The sign flipped means the added spectra will cancel, right? I mean cancel in terms of doing a delta spectra graph.Not sure what the problem is. I'm pretty sure I fixed the initial mistake in my files. For 60 µs, which is what I aimed for, you should use 6 samples @ 96 kHz.
Logically, it makes sense to me that the ripple would emerge: If you add two time-shifted copies @-40 dB to one track, the difference to the original are the two echoes. If you add one time-shifted copy @-40 dB to each original track, the nominal difference between them is the same: The two echoes. But one will have its sign flipped.
Also, the reason I made the files with just 2 sample offset is because I thought it would show something similar to a rolloff of high frequencies in the audible band. But then I was faced with seeing that the delta of spectra didn't have the ripple.
