@amirm are you saying that unless he knew about the load dependency, he would not have compensated for it? And if so, could he have known about it without performing the tests you performed?
Let me put it this way. The discovery that matching levels at the AVA output does NOT result in matched outputs once through a headphone amp, is an
immediate showstopper.
You do not proceed without actual electrical engineering knowledge of why that happened and what its other consequences are. Since Josh lacks this experience, recall how he kept claiming that the passive trim controls in this box was a good thing in the other thread, you come here and post a thread and ask.
If he had done that, we would have all a) figured out this major fault with the box and b) warn him to not continue without figuring a mitigation plan.
As I have shown, variable output impedance vs trim level also creates a low pass filter with variable response:
So you could match levels at 1 kHz but still have frequency response deviations. This level of deviation is very close to what you would get as a result of some DAC reconstruction filter. Since the theory of any objective detection of the DACs is based on that frequency response error, the fact that AVA creates the same (piled on top of the DAC), once again is a showstopper.
As I sit here, we don't know what path Josh took. Maybe he split the difference between the two measurement models. Maybe he used my suggestion of going by AVA output. We just don't know. What we know, and can take to the bank, is that he claims fantastical results.
Let's remember, this is no ordinary test. Josh didn't take an alixexpress DAC and compared to Topping. He compared top of the line DACs. For that, everything had to be matched to the strictest standard. Sitting here with all the instrumentation I have, I don't know that I can accurately match levels. The AVA level matching of 0.1 dB is not good enough for fully defensible position there based on albeit limited listening tests I did the other night.
Bottom line, we have a simple, clean explanation of why someone could easily tell the difference with almost 100% reliability between high performance DACs. And that points to not matching levels properly. No amount of "trust me bro" from a non-technical person is going to suffice to get over these issues. He wanted the element of surprise and it bit him in the buttocks.
