Audio by Van Alstine ABX Comparator Review
Seems like a thread about impedance interactions with real-world measurements and test files is badly needed.
Ideally, with conditions like popular attenuators, new, low-ish input impedance gear (under 10kOhm or so) , etc.
I am still wondering about the electrical switching artifacts that Josh describes as hearing as a static/click type sound through the IEM. @amirm is it possible for you to look at that to see if they are uniform or different?
This residual DC level related and instantaneous value differences (within Ton, Toff) related.
Yes. Would you expect any consistent difference that could be a tell?
I think so, too. There was an interesting piece here by NTTY about how the performance of the MOTU Ultralite Mk5 was affected by output level and output load.
It's a good audio interface, but the worst case distortion harmonic into 3.5kΩ (E1DA ADC) was 14dB worse than the best case, into 200kΩ.
John Atkinson always did 600Ω load testing, and a few more people like ASR and SoundStage are starting to do this too.
Most modern gear copes well, but distortion is always higher into a lower impedance, notwithstanding any FR changes.
High frequency / high amplitude / high load is always the corner of the audio envelope where performance starts to go off first.
600 ohm is a very unrealistic low load for audio sources.
For microphones or certain balanced pro inputs using line transformers it would make some sense.
600 ohm is an old telecom standard where 1mW = 0dBm = 0.7746 V
I would say most devices loading a DAC or other source have an input resistance above 2kohm
Usually around 10k - 20k. Some gear can even be 100k.
Sure one can test with unrealistic loads to see if distortion rises or what the max. output current is or calculate output impedance.
Yes, I think it's historical, but it's a measure of load tolerance and sensitivity.
Some Hypex and Purifi power amps (without buffers - which are quite the bottleneck) have very low load impedance, around 1.5kΩ.
There are a few oddities like the Topping Pre90 that has a balanced input impedance of 2kΩ.
Yes but all the modern opamps, including historical NE5532 and not very new LM4562 drive it without any problems and at very low distortion. It must have been a shit component that has issues with 3.5k load.
Not just DAC to amp, just add a typical passive variable attenuator between them (replicating thread's comparator) and you have the needed interaction (at its -6dB point would be the worst case of it)
Sorry - I read your posts as saying Dacs will sound different at 44.1K. It didn't mention passive attenuator.
This is difficult to tell. Might be if there is a substantial difference between relay Ton and Toff.
He probably meant more prone to reconstruction filter transfer function, Fs/2 is only 22.05kHz.
Asking the question another way. Would this device be useful or necessary for testing speakers, first of all? I would have to say no, as in hell no. No two differing models of never speakers sound alike. In fact, each speaker model is so different in its sound signature that they should be readily distinguishable from one another, and no 'comparator' could possibly facilitate a blind test unless you're already deaf, in which case you in no way need to be 'blinded'. So useless and unnecessary on that score.
Now, as for electronics, apart from the Tell Tale Clicks (apology EAP!), my question revolves around level matching: People like Peter Aczel stipulated the respective components must be level matched to within .1 DB of one another. Does the Van-Alstine unit do this? Based on the display it looks like level matches within 1 db are claimed. That's not good enough! Be interesting to see if there could be any testing around its level matching capabilities because if it can't achieve the requisite precision, it's useless anyway. And there are far better uses any audiophile can put $1300 to than this box.
Nice review Amir, thank you.
You might want to compare two speakers to see which one you prefer without sighted bias intruding?
Continuing our half duplex communication with Josh, he is saying:
"They've shown the ABX box has higher distortion than the DACs, which we already knew. Since I passed, the box is accused of making detection too easy. But if I'd failed, the same distortion would've been blamed for making DAC differences too hard to hear."
No, we didn't already know the extreme level of distortion that AVA produced. You posting random tidbits here and there don't provide anything close to clarity of the measurements I showed. Anyone with common sense, seeing proper data like I showed, would have said the box is simply incapable of providing a true picture of either DAC. It is like taste testing two meals in dirty dishes with soap still stuck on them. You just don't do that.
I suspect you knew that the proper measurements of the box would reveal a horrifying picture of how bad it is and hence your extreme reluctance to let me measure it.
Second, what do you think you "passed?" That there are these unknown magical factors that make all DACs to not only sound different, but trivially so? That no measurements were able to reveal that? If so, no, you failed in that regard. You passed, if we trust you, an AB test with a highly flawed tool whose weaknesses were not known to you. To wit, not a word came from you that changing trim levels resulted in output impedance changing and hence, caused level shifts.
It took but a few hours after I too "passed" the AB test with flying colors to figure out that no, the DACs didn't sound different but the box failed in its primary mission of not impacting one output over the other.
And this is key: the job is not to just pass a test and step back and celebrate. The job is to do that first but then seek explanation as to how that outcome was possible. That is the process I followed. And have done throughout the years as I have passed rare comparisons. In every one of those cases, I provide reasons for me being able to tell the difference. In a test by Archimago of 24 vs 16 bit, I explained for example that decay down to nothing could be differentiated with elevated volume level. Once there, folks accept that and can then put things in perspective.
In contrast, you think as soon as you "passed" this AB test, the job was done. We now get to believe in fairy tales that two DACs that have noise and distortion well below threshold of hearing, seemingly sound so different as to you acing every comparison. In a way, you are spitting on the face of objectivity, while attempting to use its tools (blind AB), to claim victory. It is a difference between wanting notoriety (and money in this case), compared to advancing our understanding of audio fidelity.
Above is why after Dr. Toole and crew performed controlled testing of speakers, they didn't just say "our speaker won" and sit back waiting for applaud. They dug in, performed massive amount of statistical analysis and then correlated measurements with those observations. Even then, they repeated the tests over and over again with different conditions.
You passed a test which we can't witness. One where you act in the most suspicious way by refusing to provide recordings of the output of the box. And then resisted almost all attempts for us to analyze the comparator. This was all under your control. So don't act like a victim saying you passed a test so where is your medal.
Speaking for myself, I have tested folks like you and you can't even pass a lossy MP3 encoding in blind testing. There, we have guaranteed degradation of fidelity yet subjectivist audiophiles can't pass these tests. Yet you want us to believe that you passed a test of two state of the art DACs? And went further and did it across many others? What do you expect us to do? Put everything we know aside and just praise you?
No, we investigate. We put our money and resources where our mouth is. You worked against us. And because of that, we still don't know what you really "passed."
As to failing, I am pretty sure that wouldn't have been something you would have written for which Chris would have paid you. Let's be clear on that.
I on the other hand, do post my failures. Here is an example:
foo_abx 1.3.4 report
foobar2000 v1.3.2
2014/07/19 07:09:23
File A: C:\Users\Amir\Music\Arny's Generational Loss\sb20x_original.wav
File B: C:\Users\Amir\Music\Arny's Generational Loss\sb20x_pass1f.wav
07:09:23 : Test started.
07:09:40 : 01/01 50.0%
07:09:54 : 01/02 75.0%
07:10:07 : 01/03 87.5%
07:10:26 : 02/04 68.8%
07:10:36 : 03/05 50.0%
07:10:51 : 04/06 34.4%
07:11:03 : 05/07 22.7%
07:11:14 : 05/08 36.3%
07:11:29 : 05/09 50.0%
07:11:44 : 06/10 37.7%
07:12:01 : 07/11 27.4%
07:12:16 : 08/12 19.4%
07:12:37 : 09/13 13.3%
07:13:23 : 09/14 21.2%
07:13:34 : 10/15 15.1%
07:13:47 : 11/16 10.5%
07:14:00 : 12/17 7.2%
07:14:13 : 13/18 4.8%
07:14:23 : 13/19 8.4%
07:14:37 : 14/20 5.8%
07:15:09 : 14/21 9.5%
07:15:22 : 15/22 6.7%
07:15:39 : 16/23 4.7%
07:15:59 : 16/24 7.6%
07:16:12 : 16/25 11.5%
07:16:34 : 17/26 8.4%
07:16:48 : 18/27 6.1%
07:17:09 : 18/28 9.2%
07:17:53 : 18/29 13.2%
07:18:11 : 19/30 10.0%
07:18:34 : 19/31 14.1%
07:19:13 : 19/32 18.9%
07:19:18 : Test finished.
Total: 19/32 (18.9%)
As is, I consider you a bad actor. And a hostile witness. So please don't complain. I have no patience after all the work you created for us for no reason.
Yes, in the way it has a remote for AB switching and you can adjust levels (only if you measure them the way I did). I plan to use it this way in the future.
Of course, level matching with speakers is whole other story. In the absolute, it can't be done but it is better than doing nothing and just listening to one speaker at a time.
The trim control steps are 0.1 dB.
Interestingly enough the step size the volume control chip can actually do is 0.033dB but the designer decided to make each step (up to a certain point) 0.1dB.
Too bad the volume control IC has poor performance and would be better served with a buffer right behind it. And even then distortion would be high.
Anyway... the thought/idea behind the box was good, the execution is where it failed.
After this review the owner will have a hard time selling it :(
Yep...
This means that there can be (and are) audible, or potentially audible to some, differences between DACs. A question could be how much one would care in practice.
Are we really talking about DACs or about anti-imaging filters in DACs?
The box also has (at least potentially) audible differences when different attenuation levels for A and B are used.
In the output of the amplifier behind the ABX box there thus will be a mix of (potentially) audible differences and those seem to result in 'reliable detectable' differences.
However, it is unclear which 'audible differences' are caused by the box and/or the DAC.
The conclusion that DACs can be distinguished in a properly conducted ABX test thus is not proven in Josh's article.
Simply because the box can (and does) impart audible changes and this is the key part.
But... might/could still be using a different (and verified) test method.
I was away for a bit and read this entire thread last night. I recommend all to do that.
It was not an edifying experience. Much of ASR seems to have lost a marble or two in response to the review.
That said, all props to Solderdude, one of the few who kept his head on straight throughout.
FWIW I believe Josh's claimed accomplishment is frankly impossible.
But for Amir to first cite a relay switch noise ('up vs down' , or 'tick vs tock') as a possible tell -- that's entirely possible -- but balk at recording it....amounting to dotting the 'i' and crossing the 't' on that theory -- was a flummoxing choice to this reader. I seriously, seriously doubt it requires anything near a $1000 microphone and fancy pre to capture that sound, a sound that could be heard by a good listener (Amir) wearing IEMS (not playing music). If he doesn't have an adequate one, for god's sake let's buy it for him! I'll send my never-used UMIK USB mic (purchased for REW readings that I still haven't done) to Amir if that helps. If he doesn't have time, fine, put it on the to-do list for the future! But to simply not be interested in entering an obvious bit of evidence into Josh's 'trial', but also offer sighted testimony with an 'even my wife could hear it' addendum-- plus continued chastizing of Josh for not providing us necessary recordings -- that all had me almost literally agog. It all has the makings of an audiophile farce. :rolleyes:
Regarding the crap bench results (distortion) this unit displays, Matt Hooper, of all people, hit a salient nail on the head: this means that for some uses -- such as amp comparison -- the Van Alstine device (NB., not the only ABX box ever made) really could be 'masking' a possible 'real' audible differences -- a charge audiophile crackpots have been leveling for decades at ABX boxes. And to use those crap results to wave away any need to even consider the case or the cause any further -- another rhetorical tactic displayed on this thread -- is a lame out.
Solderdude pointed out why the relay 'tell' theory might not hold given Josh's particular testimony. It feels like no one read that!. Then we moved on to another discovery, the impedence vs attenuation issue. Solderdude posted a very nice breakdown of what Josh did , to conclude this was the likely issue. No one else did that! Even though understanding what Josh actually did (to the extent we know) is critical to judging how dispositive any of the theories are. Much less to throwing accusations about what he didn't do, apparently without knowing that he didn't do it. There was so much posting about theories that had already been explained/discarded earlier in the thread.
Finally, allow me to cite the diversion into LED light conspiracy theories as another low point, and leave it at that.
tl;dr: I'm glad we found a reasonable answer but getting there was a crazy and dispiriting ride. I say this as a person with routine, perhaps even small-pond notorious, contempt for 'tone moderating'. But READ THE WHOLE THREAD if you disbelieve. Jeez, ASR, what a performance.
It doesn't. You are capturing a live event, not a mere tick. That, I recorded easily enough with my phone. It didn't work as what it captured did not sound at all like the real thing. The relay is like an instrument inside a box that resonates. And you hear it with two ears. You don't just stick a random mic anywhere. You also have to balance background noise against levels. And once again, this balance should be what I was hearing.
I also didn't think one needs to prove that relays sound different when going down vs when going up. As PMA already showed.
But also offer sighted testimony with an 'even my wife could hear it' addendum
That was not sighted to her. I did the switching blind to her and asked her if she did, or did not hear a difference. And once she said there was a difference she gave the same explanation as I. I literally dragged her up to the lab (she is in pain due to back injury) to double check I was not imagining this difference. So excuse me if I am not taking well to such commentary.
As a general rule, I hate recording and sharing sounds. I only do it in special occasion when it is really critical to demonstrate something. It is tedious work and my bench is not set up to do it.
I don't know what the heck this means. You expected us to see all the additional noise and distortion overlayed onto state of the art DACs yet go whistling dixie that is good enough to find out differences that are orders of magnitude smaller than this? By your logic, I should be able to tell the self-noise of two microphones in a very noisy room.
It is true that some differences are not masked by what the AVA comparator imparts, such as frequency response differences between the two DACs. But for any serious work, comparing state of the art DACs, it would be laughable to try to do it with this box. If I said heard differences in distortion between -130 and -120 dB in two DACs using this box, your position would be what? You wouldn't say that is impossible as the AVA has distortion of itself at -60 dB???
Regardless, this was noted but not used as explanation of what Josh may have perceived. I stated that the very thing in the review itself:
"Yes, it is the same impact on both devices under test but surely this level of distortion easily dwarfs distortion spikes in original DACs that are orders of magnitude lower"
I then performed a lot more work including listening tests and further analysis to show a clear case of the AVA box causing level mismatch. And with it, false positive in blind tests.
So no, the only thing I see lame is your commentary. We did real work here to try to investigate Josh's story in every which way. The discussions help push for different corners of the problem resulting in pretty serious discoveries.
