I gave it a shot even though this is a very challenging task for AI. Prompt to ChatGPT Pro (paid):
summarize this article:
https://audiophilestyle.com/ca/bits...he-van-alstine-abx-comparator-r1440/#comments and analysis in this thread:
https://www.audiosciencereview.com/...o-by-van-alstine-abx-comparator-review.73737/
Short version
The Audiophile Style article is a sincere, unusually careful attempt by Josh Mound to ABX-test DACs, but the later ASR examination shows that the
specific comparator cannot support his headline conclusion: that he proved he could distinguish otherwise transparent DACs by their sound.
The central issue is not whether ABX is valid—it is—but whether this particular switching/level-matching device eliminated all non-DAC cues. The evidence says it did not reliably do so.
Mound used a late-model Van Alstine ABX Comparator, two DACs fed from the same SPDIF source, a Benchmark HPA4 and Moondrop S8 IEMs. He level-matched in several stages, entered the comparator’s blind mode, and ran two 8-trial tests per DAC pair, pooling them to 16 trials. He reports at least 13/16 for every pairing and mostly 15–16/16, including comparisons between high-performing delta-sigma DACs and R2R DACs.
Audiophile Style
His own interpretation is fairly restrained: he says the differences were small, personal, and not necessarily generalizable. He also tried to avoid trivial noise-floor identification and later added checks showing no measurable
electrical A/B-path difference when the same DAC was passed through each input.
Audiophile Style
What the ASR analysis found
ASR acquired and measured the same model comparator. Its analysis identifies three possible invalidating mechanisms:
- Mechanical relay cue: the source-selection relays make audibly different physical clicks. In close headphone/IEM testing, that can reveal which path is active independently of the music. The comparator’s “uniform click” feature evidently did not make the actual relay sounds indistinguishable.
- High and variable output impedance: the attenuation setting changes the box’s output impedance substantially—roughly 5.3 kΩ at setting 99 and 8.3 kΩ around setting 90. With realistic input impedance and cable capacitance, level matching at 1 kHz does not assure identical HF response. In our 50 kΩ example, those two impedance states alone differ by roughly 0.42–0.46 dB in broadband level-divider loss; cable capacitance can add a frequency-dependent difference.
- Poor absolute analog performance: ASR measured roughly −75 dB THD (about 0.017%) plus power-supply-related noise. That is much worse than the DACs being compared, although common distortion by itself is less damaging to ABX validity than an A/B-dependent cue.
The primary ASR conclusion is therefore that Mound’s extreme scores could be produced by comparator artifacts, not demonstrated DAC audibility.
Important nuance from the thread
The more technically cautious comments make an important distinction:
- The comparator’s added distortion is undesirable, but if it is equal for A and B, it does not itself explain successful identification.
- The potentially consequential electrical artifact is the difference created by unequal attenuation/output impedance, especially at high frequencies and depending on actual load impedance and cable capacitance.
- The relay-click issue is the most direct threat because it can identify the selected route even with no audio signal at all.
So the strongest, fairest conclusion is:
His careful level checks and null recordings are evidence of good faith and eliminate some straightforward electrical asymmetries. They do not eliminate a physical relay cue, nor do they fully establish frequency-response equivalence under different attenuation settings.
Not bad. All formatting, bolding, etc. is by AI. Above is a direct copy of the response but may be biased by my past interactions with it.
