solderdude
The thing to do then is to put in A vs. A, and see if you find a bias, randomizing 'x' of course.
I believe Josh did exactly that test (if that's what you meant)
It gave a -100dB difference in the test.
Of course a bunch of distortion was added and a minute roll-off but these alterations of the actual signal were the exact same on both inputs as the attenuator was in the same position.
And using music instead of multitone.
The relay sounds during the blind tests were supposed to be masked by always flipping a relay even if the input was not switched.
