Audio by Van Alstine ABX Comparator Review
yet ....
See the PK metric change when different attenuation is used .... on Josh's gear.
This means there are changes that are possibly reaching audible levels and on top of that any superior sound quality of any connected DAC is destroyed with many factors due to the box.
The whole point is that the box changes the signals of the DACs too much in order to be able to safely say... The AB test results are caused by the DACs.
They can be caused by 2 different DACs but can also be caused by the box's poor performance.
Because of this the results Josh got are suspect.
I measured the input impedance of the Benchmark HPA4 (S/N: 205309xx) using an AP SYS-2722.
For both XLR and RCA inputs, I performed sweeps at volume settings of +15dB (Max), +9dB, 0dB, -20dB, and -112dB; the differences observed were negligible, falling within the margin of measurement error.
As a precaution, I also performed measurements using an LCR meter (at 1 kHz and 10 kHz).
You can find the Stereophile measurements for the LA4 here:
I was only intending to address the notion that the AVA ABX changed the frequency response of the DUT.
It DID in the case of Amir's test, but NOT with Josh's. Of course it added a lot of noise and distortion, and it shouldn't be there, but we don't know if that was the discriminating aspect (I don't care, actually).
It's ironic that the reason for using a passive comparator instead of ADC recordings is to avoid the noise and distortion of the additional conversion processes, when it's actually very much the other way round. That's one of those difficult and expensive lessons learned that I alluded to earlier. Now we know; that's all this thread needed to do.
It's becoming clear to me that the audible differences between DACs comes from the differences in FR and perhaps PR of the filters, rather than noise and distortion. Those differences are easily captured with the E1DA, and I'm really impressed with the stunningly good results that Archimago got from the E1DA 9039 DAC and ADC - THD down around -140dB for both DAC and ADC processes together, so the conversion process itself does seem to be a solved problem. But perhaps not the filters.
It's probably time to resist the temptation to throw any more fuel on the fire and go and do something else.
For these devices, the FR was affected by changes in load.
For this device, the FR was hardly affected by changes in load.
I don't want to come across as too much of an apologist for Josh, because I think the AVA ABX is a lost cause that we should stop wasting our time on, and concentrate instead on the DAC - ADC - DCA ABX testing, which is positively fruitful, and actually goes some way to endorsing his original review premise.
That aside, Josh does have a good answer to the question of FR linearity with the AVA. He measured the FR of the SMSL SU-1 into the AVA ABX at output levels of 99 and 90, then adjusted the vertical position so the curves sat on top of each other, and they show the same response.
When Amir did that test with his Topping A90, the curves were different, but with Josh's Benchmark HPA4, they were aligned.
I think that's really solid evidence.
Though of course it doesn't excuse the noise, distortion, low input impedance and high output impedance.
I'm not dodging the question about what signals were used set the levels. It can be done with noise, a tone, multiple tone or averaging. I guess it was done with a 1kHz tone, but the resulting FR is like that above, that would be fine.
I have to say that I am more than skeptical at this point. Amir's measurements in the first post into the presumed 100k impedance of the AP analyzer show an additional drop of more than 0.2 dB at 20 kHz (about -0.18 dB for vol. 99 vs. about -0.43 dB for vol. 90). That is at a nominal 100k, not the nominal 50k of the HPA4 with measurements by @nagster a couple posts above showing lower actual values closer to 40k for the RCA input of the Benchmark. Unless I'm understanding something totally wrong here, this would imply that the measured drop @20 kHz should be higher in the data Josh presented - not near zero, as shown in his plot. As far as I can see, the results he presented now (I am not sure those were ever shown before?) do not agree with multiple datapoints presented in this thread.
Not sure if I understand the point well enough, however:
above is an example of impedance 1kohm inserted between source (V1) and load (R2), C1 is a sum of cable capacitance and input impedance of the load (AP, HPA4, whatever). The time constant of the circuit, that determines the corner frequency (-3dBr), is RC1, where R = R1//R2 = R1R2/(R1+R2). Thus, the lower the load impedance R2, the less is the drop at higher frequencies related to flat transfer value. Thus, the relative high frequency drop with 100k load is higher than with 40k. The unknown variable is then the input capacitance of AP and HPA4, thus again, we do not have enough data. All the time we miss the data and everything are mere speculations.
Gut feeling says VA outsourced the design to some industrial, non-analog/non-audio engineer around the corner who didn't get paid much.
I've seen this before...
The designer was Dan Kuechle from Kuechle Engineering Services.
He was identified and entertained questions about this unit over ten years ago. I'm sure this thing is ancient history and he's moved onto other things.
32 pages and counting on ASR. :)
above is an example of impedance 1kohm inserted between source (V1) and load (R2), C1 is a sum of cable capacitance and input impedance of the load (AP, HPA4, whatever). The time constant of the circuit, that determines the corner frequency (-3dBr), is RC1, where R = R1//R2 = R1R2/(R1+R2). Thus, the lower the load impedance R2, the less is the drop at higher frequencies related to flat transfer value. Thus, the relative drop with 100k load is higher than with 40k. The unknown variable is then the input capacitance of AP and HPA4, thus again, we do not have enough data. All the time we miss the data and everything are mere speculations.
Thanks. That seems counterintuitive to me. I also understood @amirm's argument in this post in the sense that the lower 10k input impedance of his Topping A90 would be more problematic for the resulting FR than the 50k of the HPA4, because it is too close to the 5-8k output impedance of the comparator.
Maybe "counterintuitive", but the hard fact. This is so called Thevenin theorem applied on circuit impedance, or you can calculate the transfer function using very simple electrical circuit maths. Intuitive is not always right. If you reduced the load impedance to 1kohm, the steady state level would drop of -6dB, but the cut-off frequency would be doubled.
Wow guys, are we still talking about this? there was no third party to corroborate the result, Period. There was no scientific method! futile discussion. If somebody tells you pigs can fly, how far you want to go corroborate that, common sense guys. The burden of proof is not ours, don't waste your time.
It's interesting to myself and others. If not interesting to you, there's an easy solution for that.
Your commentary hints at one of these things. In addition to the technological puzzle presented, there are epistemological questions with no easy answers. More specifically, what level of scrutiny and what is the burden of proof needed to make positive claims of ability to discriminate? Pretty simple at the basic level. Extraordinary claims require extraordinary evidence. But one person's "extraordinary claim" is another person's "common-sense truism." It depends on your priors. When dealing with two communities with radically different priors, what deference is owed to try to satisfy the what the burden of proof would be according to their priors? Is there any hope of bridging the epistemological gap between two communities?
What we're seeing here is entirely predictable and yet somewhat dismaying. Polarization between the two communities, each one thinking the other side is increasingly unreasonable, blinkered by their presuppositions, and acting in bad faith. Not unlike debates in other domains, such as sports and politics.
Both sides are right, we are in a post modern age.
Fyi I measured 18 degrees phase shift between matrix dac and topping at 1 Khz. So they are out of phase. Someone asked about this on the other thread.
Maybe 180°?
Confused Yoda is. Didn’t Josh show they were in phase? Standard settings and RCA out? This was my first question that would completely change the game of this test. But perhaps the Topping is inverting?
Which Matrix model are you using? My memory is a little fuzzy, but I think in the other thread we saw some Matrix models are inverted polarity but the model Josh used preserves polarity.
