Audio by Van Alstine ABX Comparator Review
For those wondering about relay click audibility, here are some proper signal relays with a grain of rice for scale.
TMUX1208?
As is, I consider you a bad actor. And a hostile witness. So please don't complain. I have no patience after all the work you created for us for no reason.
Um you can get off the merry go round you know? No one forced you.
The review was posted on APS, not ASR. I'm not sure who forced anyone to do anything.
This is getting out of hand. Does anyone think Josh would have bought the AVA ABX box if he knew how badly it performed?
That's the benefit of hindsight. Sometimes learning is difficult, time consuming and expensive.
I honestly thought Josh's testing might amount to something new and useful, but not any more.
Instead, we have PMA's thread on comparing ADC recordings - and that really is valuable.
And when you denigrate the whole group, it's perceived just like a personal attack.
At least I have something to say and there is some real audio related work behind me - contrary to mere debates.
Touchy?
Touchy?
So much grumpy! You need a hug.
I have to say, I just said, on another forum, that I did not believe "every amplifier I bought sounds different". This created a storm of complaint, but also a storm of agreement.
What upset some people is when I said "if two amplifiers sound different (at the same gain), then at least one of them is faulty". Oh dearie me. Like Krabapple, I'm really, REALLY, REALLY tired of being told how stupid and idiotic I am when I ask for an actual blind test.
He isn't asking for blind test of audio. He is asking (presumably) for a blind test of the sound of a relay turning on and off. I really hope you are not with him in this regard.
Far be it for me to speak for JJ, but my read of his post was that he was tired of people claiming differences in amplifiers without blind tests and jumping on him for his point of view, not that he was asking you to record relays switching. Pretty sure we've all heard enough relays switching in our days to understand there's a difference.
And, there you go! Relays are much bigger than a grain of rice. But I have to admit the comparison would be much harder to see in a blind test...
Are we done here?
Are we done here?
I wish…
To summarise:
The ABX box 1) adds significant distortion and level differences that *will* affect the tests. It also 2) presents a relay noise that *might* influence the tests, if you can hear it despite wearing IEMs.
Issue 1) is significant enough to make the tests useless.
Issue 2) can only make matters worse.
That’s it. Isn’t it?
I wish…
To summarise:
To (1) I would add the frequency response differences that Amir measured as significant contributors to potential test bias.
I stopped doing more than just skimming a number of pages back.
Reactions: MAB
That, I think, was what I’m trying to say . I’m not technically knowledgeable in this area, so my wording may have been clumsy.
My main point is that point 1) is decisive. The test is flawed. No amount of sincere effort (which I’m sure was made) can overcome that.
A lot of relatively inexpensive gear could have been procured for measurement for the out-of-pocket cost of this review.
That was not sighted to her. I did the switching blind to her and asked her if she did, or did not hear a difference. And once she said there was a difference she gave the same explanation as I. I literally dragged her up to the lab (she is in pain due to back injury) to double check I was not imagining this difference. So excuse me if I am not taking well to such commentary.
You have misunderstood. I didn't say your wife made a sighted call . The full classic audiofool trope is 'even my wife in the kitchen heard it!', which is single blind. As was your experiment. Which is somewhat beside the point ...what made your anecdote so notable to me as a choice to report, is its obvious, fundamental similarity to a famous audiophool trope that is practically a cliche, and often a joke. Which surely you knew?
I don't know what the heck this means. You expected us to see all the additional noise and distortion overlayed onto state of the art DACs yet go whistling dixie that is good enough to find out differences that are orders of magnitude smaller than this? By your logic, I should be able to tell the self-noise of two microphones in a very noisy room.
I guess you did not (know what the heck it meant).
It meant that the Van Alstine ABX comparator indeed might mask a truly perceptible, but subtle , audio difference. IOW, agreeing with what you write in your reply.
Which happens to be something audiokooks have been yelling at us for years, about ABX boxes generally.
Which is what Matt alluded to.
Why don't you try to solve this puzzle with just this box and nothing else from Josh.
I won't do that...can't, really.
Nor am I defending Josh, just noting , correctly, that what he *did* do, right or wrong, should at every step of the argument be known and taken into account.
And even with that (see: Solderdude's posts), the final verdict on his claim remains: misapplication of technology, and/or, dishonesty. We'll never know for sure which.
To the rest of my 'junk', which elicited three defensive posts from you to my one (did I hit a nerve?), I will simply reiterate my advice to readers:
devour this whole thread at one go, as I did, and see how it makes your tummy feel. (Again, kudos to those who kept their heads.)
Thanks for the critical judgement. You should see what we think of you.
I'll assume the 'we' isn't just the voices in your head.
Yes, some reconstruction filters can have a, substantially enough, roll-off in the audible band to be audible in AB tests.
This is evident of the many tests showing the transition band for filters by Amir (and other reviewers).
Edit: and ripple in some DACs.
Not applicable to Josh's experiments because he used 96kHz files which generally don't roll-off in the audible band (well, some post-filters in some DACs do) nor were DACs used with a high bandpass ripple.
In this case there is a roll-off but attenuator setting dependent and that's what I suspect is what made Josh ace the tests when comparing DACs that are arguably 'measuring transparent'. And as the influence of the AB box cannot be ruled out as a possible tell the whole test is 'suspect'.
Well, if I understand it correctly then, the difference is 'between DACs' but only in the sense that they present different impedences, something the VA ABX comparator does not properly handle (but a competent device would).
Do I have that right?
