Looks like he measured the volume control in different volume settings (but only after the article was released) which gave some hints as to the influence of the ABX box that should not be dismissed. Even before the box was sent to Amir.
It can be seen that the null is pretty good at the same volume setting (left column) but got a lot worse even at slightly different volume settings.
Those numbers come closer to Amir's findings.
We see the PK metric drop from -100 (could say a practical near perfect null) to -55-60.
Most likely roll-off related judging from the phase difference. The bigger the difference the bigger the phase shift.
This means it is likely he actually heard differences but the conclusion he drew was incorrect because he assumed that the differences he did hear did not come from differences in DACs but differences in the ABX box due to different volume settings.
Acc. to Josh he always had to use different volume settings but never lower than 90. The only time he did not have to use different settings was with the Gustards.
my worst result across two consecutive runs of any test was 13/16. I compared the Gustard X30 and R30, for example, which share the same output level and required no attenuation at all.
That means that for that test at least the null would have been good and differences between DS and R2R versions that would mostly differ in added distortion.
The problem is that the lower distortion and the distortion profile of the R2R were both worsened to the same (higher) distortion caused by the box so harder to distinguish. This is where his score dropped as the R30 and X30 became more 'the same' due to the added distortion and no different phase/roll-off caused by the 'volume control'.
All the other DACs (the ones that measure 'transparent') were more different sounding and were distinguishable.
It turns out that the DACs tested were probably not really (as) distinguishable as the test results say but the differences caused by the volume control setting (HF roll-off phase and maybe even distortion and/or the, by Amir, mentioned noise-floor difference when using IEM's.
So it seems safe to say that Josh did hear differences, level matching probably was done correctly and the results he got were valid but .... the differences he heard were (with a high degree of certainty) caused by the different volume control settings of the ABX box and not necessarily differences between DACs.
One can say Josh did not hear detectable differences between DACs but Josh did hear (reliable) differences between different volume settings of the ABX box.
This could mean Josh was not lying nor doctoring results but was 'tricked' by the box when using different volume settings during his testing.
The article and test thus can safely be ignored ... because the box itself made changes that were small (barely acc. to Josh) but detectable.
Assuming the box was not the cause of the perceived differences but turns out it (very likely) was.
This is kind of confirmed by his own testing (table above) and Amir's tests.
Main culprit... the high output resistance of the box and behavior of the AD5652 volume control chip used in the ABX box causing added distortion and roll-off just in the audible band.
Audible differences between DACs .... NOT confirmed... ABX box volume control circuit alters the signal in an detectable way using blind ABX testing.
Sorry
@Josh83 ... valiant effort that took a lot of time, seemed science-y but sadly was unreliable resulting in (most likely) incorrect conclusions.
I still like you for making an effort... you just picked the wrong tool to do it with.
