methodically referring back to Josh's actual testimony about what he did (and acknowledging where Josh's information is lacking).
Which is a really good practice in a twisty case like this for accepting or rejecting an hypothesis; relying on memory of testimony one may have read weeks ago on this site and on AS, is not.
I wrote actually, truly, specifically, true precisely to forswear the need for responses such as yours.
I apologise for agreeing with the part of your post that didn't actually matter. The point was that psychoacoustic research was never in jeopardy.
A point I clearly disagree with. Because if Josh's method actually truly really honestly unequivocally jaysus christ are you getting the point yet? passed every test Amir threw at it, and it truly literally really etc. was 'just the DACs ma'am' that produced his unprecedented and astonishing results, there'd be some 'splainin to do. Obviously.
Anyway enough of trying to ward off pedantry with mere emphatic writing.
Back to reading posts about technical matters somewhat above our head.
I think some here and many there hope in a breakthrough in psychoacoustics findings. A devoted audiophile has found it :p:D:p:D.
Because if Josh's method actually truly really honestly unequivocally jaysus christ are you getting the point yet? passed every test Amir threw at it, and it truly really etc. was 'just the DACs ma'am' that produced his astonishing results, there'd be some 'splainin to do. Obviously.
I'm talking about the scenario after Amir's tests of the AVA ABX box, because that's the context of this thread, and you seem to be talking about the context following Josh's review and before Amir's test.
There is no conflict unless you're looking for excuses to have one.
Life beckons elsewhere.
He was on the side of the angels re: MQA,
True, yes - although to extend the metaphor, he was on the side of the angels because several angels in his forums educated him about why MQA was a problem, and their knowledge, explanations, and homemade tests enabled him to make a famous/infamous audio convention presentation about it - and he repaid their contributions by banning their information and opinions from all but one subforum at AS, prompting most of them to leave.
Integrity... It's a lost art form.
For science...
Thanks to the measurements from Amir, combined with some additional info from Erin, I was able to figure out how the actual level trimming circuit is designed.
The used AD5262 is basically a 20k0 controllable 'potmeter' but instead of a wiper there are electronic switches (which add the distortion measured Amir.)
There is a datasheet from the chip which shows the roll-off from the chip (only 20kΩ trace is relevant)
This roll-off is caused by an internal 55pF capacitance in the chip itself.
At 20kHz the chip itself (no attenuation = 99 setting) rolls-off -0.05dB (40kHz = -0.1dB)
This will be a bit worse at -1dB (90 setting).
The chip itself has (close to) 0.025dB 'steps' internally. The AVA box has 0.1dB trim level steps which means 4 'resistor steps' are used for each 'trim level step' resulting in a 312Ω 'trim level step' in the 20kΩ potmeter.
Below the schematic as is present inside the AVA box. That is excluding the relays used for routing the input signals. These will not change anything.
Turns out it was not just the AD5262 (which was evident from Amir's dashboard) but has 2 additional resistors and the output resistance measurements from Amir.
The tricky part was finding out which values were used and Erin provided that additional data.
It's a good thing these resistors were added as it makes the box a bit less input and output resistance dependent in the first trimming level settings.
But is also creates some issues (roll-off differences). These are caused by the cable (and load) capacitance combined with the output resistance of the circuit.
That roll-off frequency, however, is also load resistance dependent.
This resistance differences has consequences and also explains why there is discrepancy between Amir's and Josh's measurements (100k load vs 50k load)
Of course the source resistance also has a small influence on the output R but is too small to make changes in the frequency response.
Simulation time ... in Multisim I simulated the AD5262, the source output resistance, the circuit itself, the load resistance and cable capacitance.
Not knowing what RCA cables were used I measured some of my cables and on average these were close to 200pF/meter.
So .. I simulated using 1m and 2m cables and with source resistance of 100Ω and for the load I simulated 100kΩ (APX555), 50kΩ (Josh's amp), 10kΩ and as some would like to see what would happen with a 2kΩ load.
Influence of the source resistance in relation to the output resistance was also simulated 0Ω, 20Ω, 100Ω, 600Ω and 2kΩ.
Lets start with the output resistance (valid for DC-10kHz) and simulated for setting 99 and 'worst case' 90 setting. This would mean the output voltage difference between the DACs should not be apart more than 1dB (about 10%). If DAC A is 2.0V out (dBFS) the other DAC should be between 1.8V and 2.2V
When that difference would be more things will change. Going by the remark from Josh that the trimming always fell within the 90-99 range.
The change in output resistance of the AVA box is marginally source resistance.
Most DACs will be between 100Ω and 600Ω out and this will not change the roll-off in an audible way.
Then we also have the question what the DAC's in question see as a load.
Of course, this also changes for different loads and different trimmer settings.
Below the load the DAC sees when the AVA box is loaded with a specific resistance. No load, 100k load, 50k load, 10k load and 2k load at trim levels 99 and 90.
Here we can see that the load the DAC sees changes a bit depending on the load which, dependent on the output R of the used DAC will result in slightly different levels at best. When using a 50kΩ load (Josh) and assuming a DAC has a 600Ω Rout (likely worst case scenario) calculates as max. 0.02dB level difference.
So now the FR changes (simulated) using 1m RCA at the output (the input cable is not relevant) and a 2m cable with different load resistance in 99 and 90 trim.
There is a little snag though which is the load resistance matters and as the DACs were level matched at the output of the amp this requires the 'trim setting' to be different from 90 with a lower load impedance.
The frequency response thus is simulated in 99, 90 and (-1.1dB attenuation level) with 1m and 2m RCA cable and given at 1kHz and 20kHz only.
This means that the box as used by Josh, depending on the cable capacitance (which is unknown) can have a max. frequency deviation of around -0.13dB at 20kHz.
When a 1m cable was used around 0.03dB deviation (which jives with Josh's measurement).
Safe to say the AVA box was unlikely to cause an audible roll-off difference.
Phase in worst case @ 20kHz was 10° but most likely just a few degrees at most.
This does not invalidate any of Amir's measurements as it is unknown what cable capacitance was used and a higher load resistance was used (100k) than what Josh used so the few measurements Josh made seem to be correct.
In the end... For me, the roll-off, load and source resistance for 90 and 99 trim seems to jive with the measurements and in Josh's case thus do not appear to be as bad as Amir's measurements show (on this particular aspects) because of the different conditions tests were done.
Also note: these were just simulations and are likely close to reality but can differ.
Now... while the roll-off and phase differences in Josh's case do not appear to be an issue that does in no way mean the box is O.K. and usable for critical listening comparisons.
Reasons are the substantial distortion that, acc to Josh's measurements, differ per trimming will nullify any differences in DACs due to distortion (profiles) of the compared DACs as the distortion of the AVA box is magnitudes higher and will mask any differences.
Level matching may have been within 0.05 and 0.15dB (we have no clue).
There is crosstalk between A and B input.
There can be timing differences between DACs giving cues.
In the end... is the AVA box the best method to compare DACs that are very similar (but arguably not the same) in performance?
Not by a long shot.
There is NO way to tell what Josh heard and what was the actual cause of the tests. Sadly only recordings of the actual tests would have shown the reasons for the results.
The evidence simply is not there and means the results are clear but may not have been between the DACs and could well have been caused by the (poorly performing) AVA box.
This much is clear from Amir's measurements.
That seems to rule out that Josh could have heard differences between DACs. Whatever differences he heard, it must have been related to the box, and that still makes a level mismatch (done unknowingly) the most likely candidate IMHO.
Great efforts, Frans. You still have not covered the preamp distortion dependence on generator (source) impedance. This is well known that any opamp (or discrete amplifier) has distortion (and noise - resistor thermal noise) dependent on source impedance and this effect is also frequency dependent. Especially a non-inverting configuration - so called common mode distortion. Not saying it would dominate, however, if you want to be rigorous, you have to take it into account, together with a mere divider impedance effect.
Well.... I would not draw that conclusion when looking at ABX measurement results of devices with an even worse amount of distortion.
Could be level matching after all, could be timing, could be distortion differences between trim levels, could be DAC related differences, could be crosstalk (timing related), could be small difference in noise levels (the common mode crap Amir reported) but as an isolator was used this is unlikely. We don't know and can only suspect.
All we know is the test results and what Amir measured. The latter shows poor performance, much worse than any DAC.
The fact that there is no actual evidence other than the posted results and it is not fully documented makes the result suspect.
In other words we have no idea if the results actually come from the AVA box 'modifications' to the sound or come from actual differences between DACs
And because the results are suspect we can't (with 100% accuracy) say the results are valid or not (lack of evidence). At least that's my opinion.
Some people will say... there... the box is flawed so the test results can be disregarded.
Others will say .... well ... the measurements suggest the influence of the box are clear and can influence the test results making the test 'suspect'
Yet others will say .... well ... Josh clearly heard differences even despite the box affecting the sound but for both DACs so the results are still valid to them.
So for me it is clear that the test results are at least suspect.
They can only be proven to be correct after the test is repeated by recording the sound of the different DACs, level- and time-match those recordings and Josh could succesfully ABX them (out of 20) with the recordings verified.
17.5k vs 18.5k load of DACs is not very likely to cause relevant different distortion from an output circuit of a buffered DAC... 600 ohm or 2k vs 100k sure.
6k vs 7k source resistance (through an electronic switch) into a 50k load also is not very likely to show much difference... if it were 100 ohm vs 2k source ... sure.
Would take a lot of hassle to simulate that and one would need to know the input circuits of the used amplifiers and used op-amps that drive the AVA box.
I think the differences will be dwarfed by those the AVA box adds. :)
But yes, more aspects could be simulated/tested. This was basically just to satisfy my curiosity about the trimmer circuit only (which is the most likely culprit) and then only the resistance and low-pass effect on various loads.. So rather limited.
Of course. And the odds of Josh agreeing to do that seem extremely low.
I think to argue that the box is flawed but the results still stand is special pleading. And it’s not good science.
I admire your diligence in trying to find out the actual reason for Josh’s results. But surely there’s a time to just say ‘the box is flawed in several ways, any of which alone or in combination could account for the results.’ And then push for a retrial rather than flog this dead horse.
Occam’s Razor suggests to me that level matching is the most likely cause - to get 110/112 absolutely requires significant differences not slight ones.
Indeed, the point is there are people that don't care about the science and believe the test is valid, mostly because it seems to prove 'them' right and the 'cloth eared plot gazers' wrong and are beaten in their own game (blind level matched ABX test).
My conclusion is the box is flawed and can possibly be the reason for the 'successful test'.
There is evidence for it by the box's performance but not enough for the actual listening test to blindly accept the results at face value.
IMO Josh should repeat the test as I described above and if he can get the same results then the AVA box test may well have been good enough after all.
We don't know and don't think Josh will repeat the tests in the described way.
Josh could either be vindicated but there is a good chance he might not pass that test.
I'm afraid we will never know.
All I did was simulate a small part of the entire AVA box performance.
In my best analog preamp, that is based on this topology:
I use DACT 10kohm stepped attenuator as a volume control. The frequency response is not dependent on volume setting, at all, due to buffering form both sides. Below are relative frequency responses measured at -8dBFS and -4dBFS volume setting, related to 0dBFS measurement. The Y axis full scale is +/-0.1dB!! This is what I would call a Frequency response independent on volume setting.
'might not' have value. or... 'most likely does' not have value... and is only my personal opinion. ;)
Like EU political correctness ;). Sorry for breaking the rules, but such a temptation.
Even if the AVA box had input- and output-buffers (which would have helped in certain aspects) the too high distortion of the AD5262 would be its downfall.
The AD5262 also has its own limitation in FR (40kHz -0.1dB, see below). And a buffer would not help that either but at least not make it worse.
Arguably it would be considered wide enough (100kHz -0.5dB) if it had a buffer.
A stepped DACT would not be able to have enough 0.1dB steps to be of any practical use unless one only needs 2 or 3dB trimming only.
