Audio by Van Alstine ABX Comparator Review
Yep...
This means that there can be (and are) audible, or potentially audible to some, differences between DACs.
As I’ve mentioned before: I’m extremely bored by the idea of audible differences between DACs because I believe any well designed DAC should be neutral and transparent, and I believe that’s what I have with my Benchmark DAC. So I don’t even think about this stuff anymore.
That said, I still have the puzzling results I have described before, some blind tests I did way back around 2000 or so between a Meridian, Sony and Museatex Bidat DAC, where I was able to easily distinguish between them. (even from another room!) and the Bidat DAC had a volume control which made level matching at the speaker terminals with a voltmeter to be quite easy and precise.
In my informal listening the Meridian and Museatex had struck me as sounding really distinctly different, which is what aroused my curiosity and led to the blind tests. And exactly those differences seem to allow me to easily identify between them in the blind tests.
A question could be how much one would care in practice.
In the scenario above, the differences were quite relevant for me, as the Meridian had a presentation that just nudged it toward something more pleasing and slightly more real sounding to my ears.
If I still cared about my digital source that way, then I can imagine that being relevant for me. But I no longer do. If I want a source with coloration, I play records . For my DAC I just want neutral and that’s what I’ve got.
What about Josh's point that his Benchmark headphone amp has much higher input impedance than the Topping that Amir used? So in general this can be a problem with the box, but the effect would have been much less severe for Josh than what Amir showed. The spec on the HPA4 is >50K input impedance, so lets say ballpark 5X higher than the Topping that Amir was using.
It is about the output resistance and the cable+box+input capacitance forming a low-pass filter that affects the upper part of the audible band.
The load impedance to the AB box would only affect the total attenuation. In other words the attenuation level would be different in absolute level.
The steps would still be 0.1dB (or very close to it).
Also the matching is important after the amp (where Josh measured) and not at the output of the device with a multimeter (how he started out).
HPA4 is 50k and Amir loaded with an even 'friendlier' 100k load (APX555)
And when I think I did my calculations correctly I arrived at a 20k output resistance (higher than what Amir arrived at) in the 99 setting.
It would look like both the input imp of the box is 20k and it has a series resistance of > 20k (a 20k in series with the 'wiper').
But then again... I could be mistaken and misinterpret the data on the dashboard namely 2V input, 1.67V output, max level (99) and 100k load (APX555)
I thought Amir loaded it with a Topping headphone amp. Is that not correct?
That's where I could have been mistaken and also made calculations based on a 10k load and 600ohm load. (post #16)
Regarding the crap bench results (distortion) this unit displays, Matt Hooper, of all people, hit a salient nail on the head: this means that for some uses -- such as amp comparison -- the Van Alstine device (NB., not the only ABX box ever made) really could be 'masking' a possible 'real' audible differences -- a charge audiophile crackpots have been leveling for decades at ABX boxes.
Well, how nice to get some acknowledgment from Mr Krabapple, of all people. ;-)
I was of course being only half serious…annoying to see a result that can get the golden ears saying “ha, see we told ya!”
Even though this, of course, does not validate their general claims.
It would be fairly typical to see a golden ear citing these measured results as supporting their claims that these sciency boxes can interrupt the transparency of a system and corrupt results…. And yet go right back to criticizing measurements as being beside the point are not telling the whole story when they don’t support their claims.
According to this post, I would think he used two different AP settings (100 kΩ + 0.6 kΩ) to load the outputs and then caclulated the output impedance. At volume 90, that showed well over 8.5 kΩ impedance, which is too high for a 50 kΩ input when using the "8x or more" rule of thumb. And it is frequency dependent, with higher attentuations showing a stronger drop in the upper treble.
I would also like to repeat that the boxes' input impedance is currently still unkown. Low values there would cause additional trouble on the DAC side.
I don't think the Topping headphone amp came into it until Amir's update on Page 18, so after your Post 16 calculations.
It was this curve I was thinking of. So this would be not so mismatched with headphone amp with 50K input impedance, right?
I did a bunch of sighted DAC comparisons several years ago followed up with objective measurements; Squeezebox Touch, Chord Qutest, HiFi Berry HAT. All were connect to my main system through my streaming computer or RasPi streamer (optical, BNC, or USB) so I could easily switch between them. I thought I could hear subtle differences between them but those differences were pretty elusive. I wound up running each DAC in my main system for a couple of weeks then swapping to a different one by changing the output device on Roon. After a few weeks of this I found that there were certain pieces or listening sessions that just sounding great. Every time I had one of those experiences I would check to see which DAC was playing back. I had terrific experiences with each of them. That's when I realized that there's nothing more for me to worry about on the DAC front.
Reading about this ABX box I find that I'm not at all surprised given my experiences and experimenting. Disappointing that Josh proclaimed success without questioning how his hearing acuity could be better than the other 8.3 billion people on the planet. Doesn't seem to be much humility or rational thinking there.
Yes, I think the effect should be lower in that case (50k vs. 10k).
He should have observed a clear difference with that load vs what he measured with the output of the AVA. Assuming a 2.0 volt nominal output, he should have observed that matching was off by nearly 0.1 volt or about 0.5 dB (I am rounding) with the AVA vs HPA4. This would have been both audible and observable using a voltmeter as he says he used.
Had he reported this differential, then we would have known that the passive trim adjustment had variable output and hence, such consequences. And that he was fully aware of the problem at hand.
My guess is that he matched the levels out of the AVA because he didn't know it made a difference, contrary to what he has written. And it is that difference that allowed such easy discrimination of the sources.
Adding on, him claiming now that he only used HPA4 doesn't amount to anything. The thing that would have settled it was to hand over captured outputs. Then we could have easily verified if a level difference existed.
I’m sorry, someone like me with so little technical knowledge should just shut up (and I will again), but can’t you just AB test two units of the same DAC (ideally something the subjective folks call cookie cutter) and record the difference? We do simple control experiments like that in biology where I have my degrees… sorry if this was covered, ChatGPT said it could not summarize the 3 threads for me and I ain’t gonna catch up.
That was exactly the point of asking for source files. That said, I personally would not trust those blindly either, and don't think they'd settled the debate at all. They'd just record whatever flaws there were in the comparison... or not, there'd be endless debates about it. "What microphone was used?" "How?" "What was the environment like?" etc etc
Yes and no. Yes in this context as the writer claims to have heard such obvious results through a highly distorting and noise producer comparator. As noted, we asked for this very thing but he refused to provide.
No in that if you really want to probe the DACs at this extremely low level of noise and distortion, you can't run them through an ADC as this likely would add its own distortion and noise. But again, that is not the situation here. The reviewer was not at all bothered or sensitive to copious amount of noise and distortion the comparator added. ADC captures/recordings would have been far superior as a matter of fact.
Exactly. In the long thread, we suggested that he should have just taken one DAC and fed it to both inputs of the comparator and measure/listen to see if there is a difference when there was none. Indeed, I conducted a bunch of my tests and measurements on this box this way. To the extent the comparator is new to the reviewer, with no objective analysis of anywhere, he should not have trusted it blindly, pun intended. Verification had to be done in this and other manners.
I gave it a shot even though this is a very challenging task for AI. Prompt to ChatGPT Pro (paid):
summarize this article: https://audiophilestyle.com/ca/bits...he-van-alstine-abx-comparator-r1440/#comments and analysis in this thread: https://www.audiosciencereview.com/...o-by-van-alstine-abx-comparator-review.73737/
Short version​
The Audiophile Style article is a sincere, unusually careful attempt by Josh Mound to ABX-test DACs, but the later ASR examination shows that the specific comparator cannot support his headline conclusion: that he proved he could distinguish otherwise transparent DACs by their sound.
The central issue is not whether ABX is valid—it is—but whether this particular switching/level-matching device eliminated all non-DAC cues. The evidence says it did not reliably do so.
The Audiophile Style article​
Mound used a late-model Van Alstine ABX Comparator, two DACs fed from the same SPDIF source, a Benchmark HPA4 and Moondrop S8 IEMs. He level-matched in several stages, entered the comparator’s blind mode, and ran two 8-trial tests per DAC pair, pooling them to 16 trials. He reports at least 13/16 for every pairing and mostly 15–16/16, including comparisons between high-performing delta-sigma DACs and R2R DACs. Audiophile Style
His own interpretation is fairly restrained: he says the differences were small, personal, and not necessarily generalizable. He also tried to avoid trivial noise-floor identification and later added checks showing no measurable electrical A/B-path difference when the same DAC was passed through each input. Audiophile Style
What the ASR analysis found​
ASR acquired and measured the same model comparator. Its analysis identifies three possible invalidating mechanisms:
  • Mechanical relay cue: the source-selection relays make audibly different physical clicks. In close headphone/IEM testing, that can reveal which path is active independently of the music. The comparator’s “uniform click” feature evidently did not make the actual relay sounds indistinguishable.
  • High and variable output impedance: the attenuation setting changes the box’s output impedance substantially—roughly 5.3 kΩ at setting 99 and 8.3 kΩ around setting 90. With realistic input impedance and cable capacitance, level matching at 1 kHz does not assure identical HF response. In our 50 kΩ example, those two impedance states alone differ by roughly 0.42–0.46 dB in broadband level-divider loss; cable capacitance can add a frequency-dependent difference.
  • Poor absolute analog performance: ASR measured roughly −75 dB THD (about 0.017%) plus power-supply-related noise. That is much worse than the DACs being compared, although common distortion by itself is less damaging to ABX validity than an A/B-dependent cue.
The primary ASR conclusion is therefore that Mound’s extreme scores could be produced by comparator artifacts, not demonstrated DAC audibility.
Important nuance from the thread​
The more technically cautious comments make an important distinction:
  • The comparator’s added distortion is undesirable, but if it is equal for A and B, it does not itself explain successful identification.
  • The potentially consequential electrical artifact is the difference created by unequal attenuation/output impedance, especially at high frequencies and depending on actual load impedance and cable capacitance.
  • The relay-click issue is the most direct threat because it can identify the selected route even with no audio signal at all.
So the strongest, fairest conclusion is:
Mound’s reported scores demonstrate that he could identify the comparator’s A/B/X states under his setup. They do not establish that the identifying cue was an audible difference between the DACs.
His careful level checks and null recordings are evidence of good faith and eliminate some straightforward electrical asymmetries. They do not eliminate a physical relay cue, nor do they fully establish frequency-response equivalence under different attenuation settings.
Not bad. All formatting, bolding, etc. is by AI. Above is a direct copy of the response but may be biased by my past interactions with it.
Wait....Josh gets paid for the articles he writes for AS, including the very article that started all this?
There is a word I am thinking of now that describes this type of person and it rhymes with 'fill'
It's not really possible to draw any more out of Josh's results. It's flawed and any further information derived will be questioned on both sides of the debate.
It's unlikely that someone comes up with a great inference, proof, or thought experiment outside of what's already been presented based on the current information.
The only way to get genuinely more substantial information would be to set up another ABX trial independently. Josh could certainly participate. Being a 98% accurate kinda guy it would seem like a no brainer for him to accept that kind of offer. On the other hand, he's been paid and he has his followers still, so perhaps not so much inclination for him to participate...
And again, doing this well requires considerable effort.
I do sort of like the one line AI summary though...
"Mound’s reported scores demonstrate that he could identify the comparator’s A/B/X states under his setup. They do not establish that the identifying cue was an audible difference between the DACs"
All we really know is, in his setup, he can detect differences, but we can't infer that he can detect differences under any other more generalized circumstances.
Sounds like a pretty good one line summary of 29 pages...
